Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2007, 06:20 PM   #1
luckyone928
CF Senior Member
Default engine bay cleaner?
this might sound like a dumb question but here goes! i want to clean up my engine and the bay area and before i go spraying engine cleaner and "hosing it off" with water i wanted an opinion form the experts here! thanks in advance--
luckyone928 is offline   Reply With Quote
Old 02-22-2007, 07:04 PM   #2
grunz95
CF Senior Member
Support Corvetteforum!
grunz95's Avatar
Send a message via AIM to grunz95
Default cleaning engine
Quote:
I do a 50/50 mix of simple green. I cover the alternator with aluminum foil and other electricial components. I then spray the mix of simple green and let it set for a couple minutes then I rinse lightly with my hose. Before I remove the foil I used either my air compressor or leaf blower to remove any excess water. I hope this helps.
Gary
grunz95 is offline   Reply With Quote
Old 02-22-2007, 08:12 PM   #3
BOTYNV1
CF Senior Member
St. Jude Donor '09-'10-'11
BOTYNV1's Avatar
To get even more ideas try the cleaning-detailing forum and use search to find engine compartment cleaning. You will be amazed at the different ways people choose or prefer.
BOTYNV1 is offline   Reply With Quote
Old 02-22-2007, 11:46 PM   #4
rrichar2591
CF Senior Member
rrichar2591's Avatar
I suppose it depends on how dirty the engine compartment is now. There are those here who will tell you they've hosed their engines and have no problems at all. I have a 2004 coupe and have found that if I keep it clean by wiping it down once every few weeks, I don't have to use the spray. I just take an old microfiber cloth and spray some Simple Green on it and then wipe down all the areas I can reach. Sometimes it takes a tooth brush or something small to get into some of the hard to reach areas. It also takes some patience and time. I like to do it on an afternoon when nothings pressing and I can just take my time. If you can do this every few weeks, you won't need to do the hosing. Good luck.
rrichar2591 is offline   Reply With Quote
Old 02-23-2007, 01:16 PM   #5
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
http://forums.corvetteforum.com/show...ighlight=togwt
TOGWT is offline   Reply With Quote
Old 02-23-2007, 06:00 PM   #6
MThomas
CF Senior Member
MThomas's Avatar
Send a message via AIM to MThomas
I know I better knock on wood, however, I have always just used a power wash on my egine area. (20 years) I do this about once a month and my engines always look new. Never had a problem
MThomas is offline   Reply With Quote
Old 02-23-2007, 11:09 PM   #7
ripen ls6
CF Senior Member
Though many modern cars electronics are water-proof, be careful with presure washers and water in general, if you can use damp rags would probably be better than blasting water all over the place.
-m
ripen ls6 is offline   Reply With Quote
Reload this Page engine bay cleaner?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Performance hood seal german72 C5 General 33 05-21-2005 09:56 PM
Fluid leak in engine bay joshwilson3 C3 Tech/Performance 14 03-25-2005 10:21 PM
How to clean engine bay killaz Car Care Discussion 17 02-11-2005 07:34 PM
engine bay shot with juice 1996man C4 Forced Induction/Nitrous 17 02-21-2004 11:35 AM
engine bay help! redhotandrollin C4 General Discussion 14 12-25-2003 11:12 PM
My engine bay.....after a years work. luvmy73 C3 Tech/Performance 40 07-25-2003 02:11 PM
Just bought my 95 C4, How do I clean the engine bay! kspurr C4 General Discussion 9 06-15-2002 10:23 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
