C6 will not start
C6 will not start
Hello all in need of some help. All I get is a clicking sound when I try to start my 2005 c6. When I put the charger on it the alarm will go off. So then I took the connection off , charge the battery it's new put the connection back on and all I get is a clicking sound right a way. And the light on the hood flashes with ine clicking sound.
Sounds like a bad battery cell ...
If you press the start button, with out trying to start the car ... keep feet of the pedals ... the car will cycle through it's internal diagnostics ... and you should be able to check the battery volt reading on the DIC ... if it is below 10, the car will not allow the starter to engage.
The hood light, is it going out? That's a good sign that the voltage is dropping. Sounds like either a bad battery or a bad connection in the main wiring of the car - battery negative to ground or battery positive to fuse blocks or starter solenoid.
Canadian Events Coordinator
Received 1,508 Likes
Hajie: do the simple check first, i suspect battery either not fully charged or internal short (bad battery), disconnect your old battery and hook up battery booster (not trickle battery charger) or a good battery.
If still no start, than check battery voltage (note down), check voltage at trigger wire i think its purple on starter (someone needs to try start the car while you checking voltage there)....no voltage or more than .5 voltage difference measured at battery terminals than now trace that purple wire for somewhere breakage or heavy resistance...this purple leads to ign switch.
Once car started and you still have battery drain next day or within few hours than gotta check out parasitic draw test......thats later part dont go there until you figured out starting issue.
is relays (passenger foot well) clicking while you start the car?
Thank you all for all the help. Today I came home and try to boost the car had my yukon running then when I connected the jumper cable to the car the horn started to go off . So I pulled the fuse. Then all the lights started to flash the starter clicked and that was it still will not start. So tell me if I am wrong that tell me the car battery was dead again I got this battery in July . When I disconnect the boost cable I can still hear that ticking noise some were in the fuse box.and it stop when the battery was dead again.
what make sense? i am not alone even kick *** high fi fancy place do the same chit, even on nice euro cars....heck visit GM dealer too....with the labor time reduced and on top reduced warranty work.....and mechanics over there work on flat rate system....he dont gave a chit either, charge the dam thing and do a quicky job and he moved on to another car....they gotta make money, this is the reason i work for private garage we do lot better than at GM dealer, not saying mechanics over there are ****** nope, they get paid on flat rate system....and these days most dealership reduced labor rates plus warranty work is big time sucks (less hr paid than regular customer pay).
Hajie: Disconnect the current battery and connect with your yukan battery and see what happens....if lights are on and many things are ON than something is shorted or some electrical circuit is getting powered.....
If relays are clicking than not enough battery juice period. Isolate your existing battery and hook up with your yukan battery by itself.
No start is hard to trouble shoot through private forum or even messaging, if you are not DIY guy and not enough tools i would tow to mechanic shop.
Up date to all that help. Came home and hook up the new battery that CT give me, and boom she fired right up. So I am going to have a test done to see why the battery is draining when the car is not in use. I will give you all the answer on sat.
Former Vendor
2005 6spd manual Corvette's need to be in reverse gear when parked or the battery will drain . This might be the cause of battery problem
Glad it worked for you, i never put the gear in reverse sometime in neutral with emergency brakes pulled sometime in any gear...may be i am lucky or battery is too good. I use Interstate battery 640 CCA.
If you still have battery drain than pm me your number i walk you thru how to check parasitic draw test, all you need is DVOM meter and small plier and 4" plastic clamp and start checking fuses. connect meter in amp mode and when connected across B+ and B- should read less than 50ma if more than that you have draw somewhere, start pulling fuses, when you pulled a particular fuse and amp reading less than 50ma you have that draw follow that fuse (ckt) some switch must be ON.....
