My car came with the FE1 base suspension, and its really "floaty" to say the least. Its a cheap upgrade that really tightens things up. I am also replacing my shocks with 04' Z06 ones. Supposed to be the best upgrade for the money. My shocks need replacing anyways, they are 7 years old now!
Swapping out the shocks and sway bars will really help. Have you given any thought to changing the springs as well? That would be a very beneficial mod as well.
Location: ================ From a Fire Hall in Toronto ================ 9/11/01 FDNY 343 R.I.P.
Quote:
Boy you sure do like spending other peoples money don't you Bruce? I'm also thinking of replacing my shocks, when in April can I book into your shop?
Yes I have been debating about the springs as well. Posted my questions in the C5 Tech section and got a variety of replies. Basically if I am not auto crossing and just want a firmer daily ride. No need to change to Z06 springs.
From what I was told, the "spring rate"?? I think thats what its called is practically the same between the Z06 spring and the Basic FE1 Spring. Not much difference and not worth changing unless your into hardcore racing/auto crossing.
I added you to MSN.... but I tend to use Yahoo Messenger more often, the new phone call up grade is amazing! No more long distance charges to Calgary for me!
I agree, however, try Google Talk, it blows yahoo voice out of the water for clarity! My girlfriend uses it daily to talk to her mom in Israel!
And thats REALLY long distance!
Jason
I would still do it, it's not that much more work, and the end result will be that you will have a suspension package that is balanced and was designed to work with all the components, not 2/3 of them. Think of this: GM spends millions to develop things such as this, and I would trust what they know works. Those springs/shocks/sway bars were developed to work together as a system. You should also get your car aligned and caster/camber set to ZO6 specs to fully realize the gains from the suspension.
In the past, I have pieced together suspension systems in different cars, but once I realized that installing a packaged suspension system developed by professionals that know a whole lot more than I do about these things, I never looked back. You don't need to be into hardcore racing/auto crossing to realize the benifits from this.
