Fired up the 427ci small block !
Posted this over in C3 general but I know most of you don't go there and there are a few that still like the Gen 1 SBC
Fired up the 427ci small block this evening. Started up right away. It sounds pretty mean. It runs smooth and the idle is lumpy enough to scare off even the seasoned ricer
Anyway I will post a video but it was too late tonight to start revving it up. Also have to the hydroboost brakes working before I can take it for a spin, I am a happy camper !
All I hear these days is LS this, and LS that. It's nice to see old school once in a while. I love the SBC1 engine's.
Good to see you went with the AFR Eliminator's. What are the other specs on this motor?
I have to get the new hydroboost brakes up and running and I should be good to go in a few days, here's a more complete list of parts :
- World Motown 400ci small block, 350 mains with splayed billet caps,
- AFR 227 Eliminators with port matched Vic jr. intake by AFR
- T&D Shaft Rockers, 1.6 ratio, Manley .080" wall pusrods and
- Comp Cam small base circle Endurex solid roller lifters
- "Classified" solid billet roller, small base circle lift .650" "ish", dur. 250 "ish"
- Callies DragonSlayer crank, 350 mains, 4 inch stroke
- Eagle stroker rods with ARP 2000 bolts
- Mahle pistons, with chromoly faced rings
- ATI Race Super Dampner
- CVR billet timing cover
- CVR mini starter
- Cloyes timing set with encapsulated torrington bearing
- Melling HV oil pump
- Milodon 7 qt oil pan
- Edelbrock Victor water pump
- Hays lightweight ( 25lbs ) billet steel flywheel
- Center Force clutch
- MSD Digital E-Curve Pro Billet distributor
- MSD Super Conductor wires
- 825 Drag Race Demon carburetor
- Hooker Super Comp header into 3in. SS mandrel bend exhaust
Location: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
I hear ya, and there is no end to new high tech parts for these motor, I even have a roller fuel pump rod
- CVR mini starter
- Hooker Super Comp headers into 3in. SS mandrel bent exhaust
- CVR mini starter
Diod you buy the short block from Motown or did you build it ? I have one of their 454 SBC crate motors . I was wondering what you thought of theshort block? I wish I had those heads on my motor. Engine look killer.
Wayne
Wayne
Putting that aside the motor you have sounds like a beast.
