Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Zaino on plastic engine parts?
Old 11-26-2006, 04:09 PM
mkiv808
mkiv808's Avatar
Default Zaino on plastic engine parts?
Would this be worth doing? To help repel dust and make it easier to clean off dirt. I'm talking about applying it to a new engine bay too that's already immaculate. Or would it be a waste?
Old 11-26-2006, 04:27 PM
mrosa65
Support Corvetteforum!
mrosa65's Avatar
I've used Zaino tire gloss on many areas of my vehicles including hard black plastic items. It goes on easy, doesn't attract dust and dirt and gives my black plastic parts a satin finish. I'm not into the really glossy look.
It's also great for new parts since it contains a UV inhibitor, so it will help protect them from sun fading.
Old 11-26-2006, 04:38 PM
bldavis11
bldavis11's Avatar
Can it stand up to the high temps in the engine bay though?
Old 11-26-2006, 04:48 PM
mrosa65
mrosa65's Avatar
I used it under the hood before without any problems. I applied it to different pieces including the FRC's. For under hood use, I applied it lightly and then wiped it off with a fresh towel. As I mentioned already, I was going for a plain black satin look, nothing shiny or glossy.
I never tested how hot the rubber on my tires get. But having them exposed to the Florida sun and then driving long distances with friction from the road, I would bet they get fairly warm.
Just for grins I went outside and checked the black plastic trim on my truck. Keep in mind that the sun is setting pretty well at this point and the outside air temperature here is 71 degrees. Using a infrared temp gauge, it was reading 104.6. I'm sure during the heat of the day it's much hotter than that.
Give the Zaino tire gloss a try on a small area under the hood if you're concerned about how it will hold up.
Old 11-27-2006, 08:36 AM
Kevin V
Kevin V's Avatar
This came up once a long time ago, but I believe the Z-2 and Z-5 hold up to almost 400*, if I recall correctly.
If anybody knows for sure, post up.
To Zaino on plastic engine parts?
Quick Reply: Zaino on plastic engine parts?
