Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2005, 04:59 PM   #1
VetVetter
CF Senior Member
St. Jude Donor '09-'10
Support Corvetteforum!
VetVetter's Avatar
Location: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
Default Best Way to Remove Swirl Marks
I am no detailer. My car looks good, but I have noticed some swirl marks. Before I wax or use that other stuff, I should probably get rid of the swirl marks!
What is the best way to do that? I have heard swirl mark remover, then clay bar. Then I have heard the other way around.
They are not deep btw.
Thanks mates!
VetVetter is offline   Reply With Quote
Old 11-07-2005, 05:04 PM   #2
6speedC6
CF Senior Member
6speedC6's Avatar
I found the 3m scratch and swirl remover works well but I just bought a scratch and swirl remover product from Zaino. I haven't used it yet but if it works like the rest of their product should get good results. I also from time to time use my porta cable dual action buffer and that really seem to do the trick without any damage
__________________
2011 Mustang GT 5.0
Candy Red
2005 6speed Coupe (sold)
2009 cybergray auto Coupe(trade in)
6speedC6 is offline   Reply With Quote
Old 11-07-2005, 05:07 PM   #3
Guitarstar
CF Senior Member
Guitarstar's Avatar
Any one have experience with 3M Finesse it?
That is the final process on our Corvettes @ the BG factory.
Guitarstar is offline   Reply With Quote
Old 11-07-2005, 07:58 PM   #4
markbrown
CF Senior Member
markbrown's Avatar
Send a message via ICQ to markbrown Send a message via AIM to markbrown Send a message via MSN to markbrown Send a message via Yahoo to markbrown Send a message via Skype™ to markbrown
one word - meguires x scratch
ok maybe a couple of words.
markbrown is offline   Reply With Quote
Old 11-07-2005, 09:01 PM   #5
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
Thanks mates!
First you need to understand the proper steps in the detailing process then the whys/hows of the steps youve discussed.
WASH ---- Clay ---- Rewash ---- Dry ---- Polish ---- Seal/Wax
Claying --- this step comes first, and it has no benefit in removing any type of swirls/marring/spiderwebbing. It is in fact a way to remove contaminents that are ground into the paint and cannot be removed by washing alone. A good test is to put a little saran wrap over your hand and follow the panel. If it grabs or studders, you should seriously consider claying. Its simple with lightly gliding the clay over a lubricated and wet surface. Where the clay studders, you work a couple of times (back and forth not circles) until it is smooth. Only needs to be done twice a year on average.
Polishing (commonly called swirl remover) -- this is where an abrasive polish or compound (compound is the MOST aggressive polish) are used to burnish and remove or lessen the marks you discuss. In most cases you start with the least abrasive polish and least abrasive pad and move to more aggressive only as necessary. Cutting pads (orange and yellow) are commonly used and a good random orbital is necessary. If the markings are deep you might need to move to wool pads and perhaps a rotary buffer. Some great polishes are Optimum, Menzerna, Poorboys, 3M, and even Megs DACP. All are user friendly and will provide nice results. You will want to "work" the polish until it dries and then remove with a microfiber towel.
http://www.autogeek.net/dual-action-polisher.html
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
AUTHORIZED FORUM VENDOR FOR MORE THAN 9 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 11-07-2005, 09:03 PM   #6
Guitarstar
CF Senior Member
Guitarstar's Avatar
Been using meguires scratch-X for 2 years, dont like it. does not work for me. all scrathes are still there. Im searching now for a 3M product that will get perfected results.
Old 11-07-2005, 10:30 PM   #7
dashotgun
CF Senior Member
dashotgun's Avatar
got to autopia.org a website dedicated to car guys and detailing listen to autogeek. for proper detailing you need a random orbital buffer
dashotgun is offline   Reply With Quote
Old 11-07-2005, 10:59 PM   #8
rclark
CF Senior Member
rclark's Avatar
I say try Menzerna Final Polish II, a very fine polish. Final step at the Benz factory. I used it on my Porshe before the C6. Nice glass finish. If your swirls are deep you my need something a bit more aggressive/corse like Menzerna Intensive Polish. Good Luck!
rclark is offline   Reply With Quote
Old 11-07-2005, 11:05 PM   #9
pdqz06
CF Senior Member
Quote:
3M fill-n-glaze,,,,,,,find at any auto body supply shop
pdqz06 is offline   Reply With Quote
Old 11-07-2005, 11:10 PM   #10
mnmvette
CF Senior Member
Just curious, but why did you use it for 2 years if you don't like it?
mnmvette is offline   Reply With Quote
Old 11-07-2005, 11:21 PM   #11
LarsAtTheBeach
CF Senior Member
St. Jude Donor '08-'09-'10
Best way to remove swirl marks...
Get in the drivers seat, and drive. You would be suprised how quickly they go away.
LarsAtTheBeach is offline   Reply With Quote
Old 11-07-2005, 11:21 PM   #12
sallen619
CF Senior Member
sallen619's Avatar
Meguire's NXT wax.
sallen619 is offline   Reply With Quote
Old 11-07-2005, 11:48 PM   #13
54greg
CF Senior Member
54greg's Avatar
3M all the way! I've use it on black, black and black. Always works
__________________
54greg is offline   Reply With Quote
Old 11-08-2005, 01:23 AM   #14
LS WON
CF Senior Member
LS WON's Avatar
Default Liquid Glass Polish works wonders with me
It's easy to get also.
LS WON is offline   Reply With Quote
Old 11-08-2005, 11:46 PM   #15
markbrown
CF Senior Member
markbrown's Avatar
oh well - maybe i rub harder? anyway dupont makes a polishing compound in red and white. i know that will work for you.
like dupont number 7 or something like that.
Old 11-09-2005, 12:30 PM   #16
huskeric
CF Senior Member
Stick with 3M products. Meguiar's is pretty decent, but my numerous efforts have continually shown 3M to be the best.
http://www.autogeek.net/3mperswirmar1.html
huskeric is offline   Reply With Quote
Old 11-09-2005, 12:57 PM   #17
gkvetteuno
CF Senior Member
Quote:
Originally Posted by sallen619
Meguire's NXT wax.
This is a good wax, but had no luck with it doing anything with swirls or minor scratches.
gkvetteuno is offline   Reply With Quote
Old 11-09-2005, 01:37 PM   #18
AK's Z
CF Senior Member
3M Finesse IT III, followed by 3M swirl mark remover, both used with a 3" yellow foam pad attatched to a drill. Autogeek carries the kit.
AK's Z is offline   Reply With Quote
Old 11-09-2005, 02:50 PM   #19
need-for-speed
CF Senior Member
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03-'05-'07-'09-'10
need-for-speed's Avatar
No offense, but don't use a drill. Use a random orbital such as a Porter Cable, available at Lowes (no need to mail order). Some expers also say novices should stick to the white polishing pads and avoid the more aggressive yellow and orange pads. I use Menzerna intense followed by the final polish. I practiced on an old truck first. Results were fabu.
need-for-speed is offline   Reply With Quote
Old 11-09-2005, 03:11 PM   #20
JLinNY
CF Senior Member
JLinNY's Avatar
Excellent advice!! I have used a few different swirl removers, and nothing works on my Arctic White like 3M #39002 Perfect-It II fine cut rubbing compound.
This stuff combined with a yellow pad on a dual action polisher will take out anything that you can't feel with your fingernail. Top that off with a polish (I use Menzerna), and you are ready for wax.
JLinNY is offline   Reply With Quote
Reload this Page Best Way to Remove Swirl Marks
Tags
bar, clay, corvette, forum, glass, marks, remove, rid, swirl, swirls, swrill, top, white
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to remove swirl marks and fine scratches bman1997C5 C5 General 15 06-01-2005 09:14 PM
Help, what's the best way to remove pine sap? jc123 C5 General 19 01-18-2005 10:17 PM
Whats Second Best? (Car wax) Lurker Car Care Discussion 16 01-12-2002 02:12 PM
Do I need to strip zaino before applying carnuba wax? Kale Car Care Discussion 18 11-06-2001 03:38 AM
is it possible to have a black car look as good in the sun as is in the shade?? autolover Car Care Discussion 11 09-27-2001 02:32 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
