Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-25-2005, 03:33 AM   #1
75 Stingray!
CF Senior Member
75 Stingray!'s Avatar
Default So how was your Xmas?
As you can see I enjoyed mine
Now I just need the Heads, Cam, Short block... New engine ETA summer 2007
75 Stingray! is offline   Reply With Quote
Old 12-25-2005, 12:00 PM   #2
AGVI
CF Senior Member
AGVI's Avatar
What are you building?
AGVI is offline   Reply With Quote
Old 12-25-2005, 02:54 PM   #3
75 Stingray!
CF Senior Member
Sbc
Old 12-25-2005, 03:46 PM   #4
AGVI
CF Senior Member
AGVI's Avatar
What are you putting in it? What numbers are you expecting?
Old 12-25-2005, 04:12 PM   #5
Ratsirt
CF Senior Member
Mine was great!
Early Santa delivered LT1 with the 144 B&M supercharger and now a complete MSD system.
Glenn
Ratsirt is offline   Reply With Quote
Old 12-25-2005, 06:20 PM   #6
75 Stingray!
CF Senior Member
Congrats Glenn, I'm anxious to see your motor this summer.
Quote:
Heads:
Dart Pro 1 230cc 2.08in 1.625ex
Block:
383 stroker with 6" H-beam rods, 11:1 forged pistons
Cam:
Those are 1.7 ratio rockers in the pic above so you can be sure the cam will be mild
Intake:
Edelbrock Vic Jr
Holley 850 dp
Ignition:
MSD 6AL
I have the intake, carb, ignition, and recently the rockers. I'll be getting the cam and lifters around Feb. the heads hopefully spring, the rotating assembly fall, and the machine work/assembly done in the winter.
I suspect the motor will make ~230HP and 265TQ
__________________
Alex
1975 Corvette Stingray
2001 Cadillac Catera LS1 6speed soon
Old 12-25-2005, 06:32 PM   #7
AGVI
CF Senior Member
AGVI's Avatar
500/500?
Old 12-25-2005, 08:20 PM   #8
7t2vette
King Of The Shyte Wolves!
Support Corvetteforum!
7t2vette's Avatar
Quote:
Heads:
Block:
Cam:
Intake:
Edelbrock Vic Jr
Holley 850 dp
Ignition:
MSD 6AL
Why not build a 406 Alex? It will actually cost less because besides the normal stuff, no additional machine work will be neccessary. Actually, I guess you have to factor in the cost of a 400 block to that, but you know what they say.......there is no replacement for displacement! Unless you go with an internally balanced crank (which you can also do on a 406,I did) you will have to buy a new balancer and flexplate anyways, so its not like you will save any money there by using your old stuff.
7t2vette is offline   Reply With Quote
Old 12-26-2005, 01:23 AM   #9
75 Stingray!
CF Senior Member
I'd do a 400+ cid only if I would use an aftermarket block and the added cost would ad another year to the buildup. The only added machine work would be clearance required for the rotating assembly which I am going to do myself.
I played with Dyno2000 and found that the larger displacement motors did not gain much in terms of HP but they gained in TQ, I figured ~530 would already be to much and could not justify the added $3000 cost of an aftermarket block.
If when the motor is done I’m still not satisfied I could still build a 427...454 short block. I think my radial tires will hate me with the 383.
BTW how many blocks did you check before finding a useable 400?
Old 12-26-2005, 08:58 AM   #10
gdh
CF Senior Member
wow, I got warm gloves to go with my hat for cold top down cruising.
gdh is offline   Reply With Quote
Old 12-26-2005, 10:53 AM   #11
7t2vette
7t2vette's Avatar
Ummmmm, isn't more torque the main goal here?
With that motor, more than your radials will hate you! If you plan on driving it hard,and I know you will,your entire drivetrain will hate you!
I went through way too many 400 blocks than I care to remember to find a good, virgin block to work from!
Old 12-26-2005, 12:20 PM   #12
75 Stingray!
CF Senior Member
Quote:
I'm going for HP at 6500+rpm and TQ over 500. I want to hear that sb scream. If Torque was the main goal I'd use a smaller cc head RV cam and 600carb that should get big TQ# @ low rpm but I won't be going anywhere.
Currently a TH400 and in the future a 4L80E, Trans will be ok. Rear end should be able to live as long as I don't use slicks.
Old 12-29-2005, 07:19 PM   #13
Ratsirt
CF Senior Member
Also, received my nice speed demon today, I had mentioned at Lasfest that I wanted one well Santa was nice and had it delivered today, little late but oh well.
Reload this Page So how was your Xmas?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Do I need to go to 30# injectors??? Strike3 C4 Tech/Performance 214 05-21-2005 02:51 AM
H/C for roadracing ajderzie Autocrossing & Roadracing 32 03-15-2005 11:29 PM
Factory visitors - BEWARE! hlcptr C6 Corvette General Discussion 72 03-01-2005 02:17 PM
new Parts for sale bob369 C3 Parts for Sale/Wanted 9 11-25-2004 11:00 PM
AAARRG Keisler is doing it AGAIN! 71'AirStrike C3 Tech/Performance 41 12-27-2003 02:20 AM
Forum Calendar - Update ERND IT C4 General Discussion 12 08-10-2003 12:30 AM
Forum Calendar - Your input needed ERND IT C3 Tech/Performance 18 08-07-2003 12:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
