Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-25-2006, 02:03 PM   #1
JoshVette
CF Senior Member
JoshVette's Avatar
Default I Like Rejex, My Write-Up
I detailed two silver Vettes this weekend, one an 06 Z06 with 2,000 miles and the other an 05 coupe with about 11,000 miles.
It is a Polymer wax and goes on easy and wipes off even easier.
First wipe I didn't think it came off so I kept wiping, but the owner told me that's the way it works, you wipe it on and it stays one and you barely have anything to wipe off.
There was quite a bit of static wiping it off, so I shot some Z8 on it and no more static.
I like it alot, I was using NXT which I love, but RejeX is easier to wipe off.
Can't speek of it's durability as it's my first time using it.
My prep was on the 06 Silver Z06
Dawn Wash
Claybar
Megs Polish with White pad
Z6
RejeX
Z8
Prep on 05 Silver Coupe
Dawn Wash
Claybar
Meg's Paint Cleaner with Orange pad
Z6
RejeX
Z8
Sorry, no pics now, besides I don't thinks pics are an accurate way to determine if a polish or wax is good or not as the lighting makes a big difference as do the surrounding environments, but will get some up later, the reflections were incredible for silver cars, plus scenery helped out.
JoshVette is offline   Reply With Quote
Old 09-25-2006, 03:00 PM   #2
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
You will get much better durability out of it than you did the NXT.
agentf1 is offline   Reply With Quote
Old 09-25-2006, 03:08 PM   #3
JoshVette
CF Senior Member
JoshVette's Avatar
Quote:
I've used NXT on all my DD cars. I've been real happy with it, but I'll have to throw some RejeX on them now and see how it fairs.
Other than Zaino, anyone know which is the next most dureable.............oops, isn't that the forbidden question??
I may just have to convert.
If I had a choice, I'd do the RejeX, let it sit a couple days, take it out wash it again with no Dawn and ReRejeX it. I bet a double coat of that stuff is wicked.
Old 09-25-2006, 03:19 PM   #4
Crusher
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10
Support Corvetteforum!
Crusher's Avatar
You won't get true results of the durability of Rejex as you used both Z-6 and Z-8 along with Rejex.
Crusher is offline   Reply With Quote
Old 09-25-2006, 03:25 PM   #5
LS WON
CF Senior Member
LS WON's Avatar
I have used it for my windshield and all windows in C-6. I still have water spots or marks from the windshield wipers. I can see a dried up film of water.
LS WON is offline   Reply With Quote
Old 09-25-2006, 03:31 PM   #6
JoshVette
CF Senior Member
JoshVette's Avatar
Quote:
How come??
Old 09-25-2006, 03:40 PM   #7
Crusher
NCM Ambassador
Cruise-In V Veteran
Crusher's Avatar
Quote:
Originally Posted by JoshVette
How come??
Because Z-8 is a spray seal that contains a polymer in it that extends the durability. If you are truly interested in the durability of Rejex then just use Rejex with no other product.
Old 09-25-2006, 04:14 PM   #8
JoshVette
CF Senior Member
JoshVette's Avatar
I got it. I thought maybe it wouldn't bond as well with the Z6 inbetween and the Z8 to finish it.
So it should hold up even longer then if I read you correctly.
Owner should like that better then.
Old 09-25-2006, 04:18 PM   #9
Guitarstar
CF Senior Member
Guitarstar's Avatar
Quote:
Rejex gives me crystal clear glass.
It also reduces friction of the glass going up or down.
I also use it on my NAV screen & all tinted glass.
Rejex is the best product I have used.
Guitarstar is offline   Reply With Quote
Old 09-25-2006, 04:38 PM   #10
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
Zaino seems to have the best durability for me. I would say products like Klasse and Rejex are also towards the top of the list as far as durability goes. I also found that sealants like NXT and Tropicare are at the bottom of that list or the least durable. JMHO.
Old 09-25-2006, 04:42 PM   #11
Crusher
NCM Ambassador
Cruise-In V Veteran
Crusher's Avatar
No, it won't last as long. Z-8 adds durability. So if you don't use Z-8 it won't last as long.
As far as Z-6 being your base coat and then Rejex on top of that? I have no idea how that effects the durability or shine of Rejex. Again, to get true results, Rejex should be used alone and not with any other product.
Old 09-25-2006, 04:50 PM   #12
LS WON
CF Senior Member
LS WON's Avatar
Better than Rain X for the windows?
Old 09-25-2006, 04:58 PM   #13
JoshVette
CF Senior Member
JoshVette's Avatar
That's what I did. I used the Z8 after I RejeX'd it. So it should hold up longer.
I will say with the process I used I don't think I've seen a more reflectant Silver car. I could see clearly from a distance a green bush in the side of the door. OOooooooohhh I'll just have to get some pics up. You'll see what I mean. Maybe the Z6 inbetween and Z8 to finish were valuable in this case.
Old 09-25-2006, 05:40 PM   #14
Z06-Goose
CF Senior Member
Z06-Goose's Avatar
Dawn Wash
Claybar
Z6
RejeX
Z8
Dawn Wash
Claybar
Z6
RejeX
Z8
Josh, nice write up. To answer your question on the durability of RejeX, you can count on at least 4-6 months out of a single application, and a lot longer if your car is garaged. I did a durability test, and I went almost 3.5 months until I decided to stop the test -which was still easily good for another month or more- and re-apply another coat. I've been driving my car a lot during the Summer and no garage, and needless to say, it has been exposed to the elements, and the product held up real well. I didn't use any QD to enhance shine or durability since that would also affect the integrity of the test, as it has been mentioned above.
A friend of mine gave me a good size sample of Adams DS and I've been using it on the hood. This is the only QD I've used so far. I hear FK-425 is also a good QD as it is Werkstatt Dura Glos, I believe it's called. It's just a matter of finding a good QD comparable to Rejex. I see nothing wrong with using Z6 or Z8 if that's giving you good results. Again, the durability of RejeX is up there with the best of them.
Good luck
Goose
Z06-Goose is offline   Reply With Quote
Old 09-25-2006, 06:24 PM   #15
Crusher
NCM Ambassador
Cruise-In V Veteran
Crusher's Avatar
So are you saying that you used Z-6 and Z-8 to add durability and added gloss to Rejex?
Old 09-25-2006, 06:28 PM   #16
LS WON
CF Senior Member
LS WON's Avatar
Rejex is a stand alone product all is needed is using this one product. Less work more durability.
Old 09-25-2006, 06:50 PM   #17
JoshVette
CF Senior Member
JoshVette's Avatar
Read my process at the top and you'll see exactly what I did.
I'm about to add some pics, so stay tuned. There were a lot of trees, so the reflections are crazy........
Old 09-25-2006, 07:50 PM   #18
Crusher
NCM Ambassador
Cruise-In V Veteran
Crusher's Avatar
After reading the Rejex instructions from their website I'm not sure I would have done what you did......I like to follow the manufactures instructions as I'm sure they know their product the best......I didn't see where you said you waited the required 12 hours for Rejex to cure......But, if your happy with the outcome, that's all that matters........Here is what they say....
Curing is required to allow the monomers (polymer building blocks) that make up RejeX to attach to the surface being treated and to polymerize (cross link) into a crystal-clear, impervious film. It is very important to allow RejeX to cure for 12 hours after the haze has been wiped off. If the coating is exposed to contamination such as oil, fuel, soot, water, cleaners, etc. before it has cured, the contaminants may interfere with the film, preventing the RejeX from achieving it's maximum performance and durability.
Old 09-25-2006, 08:19 PM   #19
easyrider13
CF Senior Member
easyrider13's Avatar
For a fair test, I'd skip the Z-6 and wait 24 hours before applying a QD.
easyrider13 is offline   Reply With Quote
Old 09-25-2006, 08:44 PM   #20
JoshVette
CF Senior Member
JoshVette's Avatar
Both owners and myself were aware of this. I'm holding a bottle in my hand and it says not to apply any polish's or wax's over the RejeX as the abrasives may take the RejeX off.
Also to let set out of sunlight and elements for 12 hours so that it can cure without any contamintation attaching itself.
I don't believe the Z6 or Z8 was "bad" for the RejeX, if anything it was good for it. After 5 hours of sitting (while I finished the second car) there were absolutely no negative affects on the finish of the first car.
Reload this Page I Like Rejex, My Write-Up
Tags
durability, rejex
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
