Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-30-2007, 03:33 PM   #1
dankhts
CF Senior Member
dankhts's Avatar
Default Lifter Noise
Seems my noisy lifter(s) getting worse and louder, on my '02 vert, people other than me can hear it now, I have extended warranty, so should be no problem, other than perhaps someone recommending a dealer that's had experience taking a few engines apart. My local one says they should be able to handle it, but haven't had any engines apart yet, I talked to a tech there who hinted that they talked a few people out of the idea of fixing theirs, convincing them it was ok and not bad enough. Any one have a similar problem fixed satisfactorily?
dankhts is offline   Reply With Quote
Old 08-01-2007, 10:42 AM   #2
dankhts
CF Senior Member
dankhts's Avatar
Nobody?
Old 08-01-2007, 11:57 AM   #3
kidneyboy
CF Senior Member
kidneyboy's Avatar
Wilson Niblett?
kidneyboy is offline   Reply With Quote
Old 08-01-2007, 12:05 PM   #4
Patman
CF Senior Member
Patman's Avatar
Before you take it in anywhere, have you considered trying a different oil? I'm assuming you probably use Mobil 1, and I know that a lot of people with all types of engines have noticed that Mobil 1 gives them more valvetrain noise than other oils. This also shows up when you view oil analysis reports with Mobil 1, as that oil tends to show higher iron numbers too, indicating more valvetrain wear.
So try a different oil first and see if that helps. Amsoil 5w30 has been known to make a big difference in quieting down a lot of people's noisy LS1s, so has Redline 5w30.
__________________
Black 98 C5 (3.15 A4)
208,000 km
Best ET-12.81 at 109.4 mph (1.98 60ft)
Stock except for Vararam & tuning
Patman is offline   Reply With Quote
Old 08-03-2007, 03:46 AM   #5
auctiondepot
CF Senior Member
auctiondepot's Avatar
Quote:
Take it to another Dealer, get it fixed under warranty. If a dealer tries to talk you out of a repair it would be becasue GM wont pay enough to make it worth their while. For all you know you could have a broken piston, or a bad bearing.
auctiondepot is offline   Reply With Quote
Old 08-03-2007, 10:11 AM   #6
dankhts
CF Senior Member
dankhts's Avatar
Exactly what I was thinking! I was just wondering which is the best dealer with experience taking these engines apart - I'd hate to have it go back together worse than it was before....
Old 08-03-2007, 11:48 AM   #7
75 Stingray!
CF Senior Member
75 Stingray!'s Avatar
Check for an exhaust leak at the manifold, this is usually mistaken for lifter noise.
75 Stingray! is offline   Reply With Quote
Old 08-03-2007, 12:40 PM   #8
dankhts
CF Senior Member
dankhts's Avatar
Quote:
Did that, seems ok..... definately comming from under the valve covers...
Old 08-03-2007, 02:35 PM   #9
auctiondepot
CF Senior Member
Quote:
This is probably the stupidest thing you could do.........
Mask the problem and let the warranty run out before the engine blows up! not good advice.
Ive had an engine builder suggest that one, I didn't buy it then and I'm suing him for damages now.
Old 08-03-2007, 02:50 PM   #10
dankhts
CF Senior Member
dankhts's Avatar
I have heard that other oils will change or reduce or even eliminate the lifter noise, but it's usually only temporary. I feel that it should be repaired under warranty, and shouldn't happen when using the maunfacturer's specified oil grades and quality, especially the same brand as factory fill. I just wonder who a good dealer is that's had these engines apart a few times for similar or more serious problems, and has fixed them properly with no further issues.....
Sometimes the wrong mechanic can create night mares down the road.. I see it regualarly in my own heavy truck shop.....
Old 08-03-2007, 02:51 PM   #11
Patman
CF Senior Member
Patman's Avatar
I'm not suggesting he do it if there is an actual problem, what I'm suggesting is that there isn't an actual problem with the engine at all, but that he simply is using the wrong oil to begin with.
I know this will ruffle a lot of feathers on here, but Mobil 1 is really not a very good oil at all. It has gotten even worse over the last few years. With many types of engines, not just LSx based ones, this oil has given a lot of people greif because of louder valvetrain noise, and higher valvetrain wear in their oil analysis reports.
So I'm not suggesting that he try to "mask" any problem here at all. I'm simply suggesting that he might not have a problem at all, he might just be hearing the typical LSx engine noise, but amplified a few times over thanks to the crappy valvetrain protection that Mobil 1 provides.
By the way, I never give bad advice, and don't appreciate being accused as such....
Old 08-03-2007, 02:58 PM   #12
dankhts
CF Senior Member
dankhts's Avatar
Hey Patman, I understand exactly what you're saying here about better oil qualities available, but this noise is getting worse, starting from only when cold started (dissappeared when warmed up) to being constant. My oill sampling shows no signs of excessive wear btw...I think I'll try phoning a few other dealers to see if any of them give me a warm and fuzzy feeling of comfort about letting them take my engine apart, and try to get it fixed before the warranty expires.... I only have about 6 k's left on my GMPP.....
I had a guy walk up to me in the parking lot of the mall one day cause he could hear my noisy lifter and said he had the same problem - even asked if I was using Mobile 1, I said yes, and he said he changed to Syntec on his Camaro and had better luck, and got rid of his valve train noise....
Old 08-03-2007, 05:16 PM   #13
SLED28
CF Senior Member
St. Jude Donor "08
SLED28's Avatar
Send a message via MSN to SLED28 Send a message via Yahoo to SLED28
As air temp goes up in the summer, the oil will thin out which could explain the more noise its making recently. Who do you deal with in Hamilton? It is pretty simple to pull the heads and swap lifters, they should be able to do it. I am wondering if they checked for bent pushrods?
SLED28 is offline   Reply With Quote
Old 08-03-2007, 05:18 PM   #14
SLED28
CF Senior Member
St. Jude Donor "08
SLED28's Avatar
I agree Patman, and also I like the thicker oil in the summer, it will help the engines reliabilty...
Old 08-03-2007, 11:20 PM   #15
eb02z06
CF Senior Member
St. Jude Donor '08
eb02z06's Avatar
I agree with PATMAN on this 100%-mobil 1 5w30 is JUNK!!!! It breaks down too easily-gets sucked through the pcv and fills your intake with oil-which later builds up on your pistons whcih in turn leads to detonation.
A good way to test this is to but on a simple catchan-drive the car around and see how much oil collects. Then on your next oil change-swap to a different brand-I swapped over to crappy tire oil-and the oil being caught in the catchcan was half as much.
PATMAN can verify this-Mobil re-formulated there oils a while back, and since then there 5w30 has been awful. Ask Patman what he prefers or for a better replacement-it's worth a try before tearing it apart.
eb02z06 is offline   Reply With Quote
Old 01-28-2008, 07:59 PM   #16
NEO1
CF Senior Member
Sounds more like an engine problem, not a lubrication problem no?
NEO1 is offline   Reply With Quote
Old 01-28-2008, 08:16 PM   #17
NOCRISIS
CF Senior Member
St. Jude Donor '09-'10-'11
Support Corvetteforum!
NOCRISIS's Avatar
if there is warranty,why have this discussion,get her done!
NOCRISIS is offline   Reply With Quote
Old 01-29-2008, 12:25 AM   #18
CDN_Wolf_eh
CF Senior Member
CDN_Wolf_eh's Avatar
let's keep it friendly in here, eh.
CDN_Wolf_eh is offline   Reply With Quote
Old 01-29-2008, 09:34 AM   #19
dankhts
CF Senior Member
dankhts's Avatar
Boys Boys - why can't we all just get along!
Oh, and theynever did anything about the lifter noise btw, they said it wasn't serious enough - no more W.N. for me - left the car there a week with a list, and basically none of it was done...
Oh, and I'm switching oil brands too, as per Patman's recommendation....
Old 01-29-2008, 10:14 AM   #20
vettefan123
CF Senior Member
What kind of noise is it making? Is it like a 'tick', 'tick', 'tick'..... I had that happen on my LS1 SS a couple weeks after I bought it. I ended up taking the top end of the motor apart and found the problem. It had two bent pushrods. I ended up fixing the problem for under $100 bucks, thank goodness!! I would also go over to ls1tech, and do a search. There are lot's of guys over there that know there stuff!! Good luck!
vettefan123 is offline   Reply With Quote
Reload this Page Lifter Noise
Tags
2000, c3, c4, corvette, forumnoisy, lifter, noise
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
92 lt1 lifter noise DRAGRCR1005 C4 Tech/Performance 9 07-28-2004 09:16 AM
Lifter Noise?? MikeyD C5 Tech 16 11-04-2003 03:42 PM
lifter noise after a valve job, is this normal?? robertpel9 C4 Tech/Performance 9 10-24-2002 10:27 AM
Smoke, crank pressure, infrequent lifter noise Jeffyvette C4 ZR-1 Discussion 10 10-14-2002 12:37 PM
Help! Lifter noise, I think???? polyrocks C1 & C2 Corvettes 18 09-12-2002 02:25 PM
LT4 Lifter Noise John Ruy C4 Tech/Performance 9 05-03-2002 02:17 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
