Garage lift?
Garage lift?
Thinking of getting a lift for my garage (4 post) so i can get a third car inside and be able to do a lot more work on my cars myself.
Anyone have recommendations for local suppliers?
I went with a Bendpak lift.
I decided on this because of the method on which the lift actually locks to the posts. As well it has a secondary locking system which is nice for just incase..
Alittle more then a direct lift, but cheaper then a rotary lift.
http://www.babco.ca/Automotive-Equip.../BendPak-HD9ST
Oakville- the Lift superstore. Uses motors from the u.s., not China like some others
If your floor is perfectly level, you should not need to lag it down. If yours is slightly sloped like mine is, the posts walk slightly as you raise and lower the vehicle. I have added one 1/2" lag to each corner and it has not moved.
I've had my Bendpak approaching ten years and no issues.
Mine is bolted down as I have a sloped garage slab, but wouldn't feel comfortable working under the hoist/car without it being bolted down.
I had them Liftsuperstore install mine.
Only thing i needed was to extend the alum ramps, due to the car being lowered and the APsis front lip.
cheers.
my slope was more than code so all 16 were anchored. Regardless, spend the extra on the 'half the weight of steel ramps' and buy the aluminum ones. Well worth it for $3-400
