What is a good product to lube and protect weatherstripping?
I heard someplace it's bad to use silicone. Then I heard BMW sold the best stuff but I found out it costs $61 for a little tiny tube. Any suggestions?
The BMW stuff is silicone-based too. Silicone is bad for your paint (because it gives painters fits from fisheyes), and it's none too good for vinyl or leather either (it causes cracking), but for rubber, like weather stripping, it works great. Here's a pointer to the good stuff. I haven't searched, but I assume you can find it easily on the internet.
http://products3.3m.com/catalog/us/e...er/output_html
Keeps the stuff supple as new.
Now I'm told the stuff's expensive given the size of the tube, but what's there seems to last forever.
I use a great product called Shin-Etsu Grease (basically it is a white silicone grease) that can be purchased at a Honda dealer or you can buy it online at http://www.handa-accessories.com/s2000-03.html. It's the stuff Honda recommends for the convertible top seals on the S2000 and works well. If you get a little overzealous with it around the window seals, it can smear on the windows. Otherwise, it works well to preserve the weatherstripping, and it's cost is reasonable. A little goes a long way.
A little more info... what's 303?
It's a rubber/plastic protectant. It basically makes stuff look like new without a lot of extra shine and gives good UV protection.
There website has a search function to find sources near you, or you can mail order it. Please check forum vendors first.
I also use in on my wheels, I just wipe them down with it when I do my tires. Seems to work as good as regular wax or sealer on clearcoated or painted wheels if you wipe them down with it everytime you do your tires.
Originally Posted by Landru
My [certified] Corvette mechanic gave me a tube of GM (brand) Dielectric Silicone Grease, GM Part #12345579 for use on all my Corvette's weatherstripping.
Most silicone grease contains some fillers, it's not pure silicone. Which is fine, but won't last as well as pure silicone, which is expensive, but not that expensive - think $10-15 for a tube. Try O-ring lubricant from an industrial or plumbing supply place. And it only takes a tiny little bit.
Silicone is a pain to remove, but any good paint job should include a thorough cleaning. Silicone can be removed with a non-polarized solvent like isopropanol.
Personally, I think that 303 or Back to Black is a better (and less messy) alternative if you do it fairly often, say monthly.
Originally Posted by Army Vette
How often should this be applied to the weather stripping?
As for cleaning and protecting the rubber, opinions differ, I'd say anywhere from every month to every third month, or when it's looking sort of dry or you can get a little black smudge off of it by wiping it with a dry cloth.
DC-4 will work. $12 for a tube that will last a lifetime.
A VERY good silicone grease is available at your local scuba diving shop. They sell it in little plastic make-up containers for use on wetsuits. This stuff is very good, and easy on your hands and non-toxic. It's also cheap.
Apply once a year or as necessary.
When I worked for Grumman Aircraft we used Aerospace Protectant 303 on the interior consoles of the F-14's fighter jets. It works well on vinyl,rubber,plastic, fiberglass and leather. A little hard to come by. I ordered a spray bottle from my local Ace Hardware Store . About $12 a bottle. What's good for a $60 million jet should work well on a $60K Vette. I'm sure some of the forum care car suppliers can get it for you.
