Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-02-2008, 10:49 PM   #1
luvchevs
CF Senior Member
luvchevs's Avatar
Default Is it OK to use an extension cord with a battery tender?
I believe I've seen on the package of some of these devices that they say NOT to use an extension cord?
What do you guys think?
Dave
luvchevs is offline   Reply With Quote
Old 01-02-2008, 11:19 PM   #2
RAGGDOLL
Corvette is King baby!!!
Support Corvetteforum!
RAGGDOLL's Avatar
Location: Whitby..... proud member of the East End Posse, looking for an RFE!
Don't know for sure, but I've always used one with zero issues.
RAGGDOLL is offline   Reply With Quote
Old 01-02-2008, 11:29 PM   #3
4GTABODT
CF Senior Member
St Jude Donor '07-'08-'09
4GTABODT's Avatar
Location: Oakville, Ontario Corvettes were built to be driven...not trailered
Send a message via ICQ to 4GTABODT Send a message via AIM to 4GTABODT
Dave, most manufacturers say you can use an extension cord but they warn against the use of your garden variety type...like the white or brown extension cords you use for an indoor lamp for example. They want to make sure the extension cord being used can handle the juice being pumped through it
Unless yours specifically says "DO NOT USE..." you should be OK
See top of page three of this attachment
http://www.powerwerx.com/download/Pr...tions_LWOB.pdf
PS: Don't ask why I had this bookmarked
4GTABODT is offline   Reply With Quote
Old 01-02-2008, 11:29 PM   #4
dlynch
CF Senior Member
dlynch's Avatar
used an extension cord all last winter...ok here.
DaveL
dlynch is offline   Reply With Quote
Old 01-03-2008, 09:40 AM   #5
dankhts
CF Senior Member
dankhts's Avatar
Battery tenders/chargers draw very little juice, so extention cords are OK, as long as they aren't 100' long!!
If you use an extention cord with a higher draw item, like say, a power washer, then you'll likely have a little trouble as they generally have really long cords to begin with, and say right in the instructions not to use an extention cord....
dankhts is offline   Reply With Quote
Old 01-03-2008, 09:59 AM   #6
SilverSurferC6
CF Senior Member
Send a message via MSN to SilverSurferC6 Send a message via Yahoo to SilverSurferC6 Send a message via Skype™ to SilverSurferC6
Dave
I believe that if you used the heavy-duty type like say the one on your block heater you should be fine. Those are typically over-insulated and and the gage is much greater therefore more resistant to heat from a high draw of current. My Schumacher and Battery Tender Plus both mention that. You should be fine.
SilverSurferC6 is offline   Reply With Quote
Old 01-03-2008, 01:08 PM   #7
WildWilly55
CF Senior Member
WildWilly55's Avatar
Mostly a manufacturer thing---liability!!---these are little transformers remember---while they are converting AC to DC through the coils they generate quite a bit of heat. If they are plugged into a wall recepticle they have all 5 sides exposed for disepation of heat. If they are plugged into an extension cord--generally one side is laying on the ground somewhere--thus causing the coil to build up more heat an possibly creating a fire hazard (in extreme cases!!) As per Mo these units draw .4 -.5 amps tops. Most house current sizing is 15 amps--so power consumption should not play any factor in use of an extension cord. But as Mo pointed out--always use a good extension cord--not your dad's one that is 100 feet long and taped up every 3 feet--and will not lay flat (stretched inner wires)--Here endeth the lesson!!!
WildWilly55 is offline   Reply With Quote
Old 01-03-2008, 05:52 PM   #8
JUSTAKAR
CF Senior Member
JUSTAKAR's Avatar
Default Facts
Dave
If an extension cord can handle say 10amps like every typical awg wire that you find on a cord, then the secondary is... for ease of talking is 10 times less voltage therefore the current could be ten times higher from the device SO in short no battery tender ever outputs 100amps and thus any cord on an extension will handle any current that a tender would draw.
In short no trouble with an entension cable ....just don't use say a 300 foot extension cord which has exceptionally small wiring to power the tender as losses will be large in the cable feeding the tender.
Short extension less than 30feet = no problem.
Hope this helps ..
Ian
JUSTAKAR is offline   Reply With Quote
Old 01-03-2008, 08:13 PM   #9
RAGGDOLL
RAGGDOLL's Avatar
Hope this helps ..
Ian
Ian, explain that again, this time in english...
Old 01-03-2008, 11:41 PM   #10
dlynch
CF Senior Member
dlynch's Avatar
One concern...garage floors are wet. So I draped my cord so that it couldn't possibly hit the floor. And I don't use the one I might have run over with the electric mower.
DaveL
Reload this Page Is it OK to use an extension cord with a battery tender?
Tags
battery, cord, extension, tender
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
lg header question z06worshiper C5 Tech 13 08-11-2005 08:04 PM
Air Compressor questions redux Islander21 C1 & C2 Corvettes 15 10-15-2003 09:11 PM
Agh....brand new paint buffed with 3M...lots of new swirls? Finch Car Care Discussion 9 07-11-2003 10:33 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
