Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-22-2005, 01:55 PM   #1
Net Exploit
CF Senior Member
Net Exploit's Avatar
Send a message via AIM to Net Exploit
Default Water Spot Removal and other Subjects
I am getting ready to do some serious detailing. I use Zaino.
However before I start the yearly ritual, I want to remove the water spots on my paint. Does anyone have a suggested procedure for that.
I assume I will follow that up with Clar Bar and then move on to
swirl and scratch removal. Any suggestions on the best swirl removal product for this. I will be using with a Dewalt 849 Buffer.
Thanks,
Dan
Net Exploit is offline   Reply With Quote
Old 08-22-2005, 02:49 PM   #2
Boozman
CF Senior Member
Boozman's Avatar
Clay bar will remove the water spots.
__________________
1972 Convertible
1980 Coupe
2001 Coupe
2004 Black Z06
2005 Black C6
2010 Torch Red C6
2012 Article White GS
Boozman is online now   Reply With Quote
Old 08-22-2005, 03:05 PM   #3
1bdvet
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
1bdvet's Avatar
Clay Bar Is The Way To Go.
1bdvet is offline   Reply With Quote
Old 08-22-2005, 03:20 PM   #4
Net Exploit
CF Senior Member
OK, Clay Bar it is.
I then need to polish swirl marks out. I will be a polisher/buffer.
Any suggestions on the polish?
Old 08-22-2005, 03:50 PM   #5
easyrider13
CF Senior Member
easyrider13's Avatar
I think you'll like Optimum Polish.
easyrider13 is offline   Reply With Quote
Old 08-22-2005, 04:29 PM   #6
ZaneO
CF Senior Member
ZaneO's Avatar
If the spots are etched, a claybar isn't going to do a thing for them. You will need a paint polish to remove them.
__________________
Zane Oliver
ZaneO is offline   Reply With Quote
Old 08-22-2005, 05:54 PM   #7
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Default Removing water spots from paint film surfaces-
1a) Removing surface water spots from paint film surface-
Methodology
•Use detailing clay to remove any `hard' surface granules
•To dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following;
1) 2:1 solution of distilled water/distilled white vinegar
2) Distilled water/Isopropyl Alcohol (adjust ratio as required)
3) Equal parts distilled water/distilled white vinegar/Isopropyl alcohol
Allow vinegar solution dwell time (5-10 minutes)
•Use a clean spray bottle and 100% cotton micro fibre cloth to apply the solution to the paint surface
•Wipe off any residue from the paint surface and dry with a damp waffle weave towel
•If any `water spots' remain apply distilled white vinegar or Isopropyl alcohol un-diluted to a 100% cotton micro fibre towel, using a medium/heavy pressure on glass surface, for stubborn spots use an abrasive polish as in (1b)
•For stubborn water spots use Auto International's A, B, C System, a safe alkaline wash and neutralizing system (http://www.autoint.com/)
1b) Removing etched water (below surface) spots from paint-
Methodology
•These can be removed by using detailer's clay to remove any hardened surface deposits
•Then using a machine polish, Iz einzett TM Metallic Polish or Iz einzett TM Paint Polish and a cutting (LC Orange or Yellow) foam pad (speed # 4) to level the surface
•Work on a very small area at a time (2-foot x 2-foot) until the polish has run out
•Repeat this process two or three times, as necessary
•Reapply surface protection once spots have been removed.
JonM
TOGWT is offline   Reply With Quote
Old 08-22-2005, 06:14 PM   #8
gwayne
CF Senior Member
gwayne's Avatar
If the previous methods don't work for you, Zaino Fusion is fantastic for removing water spots as is Optimum Polish.
gwayne is offline   Reply With Quote
Old 08-23-2005, 02:42 AM   #9
bugman
CF Senior Member
Support Corvetteforum!
bugman's Avatar
if water spots are very old, and etched into the clear coat,
I had excellent results with 3M fine cut rubbing compound 39002 BY HAND -- a bit of work, but completely got rid of them after about 3 applications to the hood. Then one application of 2M 39009 swirlmark remover - but I'm not that convinced that the 39009 added any shine or further improvement, so you might get away with the 39002 alone.
If using a PC, try the 39009 first with white pad - if that doesn't work, move up to the 39002. I had a bad experience with the orange pad, so I think it's far too aggressive for fine scratches or water spots.
bugman is offline   Reply With Quote
Old 09-16-2005, 04:01 PM   #10
phrogs
CF Senior Member
phrogs's Avatar
marked so I can find later!
thanks
phrogs is offline   Reply With Quote
Reload this Page Water Spot Removal and other Subjects
Tags
nj, removal, spot, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
