Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-25-2006, 02:49 PM   #1
Son93SL2
CF Senior Member
Son93SL2's Avatar
Default Using the Porter Cable buffer
I am considering buying the Porter Cable buffer, the only wax/polish I currently use is MacGuires NXT Polish. Can I just use that or do I need to use a different products?
Son93SL2 is offline   Reply With Quote
Old 09-25-2006, 02:57 PM   #2
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
You can use NXT with your PC without any problems.
You may also want to pick up a good Scratch and Swirl remover to use with it, there are tons of good ones on the market. Do a search on here and see which one sounds like it wll work for you. A few brands that I like are 3M, Menzerna and Zaino.
agentf1 is online now   Reply With Quote
Old 09-25-2006, 03:29 PM   #3
JoshVette
CF Senior Member
JoshVette's Avatar
I use it with NXT all the time, just make sure you're using a good white or black pad and not a yellow or orange pad to put it on with.
Might look into Meg's step process.
Paint Cleaner (orange pad)
Polish (white pad)
NXT (white or black pad)
I'd claybar it first too for premium results. You'll be happy you did.
JoshVette is offline   Reply With Quote
Old 09-25-2006, 07:36 PM   #4
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
You can use the PC with NXT as it has calcified kaolin and is a light cleaner. You will get more from your PC by moving to dedicated polishes however. Consider a line of polishes (XMT, Poorboys, Clearkote) that will work well with NXT and help to bring your finish to the next level.
http://www.autogeek.net/po.html
As offered above, the proper prep of your finish will make a dramatic finish (pun) to your car. Consider the basics ....
Wash ---- Clay ---- Polish ---- Protect
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 09-26-2006, 06:32 AM   #5
bugman
CF Senior Member
Support Corvetteforum!
bugman's Avatar
wouldn't waste money getting a PC to apply NXT.
it goes on so easy by hand that you'll gain nothing by using a machine, except wasting a lot of product that just soaks into the pads.
Use the foam hand applicator that comes with the product.
Likewise with removal of NXT, you'll find that it's more trouble to take out the PC, put on a pad, and plug it in, than it is just to wipe off the NXT with a towel.
I say don't waste your money on a PC unless you REALLY mean to remove scratches, swirls, --- and in that case you're not going to accomplish that with NXT , you'd need abrasive products that are mentioned above.
bugman is offline   Reply With Quote
Reload this Page Using the Porter Cable buffer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Considering a Porter Cable - need advice gwayne Car Care Discussion 26 07-13-2005 11:08 AM
A Bit Confused w/ the Porter Cable??? gtoformula400 Car Care Discussion 9 07-12-2005 03:19 PM
Porter Cable with Mequire's Gold Class/ CJS Car Care Discussion 9 05-26-2004 09:07 PM
New Car + Porter Cable + Yellow Pad = Paint on Pad and Towel?!? PeteyPete Car Care Discussion 11 10-01-2003 08:58 PM
Porter Cable Orbital Buffer mikejaeggi Car Care Discussion 22 07-20-2003 03:51 PM
Porter-Cable vs. Cheap random orbital buffer ?? UFLS1Vette Car Care Discussion 13 06-19-2003 07:35 AM
Porter Cable polisher Grendel Car Care Discussion 10 12-14-2001 10:25 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
