Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-25-2006, 03:06 AM   #1
LS WON
CF Senior Member
LS WON's Avatar
Default Mother's Polishing Ball
How good are those Mother's Polishing Balls for cleaning off wheels for brake dust? This item costs 18.00 at Walmart and is like a red ball sponge. You attach it to your drill to make it spin.
LS WON is offline   Reply With Quote
Old 09-25-2006, 08:34 AM   #2
BostonJoel
CF Senior Member
BostonJoel's Avatar
I bought the small one at a car show recently. Waste of Money. I can polish the Corvette chromies just a well manually. The ball does not get into all the corners as advertised...you still have to use your polishing cloth...so why bother with it. I tried to clean it using hot water...but the dirt would not come off.
__________________
2011 Crystal Red Metallic Grand Sport convertible, cashmere int, beige top,LS3,3LT, F55, A6 Paddles, Chromies, NAV, NPP w/controller,V-1, Lloyd mats
NCM Member #8206
Other cars:
2007 Nissan Maxima SE- Daily Driver (his)
2012 Nissan Maxima SV- Daily Driver (hers)
1986 Corvette Coupe (sold)
1994 Corvette Convertible (sold)
1999 Corvette Convertible (sold)
2008 Corvette Coupe (sold)
BostonJoel is offline   Reply With Quote
Old 09-25-2006, 09:51 AM   #3
JoshVette
CF Senior Member
JoshVette's Avatar
I just bought one also and am not impressed with it.
It is perfect however for cleaning up exhaust.
It is good if you have some HRE's for getting around and inbetween those little nuts that go around the perimiter of the rims.
JoshVette is offline   Reply With Quote
Old 09-25-2006, 10:47 AM   #4
gmblack3
CF Senior Member
gmblack3's Avatar
Brake dust should be cleaned off, not polished.
The mothers or any other "powerball" is going to work best on uncoated wheels.
I am sure your chrome wheels are coated.
gmblack3 is offline   Reply With Quote
Old 09-25-2006, 12:22 PM   #5
Crusher
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10
Support Corvetteforum!
Crusher's Avatar
I believe the power ball was mad to POLISH non-clear coated wheels using an abrasive cleaner. I used it on my aluminum wheels and it made them look like chrome. Each wheel took me about 5 minutes. I couldn't be happier with the results.
Wish I had taken before and after pictures because the difference was extremely noticeable.
If you had used the search function you would have found several previous threads about the power ball.....here is one...http://forums.corvetteforum.com/show...ght=power+ball
Crusher is offline   Reply With Quote
Old 09-25-2006, 01:46 PM   #6
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
Yes, I use my mini power ball all the time to polish my 76 Stingray wheels and even use it on my Lightning's exhaust. They work awesome for all your "polishing" needs.
agentf1 is offline   Reply With Quote
Old 09-25-2006, 03:20 PM   #7
LS WON
CF Senior Member
LS WON's Avatar
Quote:
How do you keep this Powerball clean when only using it for brake dust removal as these chemicals are pretty hard to get off because usually whatever I clean the brake dust off with like a rag I throw it away. Don't want to be throwing away Powerballs.
Old 09-25-2006, 03:23 PM   #8
LS WON
CF Senior Member
LS WON's Avatar
No chrome for me I have whatever came factory stock on a 2005 Corvette. Am I better off with rags as won't the brake dust eventually destroy the powerball? How do you keep powerball clean from brake dust?
Old 09-25-2006, 03:23 PM   #9
LS WON
CF Senior Member
LS WON's Avatar
This thread was more positive about the powerball.
Old 09-25-2006, 06:20 PM   #10
Stickman81
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10
Stickman81's Avatar
I bought the larger PowerBall specifically to do the inner portions of my Z06 Chromies, which is not clearcoated.
After washing the wheels, I used "Blue Magic Metal Polish" applied with a cloth to the barrel portion of the wheels. I ran the Powerball around a few times and it cleaned the wheels right up.
I just cleaned up the Powerball with soap and water.
Right side wheel is polished, left wheel is already washed, just not polished.
Click for the bigger pic.
Stickman81 is offline   Reply With Quote
Old 09-25-2006, 07:09 PM   #11
slolane
CF Senior Member
CI 7-8-9 Veteran
St. Jude Donor '07-'08
slolane's Avatar
I have the small one and I wrap a fine scotchbrite around it to clean and shine the inside of my Borla tips works great
__________________
[font=Arial]-Slolane ZULATER
My photos
http://forums.corvetteforum.com/album.php?u=165197
'06 z06
'02 Goldwing
slolane is offline   Reply With Quote
Old 09-25-2006, 07:11 PM   #12
LS WON
CF Senior Member
LS WON's Avatar
Quote:
How do you know if you have the large mother's powerball or the small powerball. I paid about $18.00 for mine at Walmart probably is the large powerball?
Old 09-25-2006, 08:26 PM   #13
easyrider13
CF Senior Member
easyrider13's Avatar
Quote:
Probably is the large Powerball. Walmart has lots of the big Mothers at $18 (a good price). I haven't seen the minis there.
easyrider13 is offline   Reply With Quote
Old 09-25-2006, 08:44 PM   #14
mrosa65
CF Senior Member
mrosa65's Avatar
Quote:
I bought mine at wallyworld also for $18 and it was the larger sized PB. I hope they get the mini PB sometime soon.
Edit-
I did a quick search and found the PB mini at advance auto for under 20 dollars which is a pretty good price.
mrosa65 is offline   Reply With Quote
Old 09-25-2006, 09:09 PM   #15
Stickman81
CF Senior Member
Stickman81's Avatar
The large Powerball is about six inches in diameter.
Old 09-26-2006, 06:24 AM   #16
bugman
CF Senior Member
bugman's Avatar
For anyone reading this - probably you do NOT want to buy the powerball that you'll find in kmart, walmart etc. -- this will always be the LARGE powerball, which is just too big to be used in the complicated patterns of many wheels. It is about 6" diameter. Just too big for any use on my motorcycle at all, which was what I bought it for.
Look for the mini- powerball. You'll get much better use out of this. I ordered from on on-line vendor - not hard to find with google.
bugman is offline   Reply With Quote
Old 09-26-2006, 02:15 PM   #17
LS WON
CF Senior Member
LS WON's Avatar
Then what is the large powerball used for?
Old 09-26-2006, 03:48 PM   #18
JoshVette
CF Senior Member
JoshVette's Avatar
Got mine at Pepboys, they had a big selection of the large and small powerballs.
Each were about $25.00 bucks though.......
Old 09-26-2006, 04:00 PM   #19
LS WON
CF Senior Member
LS WON's Avatar
Did you find them effective to clean whatever you use them for?
Old 09-26-2006, 07:05 PM   #20
2k2C5
CF Senior Member
2k2C5's Avatar
Autozone carries the large and small versions.
2k2C5 is offline   Reply With Quote
Reload this Page Mother's Polishing Ball
Tags
ball, cleaner, fl, good, mart, polish, polishing, power, powered, red, rim, vbulletin, wal, walmart, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
House of Bling! fig32 C5 General 25 06-04-2005 03:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
