How Do I Keep From Scratching the Paint?
1 Post
St. Jude Donor '06
I've had my Monterey Red coupe for about a month, have washed it 3 times, and am already seeing fine scratches in the paint. The dealer applied a coat of sealant and I immediately added another coat of Rejex. I'm using new microfiber towels for both washing and drying and am careful what I wash first (horizontal surfaces, windows, etc.) and last (lower sides, back end, around wheel wells, etc).
Is there something I can do differently to reduce scratching? Woiuld a lambswool wash mit or other tools make a difference?
HELP!
HELP!
It's good you were sharp enough to notice. A few things
Many will disagree with me, but I really think that the synthetic microfiber is a big problem if you're using it to detail. Use 100% cotton. Also, using synthetic sponges and chamois cloths can be a problem as well. GEt that mitt, and of course don't use it on the wheel wells or wheels etc - keep it clean to use only on the body panels.
And it's a good time to think about getting a PC7424 so you can remove those scratches when the time comes that they start to bother you.
- 1. most definitely buy a sheepskin mitt.
- rinse the mitt frequently
- buy a "Grit Guard", sold at THE GEEK, or in the combo deal I got. It helps OR...
- Use two buckets - one to rinse out the mitt with plain water, the other to soak your mitt and refill it with soapy water
- use only 100% cotton to apply your wax/sealant, and to remove same
All great advice above...
I would also recommend using a Leaf Blower to dry your car. I have a 220 mph Electric Toro Leaf Blower and it works great. If you car is freshly Zaino'd it will practically blow it perfectly dry. I then follow up with a pakshak waffle weave drying towel to get they few remaining spots of water. The less you touch it the less chance of scratching it.
I also second using the Sheep Skin mitt but have to say that I used a sponge for washing for years and never had a problem. I think it is more in your method. Use 2 BIG buckets, 1 for the wheels, one for the body. Work top down (roof first, then hood, trunk, top of side, bottom of side etc), rub top down so the grit falls. I try to never rub up the side it is always top to bottom, top to bottom and occasionally go horizonal if needed but never reverse direction. Rinsing sponge/mitt frequently.
Store your MF's in plastic bags so they do not get grit in them while sitting on shelf. I would also do the CD test to make sure you have good quality MF. I really like DFTowels for removing my LSP, although I think they suck for drying.
another thing to do if your crazy like me is buy a gilmour foam gun. foam gun It is meant to fopam chemical cleaners but does a great job of producing a lot of soap foam. More soap foam better lubricting and floats the dirt off. Less wash scratches. I agree with bugman, The porta cable is great for polishing
1 Post
St. Jude Donor '06
I got lucky and bought it off of ebay. or go here:
http://www.automagic.biz/accessories/miscorder.htm
Rob
Location: Mississauga, Ontario Corvettes were built to be driven...not trailered
1 Post
St Jude Donor '07-'08-'09
I use the McGuires soft brush. I know it sounds crazy but it works. When you put it the pail you shake all the fine grimy stuff off while its submerged. Go the the mcguire website for more details
Good Point About The Maguire's Brush!
I got one for my girlfriend to use on the higher parts of her new SUV and it not only works great but never leaves any scratches on her paint. Very soft material and only cost about $10.00!
