Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2005, 11:57 PM   #1
Glassbergs
Junior Member
Default Will using distilled white vinegar harm paint finish?
I read that distilled white vinegar can be used to remove watermarks which I got from someone turning on a lawn sprinkler next to my parked C5 vert. I tried vinegar in a small area and it seemed to work with very little elbow grease. Does anyone know if this is harmful to the paint or clearcoat? Thank you.
Glassbergs is offline   Reply With Quote
Old 07-25-2005, 12:16 AM   #2
ZaneO
CF Senior Member
ZaneO's Avatar
It is fine to use. It will remove most or all of your wax, so that are will need to be redone.
__________________
Zane Oliver
ZaneO is offline   Reply With Quote
Old 07-25-2005, 06:27 AM   #3
Z0SLIK
CF Senior Member
Z0SLIK's Avatar
Quote:
Z0SLIK is offline   Reply With Quote
Old 07-26-2005, 09:26 AM   #4
SMR 67
CF Senior Member
Support Corvetteforum!
SMR 67's Avatar
Will vinegar also work to remove dried wax in hard to get areas? I've read on this forum that turpentine is good for that, but I don't need the half gallon of turpentine that seems to be the smallest size my local hardware and paint stores stock.
SMR 67 is offline   Reply With Quote
Old 07-26-2005, 10:13 PM   #5
KLO
CF Senior Member
KLO's Avatar
Send a message via Yahoo to KLO
Will not hurt anything, it will dull out the paint so you will need to rewax the area.
__________________
EMAIL: koverall@cddn.com
2005 Machine Silver C6
2006 Malibu SS Black
1999 Silverado Black
1996 Impala SS Black
Zaino Distributor
WWW.TNZAINO.COM
Zaino Vendor 2010 C5/C6 Bash
KLO is offline   Reply With Quote
Old 05-30-2012, 03:51 PM   #6
SnakeBT6
CF Senior Member
SnakeBT6's Avatar
Revisiting an old thread..
I hand glazed and waxed my black 011 GS..(used Adams products) looks fantastic BTW..took it to the movies and it sat thru a rain shower, then in direct sun for a few hours. Needless to say I now have water spots.
I basically have a millon outlines of where the water spots were. Thought about using white vinegar since ive tried to clay bar and it didnt work. Has opinion on this changed?
If it matters I Zaino'd the car when I first got it and thought Id try Adams now a year later. I really like the shine and the look.
SnakeBT6 is offline   Reply With Quote
Old 05-30-2012, 04:09 PM   #7
Dave1
CF Senior Member
St. Jude Donor '09
Dave1's Avatar
Black cars suck for water spots......
Especially sun water etched.....
It's gonna need a machine polish with the right products and pads to remove them completely. White vinegar can only do so much......
Good luck.....
Dave1 is offline   Reply With Quote
Old 05-30-2012, 04:41 PM   #8
Rich98
CF Senior Member
Shouldn't be that hard to remove so soon after, have you washed and wiped dry the car?
Detail spray and a microfiber should take care of them seeing the car has protectant on it.
I wash my car just outside the garage and pull it back in right away to dry it, spots already forming, they wipe right off.
Rich98 is offline   Reply With Quote
Old 05-30-2012, 04:52 PM   #9
Dave1
CF Senior Member
St. Jude Donor '09
Dave1's Avatar
Quote:
Nope....
Detail spray and a MF towel will not remove water spots......
Especially ones that baked in the sun......
What's underneath doesn't seem to matter with these little devils......
Wax or Zaino, doesn't seem to stop them from showing up from time to time. A good polish with the right pads will help wonders.....
Look for a good detailer in your area if you don't have the knowledge or products for the job.......
Old 05-30-2012, 05:23 PM   #10
Rich98
CF Senior Member
Baked on water spots are one thing, I'm talking about the ones you get right after washing or overnight dew causes on non garaged vehicles.
Some that are etched in the paint will never come out, even after wet sanding and compounding.
Old 05-30-2012, 05:31 PM   #11
SnakeBT6
CF Senior Member
SnakeBT6's Avatar
This was just bad timing with pollen and the car being a bit dirty recently waxed and a heavy rain and hot sun for a few hours after.
Kinda stinks as I really do try and do a good job of taking care of it.
As the clay didnt work, Im going to try and use some white vinegar to see if that helps. Ill let you know the result. If not Ill have to get it professionally polished.
Old 05-30-2012, 07:47 PM   #12
TOGWT
CF Senior Member
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
TOGWT DetailProfessor
Water doesn’t leave marks or etch surfaces; it’s the minerals that it contains calcium (Ca) and magnesium (Mg) and reactivity (heat acting as a catalyst) the spots are actually traces of minerals left on the surface. Alternatively they can be caused by industrial pollution (i.e. acid rain, bird excrement or industrial fallout)
Generally surface water-spots have no raised edges and are very shallow and so cannot be felt, they are very similar to micro-fine surface marring. They cannot be removed from the surface by washing but they can usually be removed with a slightly abrasive chemical paint cleaner
Note: Vinegar is a liquid produced from the fermentation of ethanol in a process that yields its key ingredient, Acetic (Ethanoic) acid, pH 2.7
There are two categories of water mark (the so-called water spots)
Stage I (Surface) Corrosion
[: defined as a surface with light to moderate corrosion damage to the paint surface]
Stage II (Sub-surface) Corrosion
[: definition when the dirt/corrosion deposits are no longer on the surface but have started to break down the molecular structure, leaving an etched or white haze on the surface( a concave circular mark ) after the stain has been removed, with moderate to serious paint damage]
TOGWT is offline   Reply With Quote
Old 05-30-2012, 08:23 PM   #13
Killrwheels@Autogeek
Platinum Supporting Vendor
Killrwheels@Autogeek's Avatar
some product lines like Chemical Guys now offers water spot removers. You can also find ingredients in products like ONR (Optimum No Rinse) which soften water and said to help in reducing some spots. But vinegar is often used without issue also.
__________________
Use coupon code CORVETTEFORUM for 10% off most car care products at www.autogeek.net (some exclusions apply)
FORUM VENDOR FOR MORE THAN 10 YEARS !
Killrwheels@Autogeek is offline   Reply With Quote
Old 05-30-2012, 09:25 PM   #14
SnakeBT6
CF Senior Member
SnakeBT6's Avatar
Thanks guys..Im off for the rest of the week and will try the vinegar tomorrow to see how it works.
If no luck Ill take it to a detailer.
Old 05-30-2012, 10:13 PM   #15
Rich98
CF Senior Member
We're are you located in NY?
Old 05-30-2012, 11:47 PM   #16
SnakeBT6
CF Senior Member
SnakeBT6's Avatar
Im in NYC, and have a weekend place in Moriches. Keep the car out there.
I actually had it detailed at TKO Corvettes in Bayshore a month ago. They used Adams products, and I really liked the finish when it was done.
I bought Adams glaze and wax and do a section or two here and there after washing and it keeps it looking fantastic.
Old 05-31-2012, 07:08 AM   #17
Rich98
CF Senior Member
Didn't know Ed does detailing, ok.
I'm in Hicksville if you ever want it looked at.
Old 05-31-2012, 10:19 AM   #18
SnakeBT6
CF Senior Member
SnakeBT6's Avatar
Thanks..actually wont get out there until Sunday.
He called a guy in to do it while I waited..they put it up on his lift and the guy really did a nice job.
Just hate the fact that I may have to get it done again.
Ill keep you posted.
Old 06-08-2012, 05:22 PM   #19
0David-Fermani
Former Vendor
St. Jude Donor '12
While I don't know how deep the detailer had to cut, the good thing is that Vettes have lots of clear from the factory. You should be fine
David-Fermani is offline   Reply With Quote
Reload this Page Will using distilled white vinegar harm paint finish?
Tags
car, cars, distilled, finish, harm, harms, hurt, interior, older, paint, pant, vinager, vinegar, wax, white
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
