Wetsanding a C6 Z06
Wetsanding a C6 Z06 (56k warning...)
I am currently helping a friend wet sand his black C6 Z06 corvette. I thought that some of you might enjoy seeing the pics. It was sanded with 2000 grit first and then went over with 3000. Scott is a perfectionist and has sanded every square inch of this car. Weather permitting we will be doing some more sanding and buffing this weekend and I will continue to post pics as the project progresses. I cannot take alot of credit for this as I had came in on the tail end of the sanding, I think Scott already had over 60 hours into sanding when I started to help him. Scott is also writing an article on his experience, I will make sure that I get everybody a link to that as well when it is completed..
Here is the car before. I think you will agree it is freaking awesome...
The problem...
The sanding process...
The problem...
Getting ready to buff...
A few panels buffed out...
more to come...
more to come...
Originally Posted by ZaneO
Brave, brave, brave!
Looks like you two are doing great work so far
It has also given me the encouragement I needed to start wetsanding some of the bad spots on mine also.
Man, it takes guts to attempt that on a factory paint job when you don't really know how much clear has been applied. It does look awesome!!!! Just seeing the sanding pictures is pretty scary, but the end product really looks great.
-Bob
-Bob
If you have any questions for Scott directly please go to the original thread on the Z06 forum, he is a great guy and I am sure he would be more than happy to answer them for you, he is also a member of Z06vette.
http://www.z06vette.com/forums/showthread.php?t=93629
Or you could ask here and I will give it my best shot providing it is a generic question about the process.
1 Post
St. Jude Donor 06
From some of your other threads I would have never doubted your ability to polish this one out. Wet sanding is a beotch and very time consuming but the final shine is top notch. Which looks like you are on the way.
What kind of time are you looking at? Also what type of compound are you using on the first go round?
Wow!
AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
It does takes some to do that, especially on a new car. The outcome is incredible. GREAT JOB!!!!!!!!!!!!
So tell me the basics -
Does this mean you are removing all the clearcoat, then getting a smooth basecoat paint surface by sanding it?
or are you just sanding the clearcoat itself to a smoother surface?
Then my other questions:
I'm sure you can enlighten me on this process. Great pics - and thanks for the post !
- if you're actually sanding the base coat, how do you protect it once you're done? do you re-clear coat it?
- if you're NOT sanding the base coat, then how do people claim to get rid of orange peel this way? Isn't the OP in the base coat itself?
Originally Posted by gmblack3
Frank, are you guys going to use any Menzerna 106ff/085?
Can't wait to see the finished product.
REally cool, agentf1 -
I guess you know you've hit base coat when you see color coming up, rather than just a milky white material while wetsanding.
other than that, isn't there some kind of device you can use to gauge the paint thickness?
It's a pretty courageous process. Would be fun to try on my vert - but wow, lots of hours, and I need the car to get to work everyday. Hell, I DO ride a motorcycle most days in the summer though . Hmmmm.....
my black c6 is in the shop right now getting the clear sanded off and new clear shot on and buffed out should look nice when its all done ,looking for perfect finish
good luck finishing the Z
