Non-Starter
Non-Starter
Help! Anyone have any ideas? My car won't start only with a boost. Battery tender on all winter. Battery appeared dead. Put a charger on overnight, it says the battery is fully charged but no start. Just clicking and then nothing. When I boosted it, I drove around fo 1/2 hour. Ran perfectly. Then no restart! 2010 GS vert with 8,000 klicks. I can boost and get back to the dealer but I'm wondering if any of you know about similar issues? Fuses, relays etc.
Just a thought. Best of luck.
Toronto Events Coordinator
Take jags offer
Ian
I'd be suspicious of that battery tender. It might have failed, over charging the battery all winter, cooking it and boiling it dry. This seems to be a common failure mode of the Deltran Battery Tender brand.
Can you open the caps on that battery to see if it's a little dry inside?
Hi Mike. I'll be home by 1:30 if you're available. I can't believe battery is junk already, but you never know....posts look clean and no corrosion. put hands on both posts and one isn't heating up as if there is one loose and excess resistance. So I'm totally baffled. If I have to get a new battery I will. Hopefully I can get one today somewhere.
Thanx to Raggdoll for stopping by and confirming what everyone's saying! New battery needed. Hop it's warrantied. I'll be calling the dealer first thing. Friday I was able to boost it and it started right up. Hopefully it'll do the same tomorrow. Fingers crossed.
Hope you get a warranty on the battery.
