Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-02-2006, 11:36 PM   #1
LMB-Z
CF Senior Member
LMB-Z's Avatar
Default wax on...wax off
can anyone please tell me about using a clay bar? In all my years, I have never even seen one, let alone used one. I'm trying to get the best shine for the bucks without spending hundreds on car wax. Any tips would be greatly appreciated.
LMB-Z is offline   Reply With Quote
Old 10-02-2006, 11:39 PM   #2
ALLEGRO
CF Senior Member
ALLEGRO's Avatar
I used one for the first time in April as the result of spill paint on the road YUK
You will be amazed at the result. Takes very little time or effort and the smoothness and brilliance will be amazing.
I used Mother's but there are many to choose from.
Post pics when you are finished.
__________________
2003 50th ANNIVERSARY EDITION
CLICK PICTURES TO ENLARGE
ALLEGRO is online now   Reply With Quote
Old 10-02-2006, 11:57 PM   #3
djengr
CF Senior Member
djengr's Avatar
I bought a kit with clay bar and spray from autozone. You just spray and area and rub the clay till smooth, or till it starts draging. Fold the clay over and move on. After claying the entire body, I followed with a carnuba wax. At first I did not think my paint could get any smother, but the clay made significant difference in the feel of the paint.
djengr is offline   Reply With Quote
Old 10-03-2006, 12:38 AM   #4
Cozmo
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12
Cozmo's Avatar
1. Wash the car with Dawn dish soap to remove the previous wax.
2. Mix some good war wash with water in a spray bottle. Work the clay bar all around keeping the surface wet and slippery. The clay bar will pull all of the embedded impurities from the paint.
3. Wash again.
4. Use scratch and swirl remover if needed.
4. Wax with your choice of products. I prefer Zaino.
Good luck and post some pics.
Cozmo is offline   Reply With Quote
Old 10-03-2006, 12:44 AM   #5
b98
CF Senior Member
3. Wash again.
thanks 4 the info.
b98 is offline   Reply With Quote
Old 10-03-2006, 01:03 AM   #6
yaknow
CF Senior Member
yaknow's Avatar
3. Wash again.
ya what he said
yaknow is offline   Reply With Quote
Old 10-03-2006, 01:42 AM   #7
PierEagle
CF Senior Member
Advance Auto (and others) have Mother's Claybar Package, which includes the bar, a bottle of detailer spray and wax. I understand how to use it and the results it produces. Can anyone explain though how, technically, it is able to get the impurities that that a good cleaner wax, etc., doesn't, especially when you are adding a slip agent to it, i.e., detailer spray, soap spray or whatever.
Thanks.
PierEagle is offline   Reply With Quote
Old 10-03-2006, 01:44 AM   #8
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
3. Wash again.
I used a clay bar on mine earlier this year for the first time. Amazing how smooth the paint can feel after getting all the impurities off the surface.
Vetteman Jack is offline   Reply With Quote
Old 10-03-2006, 02:11 AM   #9
GrayC5
CF Senior Member
GrayC5's Avatar
Also, check out the Car Care Discussion section of the Forum. Several very knowlegeable people and a few profession detailers hang out in that section and you find lots of good info there.
Good luck with the car.
GrayC5 is offline   Reply With Quote
Old 10-03-2006, 02:20 AM   #10
Delta3-2
CF Senior Member
Delta3-2's Avatar
Quote:
Tips, clay bar usage, etc., ? Go here: www.meguiars.com
You'll find out all you need to know at the above website.
Good luck....if you do the process you'll spend all of 20+ hours detailing your Vette.
DG
Delta3-2 is offline   Reply With Quote
Old 10-03-2006, 09:48 AM   #11
Tom/99
CF Senior Member
Tom/99's Avatar
3. Wash again.
How do you get the Dawn dishwashing soap to remove wax? I've tried, and it just don't do it. Thanks!
Tom/99 is offline   Reply With Quote
Old 10-03-2006, 09:54 AM   #12
JCGRCYA
CF Senior Member
St. Jude Donor '06
JCGRCYA's Avatar
Here is a video from Adam's Polishes website.
http://www.adamspolishes.com/videos/clay_bar.cfm
JCGRCYA is offline   Reply With Quote
Old 10-03-2006, 10:30 AM   #13
easyrider13
CF Senior Member
easyrider13's Avatar
[quote=djengr] You just spray and area and rub the clay till smooth, or till it starts draging. QUOTE]
The clay should glide fairly smoothly on the surpace of your paint. You DON'T want the clay to drag. Keep the surface well lubricated.
Also, keep the Dawn in your sink, or for very occasional uses on your car. It is no friend of your "rubber" seals.
If you clay your car, you will remove most of your sealant, and if you polish it you will remove it all.
easyrider13 is offline   Reply With Quote
Old 10-03-2006, 02:03 PM   #14
bighank
CF Senior Member
Default clay bar hairline scratches
How do you remove the hairline scratches or swirls. Do you use something like scratch x after clay barring the car or what.
Don't want to ruin the clearcoat finish.
bighank is offline   Reply With Quote
Old 10-03-2006, 03:11 PM   #15
mrosa65
CF Senior Member
Support Corvetteforum!
mrosa65's Avatar
After I finish with the clay, I inspect for fine scratches. If I find some, I use my Porter Cable RO buffer and some mild scratch and swirl remover on them.
mrosa65 is offline   Reply With Quote
Old 10-03-2006, 05:00 PM   #16
TH0001@properautocare.com
Supporting Vendor
TH0001@properautocare.com's Avatar
1) Don't use Dawn, there is no need. The clay with remove any wax or sealent on the paint.
2) Clay doesn't pull anything off the surface. It acts as a very fine sandpaper to abrade away the contaminets while floating on lube.
3) Follow with your favorite wax/sealent.
TH0001@properautocare.com is offline   Reply With Quote
Old 10-03-2006, 06:22 PM   #17
ZaneO
CF Senior Member
ZaneO's Avatar
Quote:
I don't necessarily agree with this. The contaminants "stick" to the clay and the clay pulls them away.
__________________
Zane Oliver
ZaneO is offline   Reply With Quote
Old 10-03-2006, 08:28 PM   #18
58Vette65
CF Senior Member
58Vette65's Avatar
This is probably the best thread I have seen on how clay works!
http://autopia.org/forum/showthread.php?t=59294
58Vette65 is offline   Reply With Quote
Old 10-03-2006, 08:48 PM   #19
Supporting Vendor
Quote:
It doesn't pull the contaminents from the surface like a tweaser pulling out a splinter is what I meant. Yes, contaminents will stick to the clay however.
Old 10-04-2006, 01:04 AM   #20
PierEagle
CF Senior Member
Thanks for the link. That is exactly the explanation I was looking for.
Previously I kept hearing "I dunno but it works". Thanks again
Reload this Page wax on...wax off
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ordered C6 today--suggestions on colors? Corvette50 C6 Corvette General Discussion 43 10-11-2004 10:30 PM
Need quick opinions on wax...just clay-barred Southern Comfort C4 General Discussion 22 08-10-2004 02:17 AM
need advice on wax quick99ls1 Car Care Discussion 19 02-29-2004 11:03 PM
Opinions on wax/car covers ewrobo C4 General Discussion 21 07-10-2003 11:41 PM
(CF Tour) Wax on Wax off Desertdawg Car Care Discussion 15 07-09-2003 07:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
