Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-28-2006, 03:04 AM   #1
TH0001@properautocare.com
Supporting Vendor
TH0001@properautocare.com's Avatar
Default Forum member fastskylines Vette (detail in progress)
Here are some photos I have taken of forum member fastskyline's 05 Vette, which at the time of this thread is nearing completion. So far it has about 8 hours invested in it. This car was in much worse shape then I orginally thought (though no fault of fastskyline, this was preowned). After the intial washing and inspection with a Brinkman Dual Xenon swirlfinder, I was shocked to see that car was literally a road map of scratches. There was also a fine layer of oxidation, which when removed, revealed more scratches, swirls, and etched waterspots.
I was forunate to have this car for 2 1/2 days, so I could take my time on it and do it right
The detail started by washing the Corvette with the 2 bucket method w/ Meguiars Hyperwash dilluted 400:1, using two wash mitts... First I removed the license plate, then went to work...
I then clayed it using Meguiars Quik Detail Clay and Lasttouch Detail spray while the car was still wet. Afterwards I dryed with a couple Meguiars Water Magnet microfibers...
Then I used a Brinkman Dual Xexon light to get a better idea of the surface condition. It was pretty rough...
I started my rotary adventure with Meguiars DACP #83 on a foam 8006 pad, at about 1200 rpms. After a pass, the surface looked more scratched because when it cleaned up, the road map of scratches appeared. Argh...
This led me to go with Meg's #84 on a cutting pad, at 1800 RPM for the entire car. After this, I followed by a pass of Megs DACP on a 8006 pad, at 1200 rpm and finally #82 swirl free polish on a 8006 pad. Then, I polished then entire vehicle twice with the PC, once with DACP and then followed by #80 Speed Glaze.
Here is the resulting finish...
As you can see, its not perfect (mainly because a lot of those orginal scratches ran pretty deep) but its about 95% percent defect free, and a 100% improvement, IMO.
However, there was some deep scratching in certain areas of the hood that I wanted to see if I could could remove. In this first picture, the Xenon was going dead, but you can see the scratches, or atleast the pattern of the scratches...
TH0001@properautocare.com is offline   Reply With Quote
Old 07-28-2006, 03:05 AM   #2
Supporting Vendor
The picture really doesn't do it justice, so I decied to plug the Brinkman in and charge it. I busted on the big guns, going right to Meguiars #85 Diamond Cut with a wool pad and 2000 RPM's. I made two passes, and here is the results after the second pass. I had to use the flash of the camera, so its not a fair before and after, but it will give you an idea of getting worse before it gets better!!!
Then I made one pass with DACP/rotary/1400 RPMs and 1 pass with 80/rotary/1200 RPMS to remove the heavy swirling left from the aggresive cut and the wool...
After DACP
After 80...
Then I polished the area with 80 on the PC.
The rims where cleaned with Meguiars All Wheel Cleaner and then glazed with Meguiars #21 Synthetic Sealent. The tires where scrubed with Meguiars APC, then dressed with one coat of All Season Dressing and one coat of Hot Tire Shine...
Before...
After...
Here is a sneek peak of the Corvette now, in the full sun, over the scratched areas...
I will finish posting up some pictures tomarrow. The second coat of sealent is being allowed to set up overnight, before I put on some wax, wash the windows, and dress the trim. Then it will be done, and hopefully fastskyline will be happy
Old 07-28-2006, 08:05 AM   #3
easyrider13
CF Senior Member
easyrider13's Avatar
Nice work.
Which sealant are you using on the paint?
easyrider13 is offline   Reply With Quote
Old 07-28-2006, 09:05 AM   #4
Z06-Goose
CF Senior Member
Z06-Goose's Avatar
TH0001; good work again. I've seen some of the work you do, and they look like a pro!
Goose
Z06-Goose is offline   Reply With Quote
Old 07-28-2006, 10:31 AM   #5
fastskyline
CF Senior Member
fastskyline's Avatar
Send a message via AIM to fastskyline
ok todd...what did you do with MY car??? the one at the end looks too good to be mine! cant wait to see it today.
fastskyline is offline   Reply With Quote
Old 07-28-2006, 12:01 PM   #6
ZaneO
CF Senior Member
ZaneO's Avatar
Great turnaround!
__________________
Zane Oliver
ZaneO is offline   Reply With Quote
Old 07-28-2006, 01:16 PM   #7
Humanoid 2.0
CF Senior Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Humanoid 2.0's Avatar
Send a message via AIM to Humanoid 2.0
Good work, but dude, I hope you are not naked in this pic and buff in the buff
Humanoid 2.0 is offline   Reply With Quote
Old 07-28-2006, 01:46 PM   #8
Supporting Vendor
Okay here is the afters...
The morning started (I stayed up late, sealing the paint with 2 coats of Meguiars 21, followed by a coat of 26)
I used Meguiars Exterior Detailer on the plastic and rubber, on the right you can the untreated area, on the left is treated. Not a big difference, but a subtle, dark, satin shine. The Corsa exhaust was polished with Meguiars NXT All Metal Polysh.
Of course its cloudy today, so I could only get a couple sun shots, but here is a pethra of afters..
Here is the scratched area from the first post, in the sun...
Old 07-28-2006, 01:54 PM   #9
Supporting Vendor
I then put the plates back on it, and drove down the front of my neighborhood to try to get some beauty pictures and some reflections in the hood...
The name of my company is Tropical Detailing Excellence, and the sun happened to break right when I was setting up this picture. My new slogan "We can't predict the weather, but we guarantee the shine!"
Nothing is wetter then a tropical shine
Old 07-28-2006, 02:07 PM   #10
mrosa65
CF Senior Member
Support Corvetteforum!
mrosa65's Avatar
TH - Outstanding work.
Fast - I bet you want to smack the previous owner for letting the finish get in that type of condition.
mrosa65 is offline   Reply With Quote
Old 07-28-2006, 03:06 PM   #11
FIDOauto
CF Senior Member
FIDOauto's Avatar
great job but oh man its gonna be so hard to keep that up!!!
I'd give it 3 coats of Zaino right away to make sure it stays that way!!... I'm not taking away anything from TH's work cuz its exemplary but I dunno about the durability of Meguiars products
FIDOauto is offline   Reply With Quote
Old 07-28-2006, 03:48 PM   #12
KidCid
CF Senior Member
CI 7-8 Veteran
KidCid's Avatar
That is just outstanding work! Congrats to TH0001 for his great work and fastskyline for the great look.
KidCid is offline   Reply With Quote
Old 07-28-2006, 05:54 PM   #13
gmblack3
CF Senior Member
gmblack3's Avatar
Excellent work. I bet it looks even better in person.
gmblack3 is offline   Reply With Quote
Old 07-28-2006, 11:01 PM   #14
Supporting Vendor
Okay, some final afters (sensory overload)...
Old 07-29-2006, 01:14 AM   #15
bugman
CF Senior Member
bugman's Avatar
yeah - my thoughts exactly . That's what - an '05 or '06 -- how did the finish get that bad in only 1 to 2 years? must have left it under a sprinkler and polished with Brillo.
Well - fantastic job !
I've been in a Meguiar's Hot Shine mode for the past 4 months myself - it's an easy spray-on, gives a nice look, and good durability. Nice to see you using it also.
Thanks for the FANTASTIC writeup and all the effort you put into it to document the work with so many pictures !
bugman is offline   Reply With Quote
Old 07-29-2006, 01:50 AM   #16
Z06-Goose
CF Senior Member
Z06-Goose's Avatar
On a car like that, is well worth the time spent to do it right.
Awesome work.
-Goose
Old 07-29-2006, 04:09 AM   #17
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
great job as always.
DPG is offline   Reply With Quote
Old 07-29-2006, 09:05 AM   #18
Supporting Vendor
Quote:
Originally Posted by easyrider13
Nice work.
Meguiars #21 Synethic Sealent
Quote:
Thanks for the compliment . Meguiars #21 will give a solid three months of protection. I'm not touching the Z word
Quote:
Ummmm, I had a black C6 in the garage and the wife was away for the day, errrr nevermind
Old 07-29-2006, 09:07 AM   #19
Supporting Vendor
ps THANKS for all the compliments
Old 07-29-2006, 09:36 AM   #20
Crusher
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '04-'05-'08-'09-'10
Crusher's Avatar
Really great job. And they say Zaino is to complicated and time consuming..........LOL
Crusher is offline   Reply With Quote
Reload this Page Forum member fastskylines Vette (detail in progress)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
