i have a couple of area that look like the clear coat has be damages or spotted, they are about the size of a quarter the biggest area is on the back seem to be a 2"x3" area. the car in mag-red can't see the problem area unless you look at them at a certain angle. any way to fix this with out a repaint.
thanks
What type of damage? any pics? If it is just on the surface of the cc it can usually be fixed by buffing or even sanding and buffing but if it is something like thin or failing cc repaint is usually the only fix.
Try what I mentioned above starting with the least aggressive method. Try something like 3M 39009 or Zaino Fusion if you have it. Do it by hand first, then step up to a machine like a ROB if by hand doesn't work. If the ROB does not work I would step up to a Rotary and then finally a quick wet sand with 3000 and repolish to a shine if all else fails. You need to be careful that it is not so deep or you don't remove too much clear coat or you could have bigger problems. You could also try a more aggresive polish like 3m 39002 or Menzerna IP if the mild ones mentioned above don't work before going to the wet sanding step which is very aggressive.
yes - please post up a pic when you get home and have a chance.
really difficult to say much further without a pic to help.
All agentf1 said is of course correct, but if your problem is, in fact, areas of clearcoat failure then you can skip it all and go right to the paint shop.
I am sorry I try to add the picture, but the attached button keeps asking for a url. I thought that I was knowledgeable about this stuff . But this has throne me for a loop. How do people attached picture to the forum I look under FAQ but couldn’t find any thing .
Help
thanks
What year is your car, what kind of products have you been using?
Goose
Help
go to a site like Photobucket.com and upload your pics to that site. Then, in your post simply copy the IMG file and paste it into your post. You will see what I mean when you get to Photobucket. Each pic you upload will automatically be assigned the appropriate coding. You can even resize your pics on there to fit better in the post.
what iam doing wrong, how do i get the picture to come up in the post
help
Some sites won't allow you to direct link to the pictures. From what I can tell you copied the address from your browser address line then inserted it into the post by using the "insert image" tool in the posting window.
