Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-23-2005, 04:44 PM   #1
harrin
CF Senior Member
harrin's Avatar
Default Vin and code stamp help
It looks like my block was machined, the front pad on the passenger side has no data stamped. the casting number is 3963512, the date code is L14 9, it is a 71 LS5 4 Speed, built Sept 11, 1970. Is there somewhere to get this done,what info should be stamped be on the pad? All other casting infor is correct for heads, intake, axle,Trans etc. Any help would be appreciated.
harrin is offline   Reply With Quote
Old 12-24-2005, 02:49 PM   #2
1971Coupe
CF Senior Member
1971Coupe's Avatar
CPH should also be stamped on the pad, refer back to the 71registry link.
1971Coupe is offline   Reply With Quote
Old 12-24-2005, 02:53 PM   #3
1971Coupe
CF Senior Member
1971Coupe's Avatar
The engine date code is a two symbol code cast into the block. This code is located to the right of the distributor on the top rear of the block. A typical code would look like "B1" which decodes as February 1971. The second symbol denotes the year "0" = 1970 and "1" = 1971. The first symbol denotes the month by using the alphabet as shown below:
A JAN
B FEB
C MAR
D APR
E MAY
F JUN
G JUL
H AUG
I SEP
J OCT
K NOV
L DEC
HEAD CASTING NUMBER:
The engine casting number is located to the left of the distributor on the top rear of the block.
"3946074" = 454 CID LS6 425 hp
"3993820" = 454 CID LS5 365 hp
"3973487" = 350 CID 270 hp and 330 hp LT1
Reload this Page Vin and code stamp help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trim tags and what color to choose? 65RDSTR C1 & C2 Corvettes 17 10-29-2004 03:07 PM
Serial Number help Brooksie C1 & C2 Corvettes 17 11-22-2002 07:44 PM
Help with vin and engine numbers HEARTBEATUSA C3 Tech/Performance 10 09-14-2002 01:14 PM
Help ! Are These Matching Numbers for my 73 73-454 C3 Tech/Performance 20 03-30-2002 02:58 AM
Need help with lots of part numbers Jester69Stingray C3 Tech/Performance 15 12-19-2001 12:13 PM
New Member needs help: What did I buy? rdys67 C1 & C2 Corvettes 11 08-24-2001 04:18 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
