Car wash swirls
Location: Austin, Texas Codes 660, 9448, and 295660 work in the C6 navigation unit. No DVD playback yet.
Try throwing out the Z5, and use 3M's Swirl Mark Remover, then Zaino on top of that.
It's better to actually remove the swirls than to try to cover them up with something that doesn't work anyway.
This may help....
http://autopia.org/kb/index.php?page..._v2&id=32&c=16
another....
http://autopia-carcare.com/freeguide.html
There are many ways to skin.... well, you know.
another....
Meguiar's #83 Polish is the strongest polish sold over the counter in the US so Meguiar's told me. It is hard to find so I bought mine from the Meguiar's website. I have uded it and LOVE IT! It would also be helpful if you apply it with an Orbital Buffer. When it starts to dry, wipe it off and apply fresh polish until you no longer see the scratches. It works when liquid not when dry. One of the benefits of #83 is you will remove a goodly amount of orange peal with one application. It will take you several applications but eventually even that will disappear.
Every Black car should have a bottle of Meguiar's #83 on the shelf. Dirt in a washers mit can cause great damage to your cars paint.
Dan
Dan
Buy a Porter cable random orbital polisher and an appropriate polish of your choice
Get the PC 7336 $99 ay Lowes.
Visit www.properautocare.com for detailing instructions
and read their recommendations.
I prefer Mezerna polishes.
It is gonna take many coats of Z-5 to fill in those swirls
Originally Posted by Top Cat
Try Zaino Z5 then Z2 and Z6.
It is just about impossible to avoid the swirl marks and scratches on a car.
St. Jude Donor '06
Originally Posted by LS WON
Z-5 is only for very minor swirls n scratches and yet it will take a few coats..
If you use the cut-in polishers regularly you will not have any paint left to remove after a while.
WRONG ! Z5 only has light "fillers" that are meant to hide some swirls and marring. To remove them as asked, calls for a polish to remove some (very little) clearcoat and these marks. People have polished more than 20 times without seeing a reduction in clearcoat with professional measuring devices, but that is not to say that you should not start with the least aggressive polish and then move forward as only necessary.
As for keeping the paint from adding additional marring, try to use a good car wash soap (lubrication), a good microfiber to help remove contaminents away from the paint, and drying with waffle weave type products to reduce sand/dirt/dust being dragged across the finish.
If you are looking for some good polishing lines ... look to Poorboys, Einszett, or Menzerna. All user friendly and great results for the novice or professional alike.
St. Jude Donor '06
Originally Posted by Killrwheels
WRONG ! Z5 only has light "fillers" that are meant to hide some swirls and marring. To remove them as asked, calls for a polish to remove some (very little) clearcoat and these marks. People have polished more than 20 times without seeing a reduction in clearcoat with professional measuring devices, but that is not to say that you should not start with the least aggressive polish and then move forward as only necessary. .............
I would agree with you if the car has not seen any TLC for a while and swirls, scratches etc accumulate on top of ech other. In that case the more practical way to remove them would be removing some of the finish.
The thread originator however did not elude to such conditions. His thread adresses car wash swirls. My assumption is that we are talking of light swirls. My opinion remains Z-5. Multiple coats will build-up the surface to optically hide them. Again, what I said in my previous post was frequent use. The idea is to get ahead of the game and not let the stuff accumulate. It doesn't take more than a couple of hours from start to finish and is good exercise anyway!
Dan
Dan
But, to answer the thread starters question. You need to polish out the swirls. two great products for that have been mentioned. Megs #83 DACP, or 3M swirl mark remover. For best results should be a pplied with an orbital buffer and polishing pad. And then top with you favorite glaze, wax etc...
Also while Zaino offers an optically pure finish in its Z2 line, the addition of even light fillers makes the finish less than pure in the Z5 line. I would want (and do) put only the best product on top of a pure or scratch free and properly prepped finish. As for time, it makes no difference to wash, clay, polish are rewash prior to sealant as to adding xx layers of one product like Z5.
Here is what the originator questioned:
How do I remove the Car Wash swirls from my Clear Coat?
That is exactly what I use.
That's very true. If there is a secret to a swirl free finish, is to use the products I mentioned (Z5, Z2, Z6) regularly and be cognizent in your cleaning/washing practices to minimize accumulation of swirls.
This is true Zaino Z-5 is only a filler not a scratch remover.
