Urgent Help Needed - What did I do to my Vette?
Brand new Corvette with the upgraded chrome wheels.
Cleaned it today for the 1st time with the regular Zaino wash.
On the way home from work I stop by the AutoParts store and the salesperson recommends EagleOne Chrome wheel cleaner.
so I spray it on like the standard EagleOne wheel cleaner I've used without problems and hose it off.
Nobody bothered to tell me that it would bleach the calipers and the inner part of the rotors.
FAAARRRRRRRQQQQQQQ !!!!!!!!!!!!
Looks like I permanently spotted the finish on these items as I couldn't make a dent in it with water & elbow grease.
But I'm praying that someone has a solution (doubtful, I know).
Very truly bummed. Thankfully it's one of those things that only I, or someone looking very carefully, will ever notice.
Originally Posted by ZaneO
What does the label say?
Label says nothing aside from "For use on chrome & wire wheels."
I read it before using and would have avoided it like the plaque if it made any warnings about other finishes.
I'm hurtin' here...Don't have the heart or guts to tell the wife and am hoping she won't notice (which is highly likely)
notice the spotty bleach marks.
I got the caliper, inner rotor, and the brake mount arm.
Arrrggghhhhhh !!!!!!!!
Former Vendor
chrome wheel cleaner is very hard on paint and zinc coating, it appears that it etched into it, which likely means no easy repair. Wheels, calipers, rotors, and such must all be cool to the touch and in most instances a less aggressive wheel cleaner is warranted.
Unfortunately, that's about what I expected to hear.
It looks and feels permanent.
I'm not the type to replace expensive items like these because of cosmetic blemish which hopefully only i will notice. So now I'm off to drown my sorrows in a few beers.
Do you think the standard EagleOne wheel cleaner is safe to use? If not, please provide me with a better suggestion. I'm not going to cheap out.
i dont think that it "bleched" the calipers much less the metal behind it. IF that wheel cleaner is for chrome rims then why didnt it mess up your wheels?? I think if you remove the wheel and maybe polish it with some kind of metal polish like blue whatever it is or mothers polish that should come off. I know on my uncoated wheels when i would use the wheel cleaner it would make them white sometimes. That happenes a lot when you spray the wheel cleaner like that on hot surfaces. It would eventually come off using a little elbow grease and some metal polish..... i wouldnt worry too much about it.
BTW you dont have chrome wheels so i wouldnt use chrome wheel cleaner for polish coated wheels. Your best bet is to use soap and water and ocassionally (SP) polish them with some blue magic or mothers polish. good luck
Former Vendor
First of all you should smack the autoparts guy.. okay not really
Chrome is a very durable surface and most chrome wheel cleaners are fairly aggresive because the chrome can tolerate it. However, you wheels are clearcoated. They are chrome underneath, so I wouldn't even recommend chrome wheel cleaner on the wheels let alone anything else.
It looks like a chemical reaction occured and the results are pretty permenent. You might want to call Eagle One and see what they recommend. Clean your rims and place a quality sealent (don't use carnuba wax because it will melt off) on them and use soap and water to clean them of a very mild wheel cleaner. Sorry to hear about your bad luck, keep us informed.
Are you sure you have the chrome, they don't look like it from the photos.
I do not like EagleOne wheel cleaners. I got the one for clear coat wheels and it still stained. I use the pinnacle wheel gel, and have had no problems.
Good luck in fixing your issue.
I completely missed that...I was thrown off when you said, "upgraded chrome wheels." As said above, those wheels are clearcoated. You need to treat them like paint.
Why not just get the calipers powder coated or paint them. Mine are powder coated but many have good luck with painted calipers. The rotor could also be masked off and painted with high temp black to hide those marks. To me that's an easy DIY fix if you want to do some work....
yea just paint the calipers...it will look better than before. i have been using meg's hot wheels cleaner (neon pink bottle) for years and never had any sort of problem.
This is why I just Zaino my wheels and maintain them with just soap (Z7) and water.
Sorry to hear about that. You wanted to paint those calibers red anyway didn't you?
First of all - your wheels are not chrome. So you should not use products made for chrome.
You have the "high polished" wheels -- which are just aluminum that is (rather poorly) polished to a gloss, then clearcoated. So to clean them you should use nothing more or less than you use on the clearcoated paint of your car. -- regular car wash soap will do great for you.
Second - yes, you should take cthusker's advice.
if you're not familiar with the process, go to http://c6.81x.com
and click on "Calipers" -- plenty of pics to show you how to do it. Will cost you about $20.
before:
After:
for the black parts: Plasticote universal black engine enamel #203.
Just my opinion -- you'll definitely have to ditch those aluminum wheels eventually. Start looking into
- corvettes of houston - probably the best deal, or
- west coast corvettes
For some nice chrome wheels at about $1000 total - can't beat that!
Bugman....
Yeah !!!!!!!
Great stuff. I've always liked the look of the red or yellow calipers on Porsches and what-not. That will be my summer project and will make everything look better than new.
What did you use to cover the bolts & rotor?
Thanks man. Things are looking waaaay up.
Yeah !!!!!!!
Originally Posted by The Squeaky Wheel
Bugman....
Yeah !!!!!!!
Yeah !!!!!!!
