Why is my Black Z06.......... Now Silver looking???
Guess the title says it all. Has anyone else every seen this? I read on Autopia that sometimes synthetics can sometimes cause this. Was this just a boo boo in my detail job? Or is it cause of the wax I used???
This is what was done.........
1.Washed with Gold Class and Meguiar's Chenille mit.
2.Meg's professional mild clay with Quick Detailer for lube.
3.#83 via the Rotary
4.#80 via the Rotary X 2
5.#80 via the DA
6.#9 via the DA
7. NXT via the DA X 2
And this is what I see now
[IMG][/IMG]
Now, the detail did make it look GREAT!!!
5.#80 via the DA
6.#9 via the DA
[IMG][/IMG]
Are you referring to the milky look? Sometimes black will look like this. I prefer to use Z5 Pro on my black Z06 since I feel it makes it look blacker than some other products I have tried. How does it look in different light or under flourescents? What pads did you use for your final buff?
In different light, ie shade or any kind of flourescent it looks GREAT!
Pads...... unsure, I believe they were all the Meguiars foam type, not sure, cause I didn't do it.
I've seen this plenty of times and the only thing I can come up with is you're seeing how sunlight reflects off the clearcoat. The fact that other light sources do not create the same effect tells me its not a paint flaw or a poor quality spray job. And the detail job looks terrific.
The clearcoat seems to be diffusing sunlight in an unusual way. It's just a thought but there seems to be some connection between the sun and the clearcoat.
I dunno.... that's my thoughts. I'd be interested in what others think.
The product you choose may help this a little bit but it is pretty much the nature of the beast with clearcoated black.
On my black car, Z5Pro and Z2Pro both look fantastic, and deepen and darken the black. I've never seen this milky look.
I've not used it myself, but Pinnacle Souveran also looks great on black - see Killrwheels' Vette.
I guess my plan would be to attack a small test patch : 2' X 2' area. See if you can make it look any different than the milky look of the rest of the car:
But there are still some things you could try to darken the look:
after that, you can give up The car really does look great overall.
- hit it with rotary 1500 rpms, 3M 39002 and Meguiars polishing pad
- then PC with 39009 and white pad at 4
- Then wipe off with alcohol and inspect to see if the finish looks any better.
- try a glaze - 3M imperial hand glaze followed by #26 carnauba or even NXT will deepen my red and black car finish.
- Try other sealants mentioned above: Pinnacle, Zaino are probably a guarantee that you're getting the deepest darkest black possible.
I'd agree that something is diffusing the color refelcting back through the clearcoat. The paint color itself wasnt' harmed because there is still clearcoat protecting it. I'd try washing with dawn again and starting over, but no buffing this time. Now I'm curious too.
I notice a like effect on my black 91. The black was turing a light gray. I ues Pinnacle paint cleaner now and the oils always get it back to a nice black color.
I know the 3m swirl remover will get out swirls - but it leaves super fine scratches. When the sun hits them right it will make the car look less black. The Pinnacle stuff seems to cover it well.
5.#80 via the DA
6.#9 via the DA
[IMG][/IMG]
5.#80 via the DA
6.#9 via the DA
[IMG][/IMG]
I use those halogen shop lights you see at Home Depot in my garage. On my black cars, when you shine the light directly into the paint, this is EXACTLY what black paint looks like. I see this same look at every stage of prep work, also, so it is not a function of the sealant/polish/wax. I just completed a orange peel reduction on my black truck and after the first compounding step, the reflection looked just like that(although, it had compound swirl). I have also worked on high end vehicles with custom black paint, and this is the same. Lacquer(sp??) seems to be the clearest, but that is on show car only type paint work.
Under all other lighting conditions, the black looks super deep/wet/shiney with no hint of this 'milky' look. My bet is the clear coat has something to do with it. High solids clear coats seem to be the point at which this became very noticable.
Todd
Todd
Originally Posted by Joe C
i think what you're seeing is micro marring in the clear coat. what type of pads/bonnets did you use with your machines?
Todd
Todd
TY Both............. Keep them coming, I have my own PC (DA) with all 3 Meguiers pads and #80 Polish coming Thursday.
All of the Meguiers pads were used. I believe just the Polishing pads followed by finishing pads. Is that correct?
K, You have me all confused, maybe it's too early. At first it sounded like you were saying the look was correct in your first paragraph. But then in your second it sounds like you are saying the look isn't correct.
when you said you used a polishing pad, was it yellow or maroon in color? my suggestion is a fine cut cleaner/yellow pad. it might take a couple passes. you may have to work at it, and make sure you're polishing long enough to break down compound. follow with a swirl remover/yellow pad, and a machine glaze/tan pad. what speed setting are you using on the PC and rotary?
TY
TY
Todd
Sorry. My second paragraph was to emphasize that the black may look like your picture in absolute direct light from a certain angle, but in reality the paint still looks extremely deep/wet/shiney. I absolutely stand by the fact all modern black paints look this way when viewed with direct light and do not believe you have any issues with micro-marring or pads. Like I mentioned, I have dealt with my own black vehicles(I have owned at least 10 than I can think of right now) and they have all looked this way in direct light for the last decade or more. I have two black vehicles in the garage right now, beautifully detailed, get comments on how incredibly deep the black looks, and yet I can take my 500watt shop lamp and peer directly into the surface and see exactly what you are showing in that picture.
Todd
Todd
Ah, that makes more sense now!!! TY! I think I will take that to heart sounds like you have seen it once or twice. That's what I was looking for someone who has black, has seen this....... I will still try to clean it up some, still not 100% perfect......lol
Anyone have/seen the same thing and possibly dis-agree???? I myself don't know.......
TY
TY
TY
Todd
5.#80 via the DA
6.#9 via the DA
[IMG][/IMG]
5.#80 via the DA
6.#9 via the DA
[IMG][/IMG]
Did you not see this before? The way you phrase the question it seems like this only happened after the detail...
To be honest, I am not 100% sure........... seeing as how I didn't have the car but a week or so....... I don't believe it was that way before, but then again, maybe I wasn't looking at it close enough before the detail. I do have some before pics that don't look at "milky" but I honestly can't remember how much sun was out when I took them.
there all like that. any black c5 ive ever seen in direct sunlight made the paint appear lighter but any other light/condition and the cars deep deep black. bugs the hell out of me but i live with it.
Well, I have now had a couple people say that it's normal, others just gave advise of how to fix it, but no one has said they've had a black car with this and fixed it.......... so I think the general concensious is............ that's how it is.
TY
JOE
TY
JOE
