Shiny stuff on the tires?
I was scanning the C6 ads in this forum yesterday and one of the advertisers had made a point of stating that he had never used the "shiny stuff" on the tires of his meticulously maintained car.
I am curious about this. What is the downside of treating the tires with products that make them shiny?
Any enlightenment on this?
I dont know honestly,, I always just thought it was oil... Though if it has alcohols and pentrating oils in the Tire Shine then that could compromise the tire..
I really wouldn't worry about it
My personal opinion is that it discolors the tires and makes the car look a little cheesey. Not to mention the "sling" factor. Therefore, I don't use it on my Corvette.
Actually I have noticed that.. It never did it on my camaro, but I used it on my Durango once and it turned the tires brown in the sunlight..
Sling factor was never a problem.. but then again i have a different body style than a vette.. So I dont notice it..
St. Jude Donor '06
I think tires look good with a very thin coat of armorall (or like type product), but not drenched in it. Just enough to make the tire colors look even and dark.
Try the new DuPont Teflon Tire Shine. I used it and it offeres a happy medium between the really shiny products and the stock new tire look. As with any tire shine, clean the tire before you apply and it helps reduce with the buildup and "sling" I switched to this product when I sold my 92 and got my 00 and I've received a lot of compliments about it. But of course, it is a vette and everyone comments on them!
MONARTOR
Stoners makes a great tire shine.. makes em look new, not slick and doesn't sling with the tire prep first..SG works great
Originally Posted by jschindler
I've been using "stuff" on my tires since before many people on this forum were born. I have found why some tires turn brown. It's because the tires were not washed before they were treated. A 50/50 mix of simple green and water will take the tire back to their natural state, then treat them. I think you will find this really works.
Scrub them very clean.
Then I apply zaino Z-16 with a foam tire swipe. You can kind of work it in with the tire swipe. If you want more gloss try another coat.
It will not sling.
It will not turn your tires brown.
It will last.
It will not sling.
It will last.
Proper tire care is his issue.
I only apply a dressing to my tires about once very 4 to 6 weeks. I wash them at every wash, using a brush, and make sure I completely blow them dry. That is the biggest help. If you blow them dry, you don't get the fading of the dressing over time. No matter what dressing I choose to use, I let it sit for 30 minutes and then wipe the tire down with a clean, dry towel. No sling issues and no rediculous shine issues.
Todd
Todd
About 7 years ago I was at a major tire store chain talking with a salesman and he told me that by using Armorall (popular at the time) you were weakening the strength of the rubber and prematurely causing dry rot.
These were high mileage tires and I was having warrenty concerns
I didn't listen to him but I think this relates to the first thread
Location: Ponte Vedra Beach / London State: Dazed and confused
The most important thing you can do to protect the durability of vehicle tyres is to endure they are clean. For any type of protect ant to work well on rubber first remove any brake dust, road tar, grease and grime, wax and dead rubber from the surface to properly clean it. 3M Tire and Wheel cleaner quickly and safely clean the rubber tyres and helps tyre dressing and / or UVR protection (303™ Aerospace Protectant) durability. .
Leaving tyres rubber surfaces with a brilliant shine, cleaning the toughest scuffs and soil from sidewalls
Tyre Dressings:
a)Water based dressings- (usually a milky-white liquid) does not contain silicone oils, petroleum distillates, waxes, or solvents that can harm rubber and / or vinyl over time. Most water-based dressings use a combination of natural oils and polymers to offer a non-greasy, satin finish. Most of these products also contain UV blocking agents to help keep tires from cracking, fading and hardening. Most, if not all water-based dressings are biodegradable, whereas silicone is not. (Zaino Z-16 Perfect Tire Gloss™, also contains UV Radiation protection)
b)Silicone-based dressings- (usually a clear greasy liquid) that do not contain UV radiation protection and contain petroleum distillates as a cleaning agent. The difference is in the carrier system used. Solvent based products use a hydrocarbon solvent to suspend the product. When you apply it, the solvent evaporates leaving the dressing's active ingredients (Silicone oil) behind; this type of silicone is also not biodegradable. (Eagle One® Tire Shine Spray & Gel)
c)Application- spray a little dressing on sponge/applicator, spread evenly across the tyre surface, remove excess dressing and allow to dry before using the vehicle, if you prefer a matt finish wipe tyre with a cloth
Knowledge - [We know a subject] [We know where to find information on it] the most highly valued; [knowledge that is both held and shared]
Originally Posted by TOGWT
Tyre Cleaner:
Tyre Dressings:
Tyre Dressings:
