I have the beige top on my vert, when it gets wet there are areas that seem like they are getting saturated as they look much darker, Nothing gets wet on the inside I just dont like the dark spots, Any products out there that will seal the top and stop this condition ?
"In the Corvette faithfull I Trust"
Greg C
Location: Ponte Vedra Beach / London State: Dazed and confused
•Apply fabric cleaner (Harrtz RaggTop Cleaner) with a clean, damp applicator and leave to penetrate fabric for 10 – 20 minutes dependant upon stain. Gently scrub using a soft brush. Repeat if necessary.
•Appling two light coats are better than the application of one heavy coat: allow drying thoroughly between coats.
•Rinse off using a low-pressure water hose and a soft horsehair brush
•Dry with a waffle weave Microfiber towel using a blotting motion to dry excess moisture.
•Allow the fabric to dry for as long as possible (preferably 24-hours) before using the protectant. An hour or two isn’t long enough, it may feel dry but that’s only the uppermost surface layer (using a protectant on a damp fabric will ‘seal in’ the moisture and encourage the formation of mildew)
•Apply a fabric protector (Harrtz RaggTop Protectant) on the dry fabric, keeping about 6-8 inches above surface and using a back and forth movements spray lightly but do not soak.
•Alternatively use a soft horsehair paintbrush and apply light thin coats, if time permits, two light coats are better than one medium coat, using gentle sweeping motion. Do not saturate. Allow to dry 10-15 minutes between coats, and to dry thoroughly before using or storing.
