Aagh! I parked near the grass at work today and the damn sprinklers came on (who has sprinklers running in the middle of the damn day?) and by the time I came out to my 01 Torch Red coupe that afternoon unaware the sprinklers would kick in I discovered a disaster. The water must be horrible because now my hood has hundreds of water stains that won't come out. I tried Mequires and Zaino polish to no effect and even Scratch-X barely made a dent in them. Any ideas on how to remove wickedly tough water spots from Corvette paint???!!!
Please refrain from the flamethrower jokes, I'm almost in tears as it is.
Try a soft cotton cloth with white vinegar on it. Let the vinegar sit on the stain for 20 seconds or so, wipe off and repeat. This has worked for me in the past.
It may be best to ask this of the folks over in the Car Care Discussion section of the Forum. Several very knowlegeable people and a few professional detailers hang out there. Too, this topic has been discussed there a number of times in the past. Good luck!
I had the same thing happen to me with my black one. It was almost like the water contained fertilizer or something. A cleaner/wax would not take them out. I had to wash it with Dawn soap and clay bar it to get it out. A couple of coats of Zaino's helped too.
Had similar problem water softner water drops that would come out of Zanio. Had to wash car with dawn dish soap to remove the Zanio. Then 3m swirl remover and random orgital polisher then rewax
White distilled vinegar and water soultion. The vinegar will disolve the hard water. Works like a champ. Then zaino the crap out of it.
Read my Story.... I FEEL your pain... But it can be fixed.. Here is my SAGA!!!!
I just worked a Grand Prix with a ton of water spots. I think I got out about 95% of them. I think it would have taken more passes, or a rotary to get the rest.
It may take more on the Vette than what I did below.
SSR 2.5 (x2) on Orange Propel pad with PC at 6 and moderate pressure.
Stickman !!! excellent results, and great job doing the picture like that - it's always helpful to mask off a section like that, or else you're not really sure if you're making progress
By the way: SSR = Poorboys polishes for those interested - you detail guys use so many abbreviations - just like the military.
Thanks bugman.
I should have spelled out the PB. I just finished up on another detail sight. Thanks for taking care of that.
Thanks bugman. I should have spelled out the PB. I just finished up on another detail sight. Thanks for taking care of that.
Hey dascar
How are you making out?
my own thoughts:
try meguiars scratch X with white pad and PC7424 setting of 5.5
if no effect, try it with an orange pad
then bump up to 3M #39002 with orange pad - guaranteed to work, setting 5 to 6
after 39002, you can use either Menzerna Final Polish II with a white pad, or 3M #39009, to put a final polish on the surface before applying your sealant.
I've actually never failed to get perfect results with 3M 39002 even when done by hand with a terry cloth towel. Pictures for you on my web page - click on SCRTCH/SPOT.
Hope all is well -- post back up here if you're still having trouble, or send me a pm or email.
Well, in my anger over this whole perma-waterspot thing, I ignored the safety warnings in my head and some great advice from you forum posters and went with Turtle Wax Rubbing Compound. I tested it on a grapefruit-sized area to find the water spots were finally gone and replaced instead with fine scratches from the product. So I followed up with lots of cursing as well as Turtle Wax Polishing Compound and Zaino and Scratch-X to pretty much hide the scratches. On the rest of the car, I used a tiny portion of the Rubbing Compound mixed with a generous portion of the Polishing Compound which seemed to do the trick. I still had to follow with Zaino and Scratch -X for the few light scratchy-swirly marks but its better than it was with just the spots. I was also quite impressed with a Caranuba Wax (Mothers) which not only smells good and goes on smooth but also leaves a killer shine.
The Carnuba just fills in the scratches.. But if you want them gone for good get a PC and some Menzerna IP... The scratches from Turtle wax are no worse than 2000 grit sandpaper and the IP takes those out perfectly..
