Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-01-2006, 12:29 AM   #1
Bosscar9er
CF Member
Bosscar9er's Avatar
Default Water Spots on Black
My mother told me not to buy black. I didn't listen and bought black anyway. Anyone know a good remedy to remove water spots? I tried wax and Zaino. Nothing I have tried seems to work. Any ideas?
Bosscar9er is offline   Reply With Quote
Old 01-01-2006, 01:47 AM   #2
Driver_WT
CF Senior Member
St. Jude Donor '07
Driver_WT's Avatar
Clay bar.
Driver_WT is online now   Reply With Quote
Old 01-01-2006, 01:48 AM   #3
VIPERxGTx2000
CF Senior Member
St. Jude Donor '05
VIPERxGTx2000's Avatar
Location: Never take a girl out for a cup of coffee, the last thing you want her to be is alert and focused. Tampa, FL
vinegar, diluted or full strength depending on the water spot. If that doesn't work then a clay bar will most likely do the trick. I have also heard of people using meguiars scratch x on stubborn water spots.
VIPERxGTx2000 is offline   Reply With Quote
Old 01-01-2006, 01:58 AM   #4
Jagcvette
CF Senior Member
Jagcvette's Avatar
Quote:
Its best to get them out now as opposed to later too. The good news is is that they will come out, just depends on how deep you need to go with the cleaners. Make sure you put som rejax on afterwords.
Jagcvette is offline   Reply With Quote
Old 01-01-2006, 09:26 AM   #5
Top Flight Reproductions
Supporting Vendor
St. Jude Donor '07-'08-'09-'10-'11
Top Flight Reproductions's Avatar
Quote:
and next time listen to your mother....
Top Flight Reproductions is offline   Reply With Quote
Old 01-01-2006, 09:34 AM   #6
VERTBLK
CF Senior Member
VERTBLK's Avatar
But they look soooo good when they are clean.
VERTBLK is offline   Reply With Quote
Old 01-01-2006, 09:52 AM   #7
SC TROJAN GRAD
CF Senior Member
SC TROJAN GRAD's Avatar
Quote:
until they leave the garage.....
SC TROJAN GRAD is offline   Reply With Quote
Old 01-01-2006, 10:01 AM   #8
timd38
CF Senior Member
timd38's Avatar
Quote:
I use McGuires "instant detailer" on my black Linclon LS, but bought the Vette in yellow for the reasons you mother told you.
timd38 is offline   Reply With Quote
Old 01-01-2006, 11:10 AM   #9
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Default [b]Removing water spots:[/b]
There are two categories of water spots;
a) Surface water spots-alkaline watermarks (water spots) are calcium and magnesium salts that deposit on the surface after the water has evaporated, the minute crystals bond to the surface and are not re-dissolvable in water. Rainwater also contains alkaline minerals that alight on the paint film surface and as the water evaporates leave white `water spots' on both the paint and glass surfaces. Alkaline water spots (sprinkler water) require an acid (vinegar is a Acetic acid pH 2.0.) to remove them, any subsequent etching requires an abrasive to level the paint surface
b) Below surface (etched) water spots- are caused by acid rain (pH 3 – 4.0) or industrial fallout causing a chemical reaction, if left for any length of time they will etch the paint film surface leaving a concave circular mark. Etched water spots are one of the most difficult paint defects to remove so be patient as it will probably take more then one attempt to remove them. Acid rain spots require an Alkaline to neutralize them
(See also Industrial fall out (IFO) and Acid rain)
a) Removing water spots from glass- rainwater sometimes contains alkaline minerals that alight on the paint film surface and as the water evaporates leave white `water spots' on glass surfaces. Mineral deposits can be caused by water from a light summer shower, or a lawn sprinkler system that that dries on the glass surface leaving a calcium / sodium deposit.
These can usually be removed by using detailer's clay to remove any hardened surface deposits, and then using a solvent type cleaner (Klasse All-In-One) for stubborn spots polish them using method (b)
Methodology
•Use detailing clay to remove any `hard' surface granules
•Dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following;
a) 2:1 solution of distilled water/distilled white vinegar , adjust ratio as required
b) A 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required)
c) Equal parts distilled water/distilled white vinegar/Isopropyl alcohol.Allow vinegar (Acetic acid) solution sufficient dwell time (5-10 minutes)
•Use a clean spray bottle and 100% cotton Microfiber cloth to apply the solution to the glass surface
•Or soak a first aid gauze pad with the vinegar/ water solution, this will help it stay in place during the necessary dwell time, 5-10 minutes) wipe off any residue from glass and dry with a damp waffle weave towel
•If any `water spots' remain apply distilled white vinegar or Isopropyl alcohol un-diluted to 100% cotton Microfiber towel, using a medium/heavy pressure on glass surface.
•If this does not remove the `water spots' use a chemical type ‘polish’ (Autoglym Car Glass PolishTM )and fine grade bronze wool (http://www.briwax-online.com) use straight-line motions only (circular motions cause swirl marks)
•For stubborn water spots use (A B C Decontamination / Neutralization system (http:// www.autoint.com) a safe alkaline wash and neutralizing system This three part system comprises; A-Acid Neutralizer, B-Alkaline Neutralizer (use in conjunction with detailers clay to remove ‘water spots’) and C- Surface Conditioner with a pH of 7.0, which safely removes both surface and subsurface contamination and neutralizes any residual acid from the painted finish. Any subsequent etching will require an abrasive to level the paint surface
b) Removing etched (below surface) water spots from glass--- are caused by acid rain or industrial fallout causing a chemical reaction, if left for any length of time they will etch the paint film surface leaving a concave circular mark. Etched water spots are one of the most difficult paint defects to remove so be patient as it will probably take more then one attempt to remove them.
These can usually be removed using detailer's clay to remove any hardened surface deposits and then using a mechanical type abrasive polish (Zaino ZPC Fusion) with #0000 synthetic steel wool or Iz Einzette Glas Polish, a random orbital buffer (speed # 4) and a cutting foam pad (LC orange or yellow) to level the surface.
Notes:
Do not use abrasive cleaner; glass polish or any grade synthetic steel wool on after market-tinted glass or you will probably scratch the surface.
1.For deeply etched water spots' in the glass surface, do not attempt to polish them out, consult an automotive glass vendor as glass used on later model cars is soft and thin (this may vary by manufacturer) due to weight / cost savings by vehicle manufactures and polishing could cause glass to crack.
2.Be cautious with polishes that contain abrasives like aluminium or cerium oxide as they have the potential to damage glass beyond repair.
3.Some windshields and mirrors have a tinted plastic coating or a blue tint that will scratch or be damaged, only polish or use synthetic wool on uncoated glass.
[each one / teach one, then student /becomes teacher]
TOGWT is offline   Reply With Quote
Old 01-01-2006, 11:16 AM   #10
TOGWT
CF Senior Member
TOGWT's Avatar
1a) Removing surface water spots from paint film surface-
Methodology
a) Use a 2:1 solution of distilled water/distilled white vinegar
b) Try 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required)
c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol.
Allow vinegar solution sufficient dwell time (5-10 minutes)
•Use a clean spray bottle and 100% cotton Micro fibre cloth to apply the solution to the surface
•Or soak a first aid gauze pad with the vinegar/ water solution, this will help it stay in place during the necessary dwell time, 5-10 minutes) wipe off any residue from surface and dry with a damp waffle weave towel
•Use a clean spray bottle and 100% cotton micro fibre cloth to apply the solution to the paint surface
•Wipe off any residue from the surface and dry with a damp waffle weave towel
•If any `water spots' remain apply distilled white vinegar or Isopropyl alcohol un-diluted to a 100% cotton micro fibre towel, using a medium/heavy pressure on surface, for stubborn spots use an abrasive polish as in 1b)
1b) Removing etched water (below surface) spots from paint-
Methodology
•These can be removed by using detailer's clay to remove any hardened surface deposits
•Then using a machine polish ( Optimum Polish or Compound, Klasse All-In-One ) and a cutting (LC Orange or Yellow) foam pad (speed # 4) to level the surface
•Work on a very small area at a time (2-foot x 2-foot) until the polish has run out
•Repeat this process two or three times, as necessary
•Reapply surface protection once spots have been removed.
1c) For stubborn water spots use (A B C Decontamination / Neutralization system (http:// www.autoint.com) a safe alkaline wash and neutralizing system This three part system comprises; A-Acid Neutralizer, B-Alkaline Neutralizer (use in conjunction with detailers clay to remove ‘water spots’) and C- Surface Conditioner with a pH of 7.0, which safely removes both surface and subsurface contamination and neutralizes any residual acid from the painted finish. Any subsequent etching will require an abrasive to level the paint surface
If water dries on a paint surface ultra violet radiation (heat) radiation (UVR) will cause water spotting, especially if it contains an excess of minerals, which will etch the surface, an acetic acid (vinegar) will remove the spotting and an abrasive polish to level the paint surface may be necessary
Old 01-01-2006, 12:14 PM   #11
John Ulrich
CF Senior Member
John Ulrich's Avatar
I have a black minivan which which takes longer to cleanup than my wifes pearl white vehicle and my Vette combined!!!
I broke down this summer and spent $200 for a deionizer....quite frankly the last item I ever invisioned myself purchasing but the battle I faced with water spotting on the finish and chrome rims wore me down.
I tested it out of the box on a 90 degree/full sun day. I washed it in the sun, midafternoon.
Dried spotfree!!!! I'm sold.
http://crspotless.com/index.php?cate...d=6&return=%3f
Later,
JU
John Ulrich is offline   Reply With Quote
Old 01-01-2006, 12:19 PM   #12
VIPERxGTx2000
CF Senior Member
St. Jude Donor '05
I sort of purchased the same thing except that I got a reverse osmosis system and deionization cartridge working together($150) so I only need to change the filter about once a year and even then, it's only $20.
Old 01-01-2006, 12:52 PM   #13
sscamaro
CF Senior Member
St. Jude Donor '07
sscamaro's Avatar
Send a message via Yahoo to sscamaro
After you get the water spots off, next time you wash the car, dry it off with a leaf blower. It gets all the water off before it drys.
__________________
Ralph's Cars
2005 C6, Black, MZ6, Z51 Package, Polished Z06 Wheels, Corsa Extreme, Kooks LT Headers & X-Pipe,Halltech CAI, B&M Shifter, Bilstien Shocks. 388/rwhp and 380/rwtq. Ported Intake,TB & Tune by Jeremy Formato
2010 Camaro SS/RS Victory Red, MN6. Hurst Shifter, SLP Axle Back, Kooks LT Headers, Edelbrock E-Force S/C, Roto-Fab CAI. 546/rwhp 522/rwtq Tune by Jeremy Formato.(Built 9/14/09)
2002 Camaro SS (Build Date 9/10/01) Bright Rally Red, 384/rwhp and 381/rwtq (SOLD)
sscamaro is offline   Reply With Quote
Old 01-01-2006, 01:16 PM   #14
gmblack3
CF Senior Member
gmblack3's Avatar
Good luck if you have to polish them out. If they have been there for a while, the vette clearcoat is very hard. With a PC its going to be very hard to get them out if they have set in for a while.
Good Luck.
gmblack3 is offline   Reply With Quote
Old 01-01-2006, 03:16 PM   #15
Bosscar9er
CF Member
Bosscar9er's Avatar
Thanks everyone for the advice, especially TOGWT's long detail. I will try the clay bar first and let you all know. One more question, if have several coats of wax on the car now, will the clay bar be effective or should I first use the vinegar to remove the wax then the clay bar?
Old 01-01-2006, 11:42 PM   #16
jesse12804
CF Senior Member
jesse12804's Avatar
Default spots
Maguires scratch-x,about 5 bucks,works great!auto parts store.
jesse12804 is offline   Reply With Quote
Old 01-01-2006, 11:58 PM   #17
RainJ
CF Senior Member
RainJ's Avatar
Location: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Send a message via AIM to RainJ
had em on my C5 the first few times I washed it.
then I bougth the MR Clean car wash system at WalMart - just to try it out.
SOB works! (but I hear some areas have harder water and that the filters and such do not do as good a job - so your mileage may varry)
I don't even touch mine after using the final spray of filtered hose water. Air dries with no water spots.
lots of good advice on this thread
Rain
__________________
CLICK HERE: My Hurricane Katrina Pictures & Video
Endorsing Artist with CA Guitars: http://www.caguitars.com/
2000 Corvette Coupe---Black/Black---6 Speed
19/20 HRE 547, RKSport Hood, Long Tube Headers, Xpipe, Vararam, Borla Exhaust, FrameSavers/RockerRails, Eradispeed +1/+2 Rotors, Both Tops, Lowered, etc
1996 Corvette Coupe---Bright Aqua Metallic---Automatic
SOLD!!!!!
RainJ is offline   Reply With Quote
Old 01-02-2006, 12:16 AM   #18
bugman
CF Senior Member
Support Corvetteforum!
bugman's Avatar
Quote:
yup --
my opinion and experience with black car left in the sun each year under sprinklers:
  • don't waste time with vinegar or clay bar - won't do a damned thing
  • start with scratch X and terry towel - it will do the trick for any spots , unless really baked in for months
  • for spots that are etched in, use 3M fine cut rubbing compoud #39002 - it will work with a terry towel, or much easier with a PC7424
If you are using scratch X or 3M, no need to remove your sealant first - these abrasives will do that. So afterward, when your finish is perfect again, be sure to seal up the paint again. Purists will tell you to use a half-half rubbing alcohol-water wipe after the abrasive product, but I've never done that, and am happy with the results.
Here is an example:
BEFORE
AFTER 3M 39002 and terry towel:
bugman is offline   Reply With Quote
Old 01-02-2006, 09:52 AM   #19
SC TROJAN GRAD
CF Senior Member
buy a car cover if the car sits by sprinklers....
Old 01-02-2006, 10:00 AM   #20
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
TOGWT has some of the best information to progress into the water spots moving from least abrasive to most abrasive. I will tell you in anything other than relatively new spots, you most likely will end up at the paint "polish" stage quite quickly.
With polishes you can also start with some of the least abrasive polishes (ScratchX, Poorboys 1.0) and move to the extreme as needed (compounds = most abrasive) . I have found that a relatively abrasive polish (Menzerna Intesive Polish, Poorboys 2.5, Optimum Hyper) is usually needed with a cutting (orange or yellow) pad initially when working with a PC and higher rpms.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Reload this Page Water Spots on Black
Tags
autoglym, black, car, care, cerium, deeply, etched, oxide, paint, pc7424, removing, safe, spots, vinager, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Water Spots paulv@05 Car Care Discussion 11 07-21-2005 01:05 PM
clay-bar skeptic - now a believer! Bullet C5 General 25 10-18-2004 11:28 AM
getting swirls on black paint C5 Hardtop Car Care Discussion 11 05-29-2004 03:01 PM
WOW! Look, Ma, no water spots... tampaz06 Car Care Discussion 9 12-06-2003 01:32 PM
Z6 streaking on black car LT4Coupe Car Care Discussion 10 05-17-2002 06:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
