01-03-2008, 10:29 PM
CF Senior Member
That article is actually a little old. Sources now all point to a LSA making 550ish HP.
I still hope for 600hp since Bob Lutz promised unexpectedly high HP for the CTS-V and that it'll suck the doors off the M5.
__________________
2004 Cadillac CTS-V (Garage Queen)
- 222/226 cam, B&B full exhaust (LT headers, cats, X-pipe, mufflers), Hotchkis sways, B&M shifter, gForce race axles, Z06 FRCs, some other stuff...
2009 Cadillac CTS 3.6DI 6-Speed (Daily Driver) - Magnaflow
01-03-2008, 10:42 PM
CF Senior Member
I'm still hopin they just transplant the same LS9 in the ZR-1 into the CTS-V.
And if it's a detuned version, all their going to likely do is to install a larger pulley for a lower boost level.
And we all know how quick and simple that would be to change.
Will they have the new CTS-V at the Toronto Auto Show this year?
01-03-2008, 11:18 PM
CF Senior Member
May have to trade in the "Physco Chryco" on this new winter beater!!!!--Does it come in "Rustic" grey?????? Heheheheheheh!!
01-04-2008, 11:14 AM
CF Senior Member
2 door coupe version coming in June to! Can't wait to see this puppy.
01-05-2008, 02:40 AM
CF Senior Member
Quote:
Originally Posted by
tlaselva
I have heard that the pulley will be almost untouchable. You'd hafta take the whole blower out of the engine and apart to change it.
Not sure if it will be in Toronto. It will be at NAIAS though. I'm going there to see it
__________________
01-05-2008, 09:16 PM
CF Senior Member
Jon04CTSV
Ya, I'm going too. Got a deposit on a ZR-1, but if the CTS-V has the same driveline, I might just flip to a Caddy.
01-08-2008, 02:35 PM
CF Senior Member
Originally Posted by GM.MEDIA.COM
2009 CADILLAC CTS-V: PRELIMINARY SPECIFICATIONS
Overview
Model:
2009 Cadillac CTS-V
Body style / driveline:
rear-drive four-door high-performance luxury sedan
Construction:
unitized welded steel body with direct-mounted front cradle and rubber-isolated, multi-link independent rear suspension assembly
EPA vehicle class
midsize car
Manufacturing location:
Lansing Grand River Assembly, Lansing, Michigan
Key competitors:
BMW M-5, Mercedes Benz E55 AMG, Mercedes Benz E63 AMG
Engine
Type:
6.2L supercharged V-8 (LSA)
Displacement (cu in / cc):
376 / 6162
Bore & stroke (in / mm):
4.06 / 103.25 x 3.62 / 92 mm
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, 2 valves per cylinder;
0.492-in (12.5 mm) lift
Supercharger:
Gen. 6 R19 with single brick intercooler; 1.9L displacement w/4-lobe rotor design
Fuel delivery:
SFI; center feed
Ignition:
direct-mount ignition coils; extended-life dual platinum-tipped spark plugs
Compression ratio:
9.0:1
Horsepower (hp / kW @ rpm):
550 / 410 @ 6200 (est)
Torque (lb-ft / Nm @ rpm):
550 / 745 @ 6200 (est)
Recommended fuel:
premium recommended but not required
Maximum engine speed (rpm):
TBD
Additional features:
pan-mounted oil cooler; cast pistons; high-flow cylinder heads; block-mounted piston squirters; steel crankshaft w/ 8-bolt flange; close-mounted converters; acoustic engine cover; E67 engine controller
Estimated fuel economy:
TBD
Transmissions
Type:
Tremec TR6060 six-speed manual; fully synchronized with single overdrive
Hydra-Matic 6L90 six-speed electronically controlled automatic overdrive with torque converter clutch
Gear ratios (:1)
First:
2.66
4.02
Second:
1.78
2.36
Third:
1.30
1.53
Fourth:
1.00
1.15
Fifth:
0.80
0.85
Sixth:
0.63
0.67
Reverse:
2.90
3.06
Final Drive Ratio:
3.73
3.73
Chassis & Suspension
Front suspension:
independent SLA; 29-mm hollow stabilizer bar; elastomeric handling and ride bushings; 65-N/mm spring rate; Magnetic Ride Control with electro-magnetically controlled shocks
Rear suspension:
independent SLA; 24-mm solid stabilizer bar; elastomeric trailing arm bushing; 90-N/mm spring rate; Magnetic Ride Control with electro-magnetically controlled shocks
Wheels:
19 x 9-inch; forged alloy, 5-lug (front)
19 x 9.5-inch, forged alloy, 5-lug (rear)
Tires:
255/40R19 Michelin PS2; summer Z-rated (front)
285/35R19 Michelin PS2; summer Z-rated (rear)
Brakes:
four-wheel disc with four-channel ABS, hydraulic brake assist and dynamic rear brake proportioning
front rotors:
vented; co-cast; 380 mm x 32 mm
rear rotors:
vented; 373 mm x 28 mm
front calipers:
aluminum; six-piston
rear calipers:
aluminum; four-piston
Steering:
power-assisted rack-and-pinion;
Steering ratio
16.1:1
Turns lock-to-lock
TBD
Turn radius (ft / m)
37.9 / 11.55
standard: StabiliTrak (four-channel, four mode); traction control; engine drag control
optional: Performance Traction Management
Dimensions
Exterior
Wheelbase (in / mm):
113.4 / 2880
Overall length (in / mm):
191.6 / 4866
Overall width (in / mm):
72.5 / 1842
Overall height (in / mm):
58.0 / 1472
Track (in / mm):
front: 61.8 / 1570
rear: 62.0 / 1575
Curb weight (lb / kg):
manual: 4200 / 1905 (est)
automatic: 4300 / 1950 (est)
Weight distribution (% front / rear):
54 / 46
Approach Angle (deg)
10.4
Departure Angle (deg)
18.3
Tumblehome (deg.
24.6
Interior
Headroom (in / mm):
front: 38.8 / 986
rear: 37.2 / 944
Leg room (in / mm):
front: 42.4 / 1078
rear: 35.9 / 913
Shoulder room (in / mm):
front: 56.7 / 1441
rear: 57.4 / 1390
Hip room (in / mm):
front: 55.1 / 1400
rear: 54.1 / 1375
Capacities
EPA passenger volume (cu ft / L):
98 / 2775
EPA trunk volume (cu ft / L):
13.6 / 385
Trailer towing maximum (lb / kg):
TBD
Fuel tank (gal / L):
18.0 / 68
Engine oil (qt / L):
TBD
Cooling system (qt / L):
TBD
Seating Capacity (front / rear)
2 / 3
Drag Coefficient
0.355
__________________
01-08-2008, 02:50 PM
CF Senior Member
Humm, the only difference I see is they put the 1.9 TVS blower, where the ZR1 is getting the 2.3. Guess that's where the 70Hp loss is from.
01-09-2008, 02:51 AM
CF Senior Member
01-10-2008, 11:12 AM
CF Senior Member
01-10-2008, 12:17 PM
CF Senior Member
I love this car man! Gotta love competition
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
