Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-04-2008, 02:36 PM   #1
electric_yogurt
CF Senior Member
electric_yogurt's Avatar
Default Techron substitute in Canada ??
Anyone know of a good substitute for Techron that can be used that's available in Canada?
I've tried a couple different products, but they didn't seem to work, my gas gauge still drops to empty when it gets to between 1/2 & 1/4 full.
thanks
electric_yogurt is online now   Reply With Quote
Old 05-04-2008, 05:11 PM   #2
Sweet 90
CF Senior Member
Sweet 90's Avatar
thanks
Don, as far as I know Techron is a cleaner, are you hoping for it to fix your sending unit?
Jim
Sweet 90 is online now   Reply With Quote
Old 05-04-2008, 08:09 PM   #3
FFIN90
CF Senior Member
CI 6-7-8-9-10 Veteran
Support Corvetteforum!
FFIN90's Avatar
Location: ================ From a Fire Hall in Toronto ================ 9/11/01 FDNY 343 R.I.P.
Send a message via MSN to FFIN90 Send a message via Yahoo to FFIN90
You have a PM.
FFIN90 is offline   Reply With Quote
Old 05-05-2008, 12:03 AM   #4
electric_yogurt
CF Senior Member
Quote:
Jim
That's exactly what I'm hoping for. A lot of the US guys swear by it.
Old 05-05-2008, 12:04 AM   #5
electric_yogurt
CF Senior Member
Quote:
Originally Posted by FFIN90 View Post
You have a PM.
And you.
Old 05-05-2008, 12:21 AM   #6
GettReal
CF Senior Member
GettReal's Avatar
Techron will help but what helped for me was NOT using Petro or Shell gas.. the sulphur content was too high or something like that and was causing mine to do it as well. Since Ive switched to Sunoco or Esso, it never happens, going on a couple years now.
GettReal is offline   Reply With Quote
Old 05-05-2008, 12:28 AM   #7
electric_yogurt
CF Senior Member
I thought about the gas bit because normally I do buy Shell, but the last 4 fill-ups I've been using a different station and the problem has gotten worse. Before, the gas gauge would go dead only occasionally when the tank got really low (ie at the low fuel warning), and now it's doing it every time once the tanks hits about the 1/2 full mark.
Old 05-05-2008, 12:33 AM   #8
GettReal
CF Senior Member
GettReal's Avatar
try JUST sunoco for the next month. Tons of vettes went through this and dealers replaced sending units, clusters and a bunch of other things and it would still drop[. Before I went through all that, I switched gas....and as I said, its been fine.
Old 05-05-2008, 12:45 AM   #9
electric_yogurt
CF Senior Member
Quote:
Er, we don't have Sunoco's out here in the wild west.
Old 05-05-2008, 12:48 AM   #10
GettReal
CF Senior Member
GettReal's Avatar
scratch that... make it Esso for one month
Old 05-05-2008, 12:56 AM   #11
CanadaGrant
CF Senior Member
CanadaGrant's Avatar
I asked the parts guy at GM about this and he said that it isn't just Corvettes with the problem. I was looking for Techron and wondered if he had any info. My 02 Z has been doing this off and on for a couple of years. Driving along with a half a tank and the bells and whistles go. He told me that when I put it up for the winter (this was last fall) I should pour in about four bottles of GM injector cleaner. No problems since.
Grant
CanadaGrant is offline   Reply With Quote
Old 05-05-2008, 01:10 AM   #12
Sweet 90
CF Senior Member
Sweet 90's Avatar
I didn't know that. Is this more of a problem with C5's & C6's
or all generations?
Jim
Old 05-05-2008, 03:06 AM   #13
clayton1
CF Senior Member
clayton1's Avatar
TheBigEarl85
Why dont you just fill up at chevron??!!
Shell did it to me too, didnt have a choice-no chevron up in FSJ.
Since Ive moved and use chevron exclusively,I have no issues.
clayton1 is offline   Reply With Quote
Old 05-05-2008, 07:50 AM   #14
Patman
CF Senior Member
Patman's Avatar
Same here! My fuel gauge would drop to zero a lot when I first got the car and was using Shell, but I've been using Sunoco almost exclusively since then and it's been probably two years since my fuel gauge acted up on me. I never add fuel injector cleaner.
__________________
Black 98 C5 (3.15 A4)
208,000 km
Best ET-12.81 at 109.4 mph (1.98 60ft)
Stock except for Vararam & tuning
Patman is offline   Reply With Quote
Old 05-05-2008, 09:31 AM   #15
electric_yogurt
CF Senior Member
Quote:
Grant
Never thought to check if GM had a recommended product.
Old 05-05-2008, 09:33 AM   #16
electric_yogurt
CF Senior Member
or all generations?
Jim
C5's of the vettes mostly but other GM vehicles too. My buddy's wife's Suburban(?) does it all the time too.
Old 05-05-2008, 09:34 AM   #17
electric_yogurt
CF Senior Member
Er, we don't have Chevron's out here in the wild west.
Old 05-05-2008, 09:38 AM   #18
Miaugi
CF Senior Member
Miaugi's Avatar
Go right to the source....head on over to the tar pits and get a fill-up there....that should fix 'er up!
Miaugi is offline   Reply With Quote
Old 05-05-2008, 10:27 AM   #19
DigitalZ
CF Senior Member
DigitalZ's Avatar
Techron removes the sulphur deposits that build up on the sending units from poor quality gas or gas with elevated sulphur content. Found out about it at a tech session at Carlisle last year. It is readily available in the US including Walmart. I picked up a bunch for myself and others last year on one of the trips over the border.
This post from last year was indicating that it should be available now over here.
http://forums.corvetteforum.com/show....php?t=1840357
DigitalZ is offline   Reply With Quote
Old 05-05-2008, 11:24 AM   #20
CanadaGrant
CF Senior Member
We have Chevron out here in BC. I use Chevron 94 octane exclusively but still had the gauge problem with my C5.
Reload this Page Techron substitute in Canada ??
Tags
atlantic, buy, calgary, canada, chevron, cleaner, corvette, esso, fuel, ontario, petro, racing, sending, techron, toronto, unit
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
