Quote:
Originally Posted by SRQC5
will goof off hurt the paint...also will a clay bar remove the clearcoat?
Goof Off will not harm the paint (just make sure it is the water based version). Clay bar is not abrasive enough to remove clearcoat, and should remove overspray and new paint immediately. 3M makes a
Wax/Adhesive Remover that should immediately rid the paint issue from the car. Just remember you will need to rewax or reseal when done. I have even removed some recent paint with WD-40.
oops .... just reread the topic and everything is off except the tires. A stiff brush and wheel cleaner should remove that. If the wheels , not tires, need help then all the above apply as long as clearcoated. If not, tread very lightly. Wish you were closer, got a new product in this week, that just might work.
http://www.autogeek.net/mothers-tire...r-cleaner.html
