You don't NEED an X pipe. The car comes stock with an H pipe, (pretty sure the C 5 did at least). Supposedly an X pipe will flow better and eliminate some of the popping on deceleration with an aftermarket exhaust, but damn, thats part of the fun in an exhaust!
As long as the car doesn't have a Y pipe, I don't see much difference between an H and an X, probably a lil different sound is all. If it IS a Y pipe, you WILL want to replace it as that is not a true duel exhaust.
Some people will tell you an X pipe is better than an H pipe, but I think its al lopinion, and opinions are like a$$holes, everyone has one.
Then again, I am no expert, so get some more opinions please!
__________________
-Corrado
2008 JSB C6
LG Street Series Headers, B.B. Bullets, Vararam, Rear Z06 wide booty, and ?? under the hood.
"Better a street King than a garage queen" ... Gone but never forgotten 2006 VY C6 Z51...
Running straight pipes is always a cool option, sound wise.
Generally the x-pipe option (also referred to as a balance-pipe) is to balance the flow availability and efficiency out of the engine and therefore make a more efficient engine, more power, ..blah,blah,blah...
It is not necessary to run x or h-pipes but on non-blueprinted engines (like a mass-produced engine), it will help with power and efficiency.
Location: Mississauga, Ontario I know all the answers it's the questions I don't understand
H and X pipes work on the scavenging principal, that being a pulse from one bank of the motor creates a small vacuum in the x or h pipe and therefore the next pulse will have less restriction or in other words will be pulled along the pipe by the vacuum resulting in a small power increase. The only difference I can see between an X and H pipe is that the X pipe probably flows better by it's design.
__________________ 1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust Paint by Dream Car Garage
Location: Oakville, Ontario Corvettes were built to be driven...not trailered
Quote:
Originally Posted by SICK-VETTE
what about if i take out the h-pipe and the x-pipe and do straight pipe?
When I had my LT headers put in last year, I had the shop install hi-flo cats and straight 3" pipes all the way back to the Corsa's...no H or X pipe. Car sounds great and what I loose on the "X" factor, I gain from having larger pipes.
For stock exhaust, the x pipe definatlely helps but on a custom exhaust, their advantage is negligable
Lots of opinions and facts and all will vary depending on the application you are running. With stock you will have an advantage with the X or H pipe but general agreement is that the X pipe does function slightly better and provides better balance in the exhaust. Running straight pipes will give you the sweetest sound but depending on if your engine if stock or modified should reflect the diameter you use on your exhaust. Going too big could cost you some torque on a stock motor but will provide greater flow at high speeds for better HP top end. I suggest always have a plan on what you intend to do before you do it. Work from there. If major engine mods are in your future then plan your exhaust for that so it will work best and you are not having to install new exhaust all over again. etc etc
Quote:
Good point Mike. All my engine/drivetrain mods were done with top end speed in mind. Not being a 1/4 mile guy, I want my power band to be at the mid/upper range of my RPM curve and so you're right, the larger pipes will give me that.
That way, when I'm cruising and some pesky ZR-1 one pulls up and hits it, I can run with him for at least a little bit
