UPDATE*************
ok, so tongiht I re-installed my Hurst shifter (again) and decided to pull the spring right out thats attached to the clutch pedal. When all was done, I took it to the back roads and launched it 4 or five times, each time running it to redline up to 4th....not once did it stick
Not sure if its a permenant fix but it feels real good again.
My dealer in teh meantime is calling GM TAC? (the engineering group) to find out if there is a common problem across all C5's and what they recommend the fix is, they feel they are going to say if its modded thats why and its the pressure plate...oh well... it shifts
