Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-24-2007, 01:12 PM   #1
USA1LT1
CF Senior Member
USA1LT1's Avatar
Default Peeling Clear Coat on '95
My recently purchased dark metallic purple '95 LT1 coupe has a small section on the front bumper where the clear is coming off.
I think the bumper has been repainted in the past, so the poor adhesion may be due to improper paint prep. The rest of the car looks fine.
I've managed to scrape some of the bubbled areas off with my fingernail, but I'd like to try to avoid scraping any more of the clear coat off.
Do you think it makes sense to try to color sand the clear, and feather the edges of the peeling area so it won't spread?
I'm trying to avoid having to re-spray the clear on the bumper, so I may just leave it as is if there isn't any homegrown solution.
What to you guys think I should do?
USA1LT1 is offline   Reply With Quote
Old 03-03-2007, 12:54 AM   #2
USA1LT1
CF Senior Member
USA1LT1's Avatar
Any advice?
Old 03-03-2007, 01:26 AM   #3
ZaneO
CF Senior Member
ZaneO's Avatar
There isn't really much you can do for peeling clear beyond a repaint.
__________________
Zane Oliver
ZaneO is offline   Reply With Quote
Old 03-03-2007, 01:57 AM   #4
bldavis11
CF Senior Member
bldavis11's Avatar
Send a message via AIM to bldavis11
I had to repaint my front bumper. The cost to take to the shop and have it done correctly was $300. Be certain they get the corners the correct colors on those C4s.
bldavis11 is offline   Reply With Quote
Old 03-03-2007, 09:33 AM   #5
capevettes
CF Senior Member
capevettes's Avatar
The clear has to be removed and resprayed. You can get away with just using clear coat as long as none of the paint color has flaked off. A friend of mine just did his 87 this way. The clear was peeling off. The clear was stripped and re-sprayed. It looks new.
capevettes is offline   Reply With Quote
Old 03-03-2007, 10:04 AM   #6
Jet-Jock
CF Senior Member
Support Corvetteforum!
As said above. Also if there is no other damage then hitting it with 3M britepads and prep for clear application would be all that's needed. The nose is easily isolated either by taping off and bagging the rest of the vehicle or removing the nose. I'd do a normal first coat with base flash time then follow with a second wet-on-wet coat. Wouldn't hurt to have flex added to the urethane clear.
Jet-Jock is offline   Reply With Quote
Old 03-03-2007, 02:05 PM   #7
bldavis11
CF Senior Member
bldavis11's Avatar
The shop I used removed the whole front bumper, which worked out very well for me. They were able to get it back on perfectly. The damage was fairly minor; I had barly bumped into a trailer drop hitch and there was no structural damage at all to be repaired. I was just much more comfortable having the whole bumper pulled and repainted.
Reload this Page Peeling Clear Coat on '95
Tags
95, care, clear, coat, corvette, damage, paint, peeling, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Vette Owner - Seeking Wisdom for Some Car Repairs Amazing1 C4 General Discussion 18 03-30-2004 06:55 AM
any way to stop paint from peeling???? MY 95 C4 General Discussion 11 12-19-2003 12:55 PM
Mechanical carwash? JoeVette88 C4 General Discussion 38 12-22-2001 05:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
