Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2005, 02:57 PM   #1
ZO6Gal
CF Senior Member
ZO6Gal's Avatar
Default REJEX question...
I just received a gallon of Rejex I had ordered. How is this stuff applied? Do I just put it on right out of the bottle or is it concentrated? Not much instructions on it that I can tell. I probably should have gotten the spray but I wasn't sure. Thanks for any help.
Robin
ZO6Gal is offline   Reply With Quote
Old 11-08-2005, 03:01 PM   #2
cerino2000
CF Senior Member
cerino2000's Avatar
The smaller bottles you just shake up and then squeeze them. The gallon size is probably sold as a refiller for the smaller appicator bottles.
cerino2000 is offline   Reply With Quote
Old 11-08-2005, 03:05 PM   #3
C6FirstVette
CF Senior Member
C6FirstVette's Avatar
First step is to prep the paint...clay bar or a clear coat finish cleaner..then simply apply (soft cloth) as any other high end wax/protectorant...BUT ReJex requires a 'cure' time... I tend to apply in the evening and let sit over night and buff off in the morning...
Michale
C6FirstVette is offline   Reply With Quote
Old 11-08-2005, 03:09 PM   #4
gilly6993
CF Senior Member
St. Jude Donor '08
gilly6993's Avatar
I just used it like it says on the bottle....put it on....let it dry about 10-20 min....let it cure overnight....
gilly6993 is offline   Reply With Quote
Old 11-08-2005, 03:09 PM   #5
Buffy
CF Senior Member
Buffy's Avatar
RejeX is applied full-strength. Clean the car well, shake up RejeX well, wipe it on, wait for it to haze (20-30 minutes), wipe it off. Just like NXT or most other high-tech waxes, except that you then want to let it cure for 12 hours. As far as I understand the cure time mostly means not letting it get wet - I assume it polymerizes due to moisture, like superglue. There are a lot of threads about this over in the car care area.
You may find transferring some to a smaller bottle to be convenient.
Buffy is offline   Reply With Quote
Old 11-08-2005, 03:11 PM   #6
donsar
CF Senior Member
donsar's Avatar
It was not meant to be left on overnight. The instructions are to apply a thin layer wiped on. Then, after about 15 or 20 mins when it is a visible film, wipe it off. Do not let it sit that way overnight. It is then that the car should be kept out of the elements for 12 hours and not driven in order to let the polymers cure.
donsar is offline   Reply With Quote
Old 11-08-2005, 03:23 PM   #7
Rube66
CF Senior Member
Question:
I have noticed that alot of you guys apply this stuff the minute you get your baby home.
I was always told by body shops to never apply any type of polish or wax on new paint for at least 3 months to allow for proper curing??
Thoughts??
Regards,
Rube
Rube66 is offline   Reply With Quote
Old 11-08-2005, 03:26 PM   #8
Unknown
Fall Forward
St. Jude Donor '08-'09-'10-'11-'12
Support Corvetteforum!
Unknown's Avatar
Don't wait
Unknown is offline   Reply With Quote
Old 11-08-2005, 03:28 PM   #9
Unknown
Fall Forward
Unknown's Avatar
Rube...check out Regional forum...midwest.
See you there
Old 11-08-2005, 03:43 PM   #10
Buffy
CF Senior Member
Buffy's Avatar
At one time, cars were sprayed with laquer (paint that dries by evaporation) which was reduced with a mixture of solvents. Some of these solvents evaporated quickly, letting the paint gel enough to be solid but others evaporated more slowly, over a period of weeks. During this time the paint was still too soft for most polishing operations - the abrasive would embed in the paint rather than polish it. Most automotive waxes do include some abrasives as cleaners and polishers.
As far as I know, all modern automotive paints except touch-up paint are enamels, paints that dry by chemical reaction. This reaction occours pretty quickly - less than an hour in any case. In particular the paints used by automotive factories dry very quickly - they have to, to keep the line running, and they can because automated equipment is used which can spray the whole car very quickly.
So as far as I can tell, a week (and it's not likely that you got your car within a week of it's being painted, even with museum delivery) should be plenty of time for any residual curing of the factory paint.
In any event, the RejeX itself shouldn't be a problem - it's not abrasive.
Old 11-08-2005, 04:38 PM   #11
jim213
CF Senior Member
jim213's Avatar
When I get my vert it will receive a coat of Rejex as soon as I have the time. Will try to do two coats in two days.
jim213 is offline   Reply With Quote
Old 11-08-2005, 05:21 PM   #12
BACH
CF Senior Member
BACH's Avatar
Default rejex
i just used it for the first time this saturday squirt it on spread it around with a soft cloth wait 20 minutes while it hazes used a micro fober towel to wipe off left it in garage overnight to curepulled it out of the garage in the morning and watched it sparkle this stuff is great i think i'm gonna have to buy some more
BACH is offline   Reply With Quote
Old 11-08-2005, 05:23 PM   #13
Guitarstar
CF Senior Member
Guitarstar's Avatar
Quote:
Guitarstar is offline   Reply With Quote
Old 11-08-2005, 06:43 PM   #14
jabez
CF Senior Member
jabez's Avatar
Send a message via ICQ to jabez Send a message via AIM to jabez
Quote:
Originally Posted by blznsdl
Don't wait
jabez is offline   Reply With Quote
Old 11-08-2005, 06:49 PM   #15
C6FirstVette
CF Senior Member
I just love detailing issues..yes leave on over night and it does work doing that... does not hurt and can attest it works...sigh...
M
Old 11-08-2005, 06:50 PM   #16
own2vettes
CF Senior Member
own2vettes's Avatar
To the guy with the gallon of this stuff: send me a small bottle of it. My wife has hidden the credit cards from me.
own2vettes is offline   Reply With Quote
Old 11-08-2005, 08:28 PM   #17
ZaneO
CF Senior Member
ZaneO's Avatar
Quote:
Originally Posted by Rube66
Question:
Thoughts??
Regards,
Rube
Factory paint is cured at very high temperatures and can be waxed/sealed immediately.
Aftermarket paint will vary by painter. Follow your painter's advice.
ZaneO is offline   Reply With Quote
Reload this Page REJEX question...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
REJEX - Thumbs up! AceVentura Car Care Discussion 66 09-18-2005 08:52 PM
Wax choice? 1 word please... Unknown Car Care Discussion 107 08-17-2005 08:38 PM
rain-x gmosley C5 General 36 06-12-2005 05:47 PM
Best Wax for my Torch Red C5 sirsenna C5 General 48 06-04-2005 07:45 PM
RejeX Group Buy - Forum Discount from X-Auto Products X-AutoProducts C4 General Discussion 16 05-01-2005 11:56 AM
RejeX Group Buy - Forum Discount from X-Auto Products X-AutoProducts C5 General 22 05-01-2005 09:19 AM
Tire Care Question Kevin21 Car Care Discussion 10 08-08-2004 06:31 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
