Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-02-2008, 11:52 PM   #1
dlynch
CF Senior Member
dlynch's Avatar
Default [OT] Advice--Nissan Maxima problems SOLVED!
Edit: A happy ending!
Thanks for everyone's help here. I gave Roy your suggestions, and links to a forum or two...he found others on the forums that had the same problem...intermittent power loss.
Turns out he had a bad coil. He found the right one when the car was low on power by removing the power lead for each. When the engine was misbehaving, No 1 cylinder there was no loss of power with the power lead removed. Therefore, it was the culprit! He changed the coil, and problem was solved about a week ago. Took 4 minutes to install; dealer had wanted to change all the coils and plugs for about $1200.
Incredible help here that is truly appreciated!
Regards,
Dave L
We recently helped a friend buy a Maxima (2003)--beautifully kept and maintained car. He's having problems with it. It regularly looses power.
He lives in SW Ontario (St Thomas) and the dealer has found his soft spot. He's spent lots of money on service, and the problem persists.
Do you know any helpful Nissan sites or forums where we can do some research?
They've already replaced the plugs and one coil pack. Next step, according to the dealer, is replacing all the coil packs. Expensive!
Appreciate your help. Nice car, but so far problems with service.
Thanks!
DaveL
Mississauga
dlynch is offline   Reply With Quote
Old 01-03-2008, 12:36 AM   #2
smook
CF Senior Member
smook's Avatar
A good Nissan dealer is 401-dixie nissan.
Give them a try.
-zBill.
smook is offline   Reply With Quote
Old 01-03-2008, 01:48 AM   #3
Cdn Z06 Mike
CF Senior Member
Cdn Z06 Mike's Avatar
Send a message via MSN to Cdn Z06 Mike
Thanks!
DaveL
Mississauga
Check the Cats on the car. What is the mileage?? Did he get an engine code? I assume being in St. Thomas he serviced it at South London Nissan? Drop me a line on my cell, I can help. 905-302-3862
Cdn Z06 Mike is offline   Reply With Quote
Old 01-03-2008, 09:37 AM   #4
LT4Coupe
CF Senior Member
LT4Coupe's Avatar
I have an 02 maxima (daily driver) and have found
this site to be very informative.
http://forums.maxima.org/index.php
LT4Coupe is offline   Reply With Quote
Old 01-03-2008, 09:41 AM   #5
Snobike Mike
CF Senior Member
Another good website is freshalloy dot com.
My wife had a 2002 SE. It was a very nice car. Good Luck.
Snobike Mike is offline   Reply With Quote
Old 01-03-2008, 05:53 PM   #6
JUSTAKAR
CF Senior Member
JUSTAKAR's Avatar
Default Best option
Quote:
Call the number on the post above.......
JUSTAKAR is offline   Reply With Quote
Old 01-03-2008, 07:57 PM   #7
MikeC
CF Senior Member
MikeC's Avatar
If he needs to get some codes read, I have a code reader and am 5 minutes south of St.Thomas.
Gotta love the dealer he looks to be a parts replacer instead of spending sometime on a diagnosis.
Mike
MikeC is offline   Reply With Quote
Old 01-03-2008, 08:31 PM   #8
Cdn Z06 Mike
CF Senior Member
Mike
If you have a coil pack failure it is almost impossible to diagnose which coil it is except for left or right bank with Nissan's. Even under warranty the rule was replace the entire side of coil packs. The other issue is inevitably if you replace one bank, it won't be long before you have to do the other side. Without knowing if any codes are evident or if the problem is intermittant will be a very difficult diag to make. Dealer usually starts with the cheapest route to solve. I can't tell you how many times a fault cannot be reproduced at the dealership so how is a tech suppossed to fix it? Especially when the key has been cycled enough times no codes in storage. Scanning codes is the first step. Hopefully we have a hard code and can go from there.
Old 01-03-2008, 09:50 PM   #9
MikeC
CF Senior Member
MikeC's Avatar
Shouldn't the codes be stored? I was under the impression that once a code is set in an OBDII car, they are there until cleared. I know my Sonoma will not get rid of a code until it is reset (even if I fix the problem.) But I also know my friends Jeep's the codes can go away after awhile, I just figured they stayed in the memory for diagnosis purposes.
Old 01-03-2008, 10:56 PM   #10
dlynch
CF Senior Member
dlynch's Avatar
Thanks all. Just came back and read the responses. Roy is a great friend, hard worker.
Last night I found a link saying that there is a recall for the car.
Here's what I found on the Transport Canada site:
To determine if your vehicle was involved in a recall and has not been corrected, you should contact the manufacturer providing the vehicle's make, model, year and serial number.
Make: NISSAN
Model: MAXIMA
Affected Year(s): 2001 2002 2003
Units Affected: 74143
TC Recall #: 2003267
Manufacturer:
Campaign Code: R86
Recall Details
On certain vehicles, the circuit board for the crank position sensor may have an improper solder joint. This could cause the Service Engine Soon warning light to come on, create a no start condition, cause reduced engine power, or cause the engine to stop running without warning during vehicle operation. Correction: Dealers will replace the crankshaft position sensor and both camshaft position sensors.
I called Roy last night; it was pretty late. Don't know if he's had a chance to call Nissan, or the dealer to see if his car was taken in by the previous owner.
My wife found the car for him, and it's one that we would have gladly bought for ourselves. It was that good. The store that sold it to him has sold cars to us, and they're the best.
I'll let Roy know about my post here.
I truly appreciate your responses, and I'll get in touch with Roy.
Regards,
Dave Lynch
C6 Coupe (Vette content )
Old 01-04-2008, 02:00 AM   #11
Cdn Z06 Mike
CF Senior Member
Make: NISSAN
Model: MAXIMA
Manufacturer:
Campaign Code: R86
Recall Details
Regards,
Dave Lynch
If you send me the VIN# I can check to see if any outstanding recalls are on this vehicle or if it has already been completed and where/when. If the car went to the dealer however I'm sure this would have been the first thing they did. I would have posted the recall but it's 37 pages and applies to multpile model lines. LOL.
Cycling the key can also remove a code sometimes. After a certian # of cycles and sometimes it can be as little as 5 it clears the code.
Old 01-08-2008, 12:08 AM   #12
dlynch
CF Senior Member
dlynch's Avatar
Thanks Mike and others. Incredible help!
I haven't heard from Roy in about a week. He was pretty frustrated when we last talked. His car looks like new! We saw him and his family about 1 1/2 weeks ago in Kitchener for a GTG.
Roy regularly puts 400,000 klicks on cars. Usually on the orginal clutch! His Maxima is almost new with about 80000 klicks or so IIRC. I'm confident there's a simple reason for the issues he's had. And I really respect good tradesmen and technicians.
I'll get his VIN number when I do get in contact with him. He works hard (at the Sterling truck plant in St Thomas). Works lots of overtime.
Regards,
DaveL
Old 01-08-2008, 12:18 AM   #13
dlynch
CF Senior Member
dlynch's Avatar
Thanks so much! It's so detailed and helpful. I think the Maxima is an incredible car. This forum looks so good it reminds me of the Corvette forum!
Thanks for your help,
DaveL
Old 01-08-2008, 12:22 AM   #14
dlynch
CF Senior Member
dlynch's Avatar
Mike
Mike thanksfor your offer of code reading. I've not talked to Roy in about a week. I'll be talking to him soon.
I have no reason to doubt the quality of work at the dealer. I'm not close enough to the problem, and I'm passing on what Roy has toldme. Roy's exprerience has been with Honda's for the most part. He and his wife usually put over 400,000 klicks on a car, and very quickly.
The Maxima has just over 80,000 klicks IIRC, and it looks like new. It'll be a sweet car when this issue gets resolved.
Thanks!
DAveL
Old 01-27-2008, 10:07 PM   #15
dlynch
CF Senior Member
dlynch's Avatar
Default Follow up...
I"ve called Roy about 3 times. Offered to help. Guess he doesn't need any (yet).
Truly appreciate the offers here, and the knowledge and friendship shown.
thanks!
DaveL
Old 02-18-2008, 10:32 PM   #16
dlynch
CF Senior Member
dlynch's Avatar
see edit in first post!
DAveL
Old 02-18-2008, 11:05 PM   #17
Cdn Z06 Mike
CF Senior Member
I'll put money on it more coils to go shortly...that is what history has taught me about these but great to hear he has the problem fixed.
Old 02-19-2008, 10:06 PM   #18
dlynch
CF Senior Member
dlynch's Avatar
Now he knows what to do!
And thanks!
DaveL
Reload this Page [OT] Advice--Nissan Maxima problems
Tags
2001, coil, left, maxima, pack, right
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
