terry or foam for 3M scratch remover?
Hey guys,
I bought a random orbital buffer tonight and some 3M scratch remover...should I use a terry cloth or foam pad? The directions on the bottle say terry for hand use and a "compounding pad" for machine application. WTF is a "compounding pad"? What do you guys use?
Also, any tips. This is my first crack at this stuff. Thanks.
Uber Waxer
3m scratch remover? is it the perfect-it swirl remover? or something else?
i always use a foam pad with 3m glazes, but back in the day i used a terry pad with my orbital on my old 87 crx and it worked ok too.
Originally Posted by Prosecutor
Hey guys,
"3M™ Perfect-It™ II Foam Polishing Pad Glaze and Swirl Mark Remover 39009"
That is the Fine Cut Rubbing Compound which is way more abrasive than the correct product which is 3M Perfect It II Swirl Mark remover part number 39009 or the newer Perfect It III Swirl Mark remover which is part number 39012 (I am now using the 39012 until the new Zaino Paint Cleanser and Swirl Mark Remover comes out in several weeks)
Cool, thanks for letting me know. Good thing I didn't use it yet. I will return it and get 39009 or 39012. Thanks.
Uber Waxer
i would get the PI3 39012 glaze and a foam pad for light scratches. it wont make as much mess and is alot easier to wipe off.
I also have a bottle of McGuire's Scratch-X sitting around....is that too harsh?
Thanks for your response.
I've tried scratch X and also found that it did nothing at all, no matter how many applications I used.
The 3M rubbing compound is fantastic ! don't throw it away. Don't need a buffer to use it -- just use a terry cloth towel by hand. Sure, if you have the lightest of scratches, the 3M swirlmark remover may be good enough for ya, but keep the rubbing compound around -- you'll need it for any tougher scratches or water marks. Check the great results I got here
I saw that other thread....looks like it did a great job for you. Thanks for your reply. I was concerned that the rubbing compound was too harsh...apparently it will be alright, especially if I can follow-up with swirl remover.
