Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2007, 12:43 PM   #1
blackvette1
CF Senior Member
blackvette1's Avatar
Default Zaino - Z2 Hard to Remove?
Just started using Zaino and liked the results but the Z2 was way too difficult to remove. Not sure if I'm doing something wrong since I did the Z5 the exact same way and it came off easily. Also some one else I know that started using it has had the same issue? The initial response I've heard is that I'm using too much but thats not the case since the Z5 comes off easy using the same amount. I only used about 1/2 to 3/4 ounce at most for each coat.
I did the clay bar, then 2 coats of Z5 (with ZFX) and then finished up with 2 coats of Z2 (with ZFX). Any ideas on why the Z2 isn't coming off easy like the Z5?
blackvette1 is offline   Reply With Quote
Old 02-22-2007, 01:27 PM   #2
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
Either you applied it too thick or are not waiting long enough for it to dry.
What is it doing, just smearing? What type of towel are you using? I get best results with 100% cotton or DFTowels for removing Zaino.
I just reread your post and realized that you used 3/4 oz, you only need 1/4 oz to do a car. Take it off the best you can and whatever you cannot remove go over it with a damp towel to remove it.
And like Josh said, 3 coats is all you really should do in a day. After 3 coats I won't add another coat atleast until after I wash it.
agentf1 is online now   Reply With Quote
Old 02-22-2007, 02:52 PM   #3
JoshVette
CF Senior Member
JoshVette's Avatar
Probably not letting it dry long enough.
4 coats is really too much......you shouldn't go more then 2-3 at most in a week. Beyond that it just doesn't work well.
Just give it another wash and it should be good.
JoshVette is offline   Reply With Quote
Old 02-22-2007, 03:08 PM   #4
mrosa65
CF Senior Member
Support Corvetteforum!
mrosa65's Avatar
1/2 to 3/4 ounce for a single coat sounds like a lot. I can typically get 2 or 3 coats from a single ounce.
As mentioned already, what sort of towels are you using to remove it ? I use quality MF towels with a short nap and it comes off pretty easy.
If it wasn't dry all the way will make a difference and the outside temperature plays a big factor with that.
As Josh pointed out already, even with using ZFX you shouldn't apply more than 3 coats in a 24 hour period as per the Zaino website.
You may also want to spray your applicator with a shot or two of Z6 prior to applying the Z2. It helps to spread it very thin.
mrosa65 is offline   Reply With Quote
Old 02-22-2007, 03:12 PM   #5
blackvette1
CF Senior Member
Yes, the Z2 was just smearing when I went to wipe it off so I let it dry for a couple of hours but it still smeared. Maybe it was too many coats at once which is why the first couple of coats of Z5 came off easier.
I'll try just 1 coat of Z5 followed by 1 coat of Z2 next time to see if that makes a difference.
Old 02-22-2007, 03:14 PM   #6
Ruz
CF Senior Member
Quote:
1/2 ounce per coat sounds like a lot but you get 2 coats per ounce???
Ruz is online now   Reply With Quote
Old 02-22-2007, 03:51 PM   #7
gmblack3
CF Senior Member
gmblack3's Avatar
Quote:
I can do 3 applications of Z2/5pro with 1oz on a vette easy. I put it on so thin that i can barly see it when it hazes over. But I have been using zaino for a long time.
gmblack3 is offline   Reply With Quote
Old 02-22-2007, 04:13 PM   #8
mrosa65
CF Senior Member
mrosa65's Avatar
I was typing while on the phone. I was trying to say I can easily get 3 coats from an ounce. Now if I'm applying it to my truck, then I'll use more since it's a LOT bigger than my vette.
Old 02-22-2007, 04:15 PM   #9
mrosa65
CF Senior Member
mrosa65's Avatar
How cold was it outside when you were applying it ? That affects the drying time.
Old 02-22-2007, 04:49 PM   #10
steve8
CF Senior Member
steve8's Avatar
It does sound like you are using too much. When you think you are putting it on thin enough, put it on a little thinner.
Also, have you used the same towel for all that removal? I have always used a 100% cotton towel so far, and would not take that many coats off with the towel without cleaning it. Throw the towel in the dryer without softeners before using, and it helps.
Z6 in between coats?
steve8 is offline   Reply With Quote
Old 02-22-2007, 06:53 PM   #11
JJU
CF Senior Member
Cruise-In II Veteran
JJU's Avatar
What did the "touch test" reveal? (i.e., did it leave a greasy finger print when you touched an area?) If it didn't come off clean (non-greasy), it wasn't dry yet and/or it may be due to the use of too much product per coat.
It's so hard to judge this long distance.
__________________
Jack Urban
2001 Corvette Coupe, Torch Red/Torch Red/Mag Wheels (unique 1 of 15,681 by http://www.compnine.com/vid.php)
1963 Corvette "Fuelie" Coupe, Ermine White/Red
Newsletter Editor - Midwest Early Corvette Club
National Corvette Museum Lifetime Membership #865, NCRS Member #40855
Previously owned Corvette: 1980 White/Dark Blue L48
Nebraska Zaino Distributor
JJU is offline   Reply With Quote
Old 02-23-2007, 12:19 PM   #12
blackvette1
CF Senior Member
I used 100% cotton towels and used a new towel for each coat. I was just surprised because I waited just as long and applied the same amount of Z2 as Z5 yet the Z2 didn't come off anywhere near as easy as the Z5. I did spray Z6 on applicator pad to make it go on easy. I didn't spray on Z6 between coats wasn't sure if I needed to do this?
Old 02-23-2007, 01:45 PM   #13
GoFast908Z
CF Senior Member
GoFast908Z's Avatar
Send a message via AIM to GoFast908Z Send a message via Yahoo to GoFast908Z
i usually get about 4 coats per 1 oz of zaino.
someone said only 2-3 coats per week? where did u get that idea. Its max 3 coats per 24hr period.
GoFast908Z is offline   Reply With Quote
Old 02-23-2007, 01:54 PM   #14
hcvone
CF Senior Member
You did wash the towels before using them right? As said it just sounds like you used too much, it happens. Just dampen a towel and wipe your car down, or washing it will work too. If you are putting on more than two coats in a day with Z-6 or Z-8 you need to use very, very thin coats, or else you just overload the system by putting on too much too fast.
__________________
Carl V.
Huntingdon Valley, PA.
www.hcvind.com
hcvone is offline   Reply With Quote
Old 02-23-2007, 03:46 PM   #15
Ruz
CF Senior Member
Eh...I was just busting your balls...
Old 02-23-2007, 04:26 PM   #16
mrosa65
CF Senior Member
mrosa65's Avatar
No Problem, I try to multi-task too much during the work day. I normally have my head set on talking to a customer or one of my engineers while playing on the internet.
Old 02-24-2007, 04:35 PM   #17
steveo242
CF Senior Member
steveo242's Avatar
Agree with above, go very thin and let it dry for a while. I do the whole car, and go do something for 1/2 hour.
The better you let it cure, the better the optics will be when you remove, and easier to remove.
Patience Daniel-son!!
steveo242 is offline   Reply With Quote
Reload this Page Zaino - Z2 Hard to Remove?
Tags
coats, hard, recommended, removal, remove, wipe, z2, zaino
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Polish War Rons2ndC5 Car Care Discussion 82 08-06-2005 10:11 PM
NXT vs. Zaino Z-Dreaming Car Care Discussion 57 07-02-2004 01:15 AM
NXT or Zaino? 5th Vette Car Care Discussion 21 04-12-2004 12:56 AM
NXT or Zaino........ dallasvette Car Care Discussion 60 03-29-2004 12:22 PM
Because of this Picture, I am goint to buy NXT today.... STRMLNE Car Care Discussion 34 03-24-2004 08:12 PM
Zaino and Pinnacle compared Aaron71771 Car Care Discussion 18 09-26-2003 10:42 PM
UPDATE: Zaino too "sterile" for Black C5 ThumbsUp Car Care Discussion 26 04-07-2002 08:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
