If you have the e-mail addresses for the participants, could you please forward the following note to the following people (one includes you...):
To:
, Glenn, , Mike Fogelman
Those of you who are running Holley and BG vacuum secondary carbs can usually benefit from a secondary spring change. The springs are only available as a "kit", and are not sold individually. As these kits sell for $10 each, and I never know if they will be needed or not, I usually don't bring these with me (since each car would use the one "good" spring in each kit). If you would like to play with the secondary side of your carb a little during the tuning event (there are usually gains to be made by doing so), please pick up a Holley Kit part number 20-13 (USD $9.88 from Summit under part number HLY-20-13). If you would like to get the kit, and authorize me to order it for you and bring it with me, please let me know no later than this Tuesday, and I will arrange to get it for you.
Mike - Can you get me your carb list number?
Glenn - Is your Crane distributor equipped with vacuum advance?
Glenn, would you mind picking me up one, if you can while you are still there? If has got to be hotter than a female fox in heat in a forest fire in Pheonix right now!
