Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-21-2008, 02:18 PM   #1
1971Coupe
CF Senior Member
1971Coupe's Avatar
Default C3 guys....what oil do you use?
1971Coupe is offline   Reply With Quote
Old 12-21-2008, 02:47 PM   #2
vettali
CF Member
vettali's Avatar
Hey Romeo ,I use Bertolli imported from italy. Did you finish cleaning the driveway?
vettali is offline   Reply With Quote
Old 12-21-2008, 02:57 PM   #3
1971Coupe
CF Senior Member
1971Coupe's Avatar
Quote:
the driveway is clean, the snowblower works great......I also did the whole street.
Old 12-21-2008, 03:01 PM   #4
1971Coupe
CF Senior Member
1971Coupe's Avatar
Rob
at least you won't be seeing any snow for a few weeks....bastardo
Old 12-21-2008, 03:12 PM   #5
vettali
CF Member
vettali's Avatar
Romeo, mabye you can plow a strip of road then take the car for a spin.
Old 12-21-2008, 05:42 PM   #6
7t2vette
King Of The Shyte Wolves!
Support Corvetteforum!
7t2vette's Avatar
All you hydraulic and solid flat tappet guys should be using an oil with a high ZDDP content, or oil plus a ZDDP additive. You run the risk of losing a cam lobe(s), I did and it trashed my old engine! Diesel oil used to have an appropriate amount of ZDDP in it, but I think even that might have changed.
I am now running a roller cam, so I am not too worried about it anymore. I am thinking about switching to full synthetic 5w50.
7t2vette is offline   Reply With Quote
Old 12-21-2008, 06:08 PM   #7
Airwilf
CF Senior Member
Airwilf's Avatar
Default Oil
They put fresh Mobil 1 in the day I bought it in late September,but may switch over to Pennzoil Platinum this spring.Any filter preferences?
My oops! Altho I have a C6, I mistakenly answered a C3 post.
__________________
08 C6 Coupe, 6 spd, 436 hp, All options, Grins-Priceless!
Airwilf is offline   Reply With Quote
Old 12-21-2008, 07:42 PM   #8
1971Coupe
CF Senior Member
1971Coupe's Avatar
Bruce
Rotella T 15W40
Old 12-21-2008, 08:02 PM   #9
gdh
CF Senior Member
have been running 5w50 synth for a few years although did not get the vette out even once this past year. When I get around to freshening up with a cam change will go back to dino oil for the break in then likely back to 5w40 or 50 synth.
gdh is offline   Reply With Quote
Old 12-21-2008, 08:09 PM   #10
7t2vette
7t2vette's Avatar
Quote:
Originally Posted by 1971Coupe View Post
Bruce
Rotella T 15W40
Romeo, I may be wrong, but I believe even that oil has reduced levels of ZDDP.
Old 12-21-2008, 09:15 PM   #11
Patman
CF Senior Member
Patman's Avatar
Quote:
I use the NAPA Nascar Select oil filters on my cars, they are very reasonably priced ($5 for my wife's Civic, and around $7 for my C5) and well built filters.
Patman is offline   Reply With Quote
Old 12-21-2008, 09:28 PM   #12
7t2vette
7t2vette's Avatar
Quote:
Hey Pat, what's a good quality 5w50 synthetic oil?
Old 12-21-2008, 09:39 PM   #13
CanadaGrant
CF Senior Member
CanadaGrant's Avatar
If I'm not mistaken, these filters are made by Wix and you can't get much better than that.
I use 10-30 synthetic in my C-3 but it's a roller.
CanadaGrant is offline   Reply With Quote
Old 12-21-2008, 10:35 PM   #14
Glass Act
CF Senior Member
Glass Act's Avatar
Location: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I use Pennzoil 20W/50 racing oil, second highest rated in ZDDP. I believe Quaker State Q racing is the highest with Rotella T at 3rd highest. Most diesel oil's are rated high in ZDDP also.
I tear down my engine every winter and no signs of camshaft / lifter wear with the Pennzoil racing oil yet and I'm sure there are others who have good results with other oil brands
Glass Act is offline   Reply With Quote
Old 12-21-2008, 11:55 PM   #15
1971Coupe
CF Senior Member
1971Coupe's Avatar
Quote:
does Canadian Tire carry the Pennzoil racing oil? or where do you get it?
Old 12-21-2008, 11:55 PM   #16
Patman
CF Senior Member
Patman's Avatar
Quote:
There really isn't a lot of selection when it comes to that viscosity, as not everyone makes it anymore. Mobil 1 and Castrol both have a 5w50, and I know Quaker State used to sell one also but I haven't seen that in a while. Pennzoil also used to make a 5w50 synthetic, but I believe they stopped that also.
If it were me I'd go with the Castrol 5w50, but that's because I'm really not a big fan of Mobil 1 products. I haven't seen that many oil analysis reports with 5w50 oils since it's not a viscosity recommended by any new car makers, but I have seen a couple of reports with Castrol 5w50 over the years and it's shown to be a good oil. It does thin out to a 5w40 but then again most 5w50s will, as that's quite a large viscosity spread and it uses a much larger amount of viscosity index improvers to acheive it.
Old 12-22-2008, 12:27 AM   #17
7t2vette
7t2vette's Avatar
I'll give the Castrol synthetic 5w50 a try; thanks.
Old 12-22-2008, 01:01 AM   #18
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Mississauga, Ontario I know all the answers it's the questions I don't understand
Even with roller cam you still need the ZDDP I use Brad Penn semi synthetic racing oil 20W50 it's about 8 bucks a litre
1500 ppm Zinc (Zn) and 1340-1400 ppm Phosphorus
http://www.bradpennracing.com/
__________________
1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust
Paint by Dream Car Garage
MotorHead is offline   Reply With Quote
Old 12-22-2008, 10:43 AM   #19
gdh
CF Senior Member
I had no issues with the Castrol Bruce for 3 years, when I started to pull the cam all looked well.
Old 12-22-2008, 05:18 PM   #20
Glass Act
CF Senior Member
Glass Act's Avatar
I get mine at NAPA, I've also seen it at our local Parts Source store, which is a spinoff of CTC. From NAPA a pay $34.00 + tax for a case of 12 for the Pennzoil Racing. Hope this helps.
Glass Act
Reload this Page C3 guys....what oil do you use?
Tags
1971, c3, corvette, oil, vette, weight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ok it's time for a oil and filter change what do most of you use? wildman378 C3 General 28 05-04-2005 09:56 AM
C3 racing oil pans who runs what set-up? Solid LT1 C3 Tech/Performance 12 04-30-2004 02:52 PM
TOOLS.... Randy 71 C3 Tech/Performance 24 03-23-2004 11:02 AM
What do you guys think about this price for rear main seal replacement? nada C3 Tech/Performance 15 06-05-2003 01:09 PM
Merlins car on ebay?!? ZD75blue C3 Tech/Performance 80 01-28-2003 12:18 PM
What's the best gear oil to use for the tranny/rearend??? Ryan77 C3 Tech/Performance 12 12-27-2002 08:59 PM
Are the K&N air filters worth it? hudman C3 Tech/Performance 34 10-31-2002 09:05 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
