Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-13-2006, 05:37 PM   #1
Mike073048
CF Senior Member
Mike073048's Avatar
Default Scuff mark by rear taillight
I have a small scuff mark by my left rear taillights. I have a PC 7336sp and some Meguiars Scratch X. Is it worth it to try this combo or should I step up to something like Menzerna IP/FP to remove the scuff.
Mike073048 is offline   Reply With Quote
Old 03-13-2006, 05:53 PM   #2
agentf1
CF Senior Member
St. Jude Donor '10
agentf1's Avatar
I would give Zaino's plastic polish a try first. Or any good plastic polish should work.
A good swirl remover will probably work also but ScratchX is way too mild to do much of anything IMHO. Give one of the Menzerna polishes a try if you already have them.
agentf1 is offline   Reply With Quote
Old 03-13-2006, 06:34 PM   #3
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
Quote:
It sounds like the scuff mark is actually on the paint, just next to the tailiight correct ?? If so, following the logic of least abrasive polish first, and moving to more abrasive as only necessary, I would suggest ScatchX as a nice beginning point. If not, experiment with harsher polishes only as needed.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 03-13-2006, 07:35 PM   #4
easyrider13
CF Senior Member
easyrider13's Avatar
I've had success using a few drops of body solvent on the corner of a cloth before going to an abrasive product. Perhaps even tar remover might work. Be sure to re-wax/seal afterwards.
easyrider13 is offline   Reply With Quote
Old 03-13-2006, 07:37 PM   #5
bugman
CF Senior Member
Support Corvetteforum!
bugman's Avatar
no harm in trying scratchX, but my experience also is that it is WAY to mild to remove any scratching at all. If there is just a little paint transfer, or if you have very mild water spotting, it is good for that.
But now is the time to make you order for Menzerna IP and FP2, or whatever that numbered fancy product is that agentf1 is using . In all likelihood you'll need them for this project, and if not, you'll need them for other stuff ahead of you. No garage should be withou.
bugman is offline   Reply With Quote
Old 03-14-2006, 02:24 AM   #6
LS WON
CF Senior Member
LS WON's Avatar
Try some Liquid Glass Polish. See if the company will send you some free samples of this polish. They used to do this in the past.
LS WON is offline   Reply With Quote
Reload this Page Scuff mark by rear taillight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
