Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Glass Cleaning 101
Old 08-06-2005, 12:10 PM
0Mike@Autogeek
Former Vendor
Mike@Autogeek's Avatar
Default Glass Cleaning 101
To view this article on our website, click here.
Glass Cleaning
Cleaning automotive glass is tricky, but well worth doing. Clean, clear glass looks beautiful next to clean, waxed paint. Plus, clear glass will give you optimum visibility when driving. That’s a safety feature you can’t afford to overlook. Just a few extra minutes will add the finishing touch to your vehicle and give you a clear view of the road ahead.
Glass Cleaners
Most glass cleaners contain ammonia, which is a good cleaner but it has some disadvantages. It releases fumes that should not be inhaled in enclosed areas, like the inside of your vehicle. Also, it can dry out plastic, rubber, vinyl, and leather. Overspray is not an option with an ammonia cleaner. Plus, you cannot use ammonia on tinted windows. Chances are, if a glass cleaner does not contain ammonia, it will say “ammonia-free” or “safe for tinted windows”. If the label doesn’t say one way or the other, assume the worst and find another cleaner. Avoid household glass cleaners, which almost all contain ammonia. Some examples of tint-safe cleaners are Stoner Invisible Glass, Mother’s Glass Cleaner, and Meguiar’s NXT Generation Glass Cleaner.
Here’s a tip for tinted windows: Use Plexus to polish and protect the tint. Apply it only to the inside of the glass where tint is visible. It will seal the tint material (Mylar) and keep it clean. Plexus is non-static, non-streaking, and it dries crystal clear.
Some people prefer to use plain water to clean their windows. While this is a very safe method, it may not be effective on stubborn spots, like bug splatter. However, a glass-cleaning microfiber towel, like the Cobra Waffle Weave Microfiber Glass Towel, will provide a gentle scrubbing action to help remove contamination. Dampen this towel lightly and clean the glass. Then buff the glass dry using a dry microfiber towel. High quality microfiber does not produce lint and is extremely absorbent to prevent streaks.
Professional tip: Many detailers use newspaper to dry automotive glass because it will not produce lint. This is not a bad option, but be sure to wash the ink off your hands before touching other areas of the vehicle.
Clean by numbers
1. Detail your vehicle. Glass should be the last thing you do to avoid re-contaminating it during the detailing process.
2. Work out of the sun on dry windows. The sun can cause glass cleaner to evaporate too quickly and leave streaks.
3. Lightly dampen your microfiber towel with your cleaner of choice. Wipe down your windshield, and then immediately buff it with a dry microfiber towel, like the Miracle Towel. This will prevent streaks. Do the same on the outside of the back windshield.
4. When you clean your windows, be sure to roll them down to clean the top edge.
5. Whether you clean all your inside glass first, all the outside glass, or window by window is up to you. The advantage to cleaning one window at a time is that you’ll immediately see any streaks you left on the outside when you get in to clean the inside.
6. You can’t always get it right the first time. It may take a mist of glass cleaner to remove stubborn film and then another cleaning with plain water to remove any streaks created by the film. It all depends on exactly what is on your glass. Don’t be afraid to use more than one cleaner on the same window, if that’s what it takes.
7. When you clean the inside of the back windshield, it may be helpful to use the backside of your hand to hold the towel against the lower edge of the glass. This technique will allow you to reach the bottom of the glass with greater ease.
Removing Water Spots
Water spots are mineral deposits that have etched their way into the paint. When a drop of water evaporates, all the minerals contained in that water remain on the paint. Etching is a gradual process, but it sneaks up on you before you know it. The best way to avoid them is to dry your vehicle each and every time it gets wet. If that sounds ambitious, at least dry it after washing it and after a rain shower. If it’s already too late, here are some tips for removing those cloudy spots.
Glass can be polished just like your paint. A gentle glass polish like DP High Performance Glass Restorer will remove most water spots and cloudiness to restore perfect clarity to your windows. You can apply it by hand or with a polisher, but set your machine on a low speed (not exceeding 3000 RPM) and use a polishing pad. Do not apply pressure; the pad will do the work for you. When the polisher starts to dry, stop polishing and buff the residue away with a microfiber towel.
Another option is Diamondite Spray Clay. This is a clay foam that removes embedded contaminants from glass, as well as mineral deposits, using an included sponge. Spray Clay is part of the Diamondite Glass Cleaning System, which also includes Diamondite Glass Cleaner and Diamondite Shield. Spray Clay will not polish the glass to remove etching, but it will correct spots that are still on the surface.
Diamondite Shield will keep your glass clean and provide some protection against future water spots. It seals the glass and causes water to bead. Think of it as a wax for your glass. It improves the performance of wipers and provides a huge improvement in visibility when it rains.
Don’t forget the wipers!
Part of keeping your glass clean is keeping your wipers in working order. The rubber strip can dry out and crack so that it doesn’t hug the glass properly. Therefore, it’s ineffective at clearing water off the windshield. If you maintain your wipers, you won’t discover they’re dried out when you need them most, like in a rain storm. This is extremely dangerous, but preventable.
Wiper blades are inexpensive enough to replace, but you can get more life out of each set if you treat them with a rubber protectant made for wipers. 303 Wiper Treatment Wipes are pre-soaked wipes that keep the rubber soft and supple so the wipers hug the glass properly. Treated wipers will not skip or chatter, and they will remove water and debris more effectively. 303 Wipes also keep your wiper blades from freezing so they clear snow and ice from your windshield better. Check your wipers periodically to be sure they are working well and treat them immediately if they appear to be dried out.
Another way to keep your windshield clean is washer fluid additives. Typical washer fluids available at your local auto store are not very strong and they don’t remove much more than dust. Several companies have formulated additives that provide more cleaning power and work with your regular washer fluid. P21S Windshield Wash Booster is a great product. It supercharges your regular washer fluid to cut through particularly stubborn films and bug splatter. It can be added to antifreeze washer fluids as well as plain water. Overspray will not affect paint or rubber. Wurth Windshield Wash Additive serves the same purpose, but it has antifreeze protection already added to the formula. It will provide frost protection down to -22°F. This product is perfect for cold, snow-prone climates.
Remember, if you use washer additives and a glass sealant, your windows may not require cleaning every time you wash your vehicle. Proper maintenance and the right products will make window cleaning much easier when the time comes.
Old 08-09-2005, 08:55 AM
0Mike@Autogeek
Former Vendor
If anyone has any tips or comments they would like to add, please feel free to chime in.
Old 08-26-2005, 03:33 PM
FIDOauto
FIDOauto's Avatar
LOL @ Mike....
even If I made the products listed I wouldn't be able to add anything!
Awesome Tips.... one of the most frustrating things to do if you dont know how to do it right!
Old 09-04-2005, 08:01 AM
thecatmac
thecatmac's Avatar
Old 09-06-2005, 07:54 AM
cmb13
cmb13's Avatar
Thanks for these and the other tips on your website!
Old 09-08-2005, 04:53 PM
peccles
peccles's Avatar
For the outside of the windows, after washing the car I use the clay bar on the windows and then clean them with a glass cleaner.
Old 09-08-2005, 06:03 PM
JJU
JJU's Avatar
Cruise-In II Veteran
Deleted by Owner
Old 09-24-2005, 01:46 AM
poolhustler
poolhustler's Avatar
I was a glazing contractor for 17 years and the hands down, all around, best damn glass cleaner anywhere is "Sprayway". It is alcohol based, not ammonia. So it doesn't leave streaks. If you can get it in your area, give it a try with some paper towels and you will love it!!! Also, for removing sap, tar, etc.. you can use a new single edged razor blade with some glass cleaner and it will take anything off and not scratch the glass. Only use a new blade and then trash it.....
Russ....
Old 09-24-2005, 07:41 AM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
Russ....
http://www.autogeek.net/sprayway-glass.html
Very good glass cleaner indeed, thats why we carry it
Old 10-16-2005, 09:17 PM
ETM
ETM's Avatar
Once I started using Microfiber Towels I actually enjoy doing my windows now.I used to struggle to get rid of the streaks back when I used paper towels on my windows.Night and day difference.Thanks for the tips.
Old 10-17-2005, 07:30 PM
Former Vendor
http://www.autogeek.net/glass-master-pro.html
we recently added the Glass Master to help in reaching those hard to get to spots in the corner of the C5 and behind the hud.
Old 10-20-2005, 07:51 PM
dbaker
dbaker's Avatar
I just ordered the DP Glass Restore from you.I hope it works!!
\dbaker
rock hill
Old 10-26-2005, 08:04 PM
zoro
zoro's Avatar
I never knew special treatment for tint was recommended--thanks.
Old 11-11-2005, 11:32 PM
az57chevy
az57chevy's Avatar
I wash up and down on the outside and right to left inside. That way you know where the streak is.
Carvin (10-05-2015)
Old 01-13-2006, 11:40 PM
xs650
Support Corvetteforum!
xs650's Avatar
That seems to almost be a secret. The windshield especially get sand blasted with grit all the time. Do th ebaggie or cellophane test and if the glass doesn't feel as smooth as a baby's butt, claybar it.
It's not a substitute for normal cleaning but makes normal cleaning easier, reduces glare a bit and makes the wipers run smoother. It makes the glass act almost like new. Water beads a lot better on the glass too.
Old 03-08-2006, 02:01 AM
Joy of 6
Joy of 6's Avatar
FWIW I always use newspaper to dry my windows. Soaks up all the moisture and leaves no streaks. Also cover the dash with newspaper when I spray the insides so that it does not get on the dash.
Old 03-08-2006, 05:25 PM
Former Vendor
most newspaper is recycled currently, and some chemicals can allow ink transfer to the glass. Thus we prefer to offer a specific microfiber, linen napkin, or Glass Wizard tool.
To Glass Cleaning 101
Old 04-19-2006, 07:53 PM
pacmano
pacmano's Avatar
Russ....
And it works great on laptop screens (seriously).
Old 04-22-2006, 09:14 PM
Former Vendor
http://www.autogeek.net/dpkrviclglki.html
we have recently brought a glass cleaner/towel combo to market. Several of the Stoner faithful like it better. Just might be worth a try.
Old 06-04-2006, 08:59 AM
rwsr50
rwsr50's Avatar
Well, just got finished doing the windows with the DP High Performance Glass Restorer. All I can say is WOW! That stuff really works!!! My windows were full of water spots that nothing I tried would remove, including scraping with a razor blade. I clean the glass every time the car is driven with Stoner's Invisible Glass, but couldn't get rid of those spots that were on the car when I got it. I am happy to report they are now GONE!
Seems like most things in life are a disappointment anymore, but the DP High Performance Glass Restorer is definitely a winner! I highly recommend it if you haven't tried it. I got it from one of our sponsors, AutoGeek, and plan to send them an email telling them how great it worked.
Quick Reply: Glass Cleaning 101
