Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Canadian Events
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Canadian Events Canada, eh?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-12-2005, 09:30 AM   #1
GettReal
CF Senior Member
GettReal's Avatar
Default Lowering a C5
I am attaching my pics and also the post that Z06Cab provided..
ok and here is the additional thread with more info.. Hope this helps
Z06Cabs post is halfway down this thread - pics included
GettReal is offline   Reply With Quote
Old 07-12-2005, 08:09 PM   #2
4GTABODT
CF Senior Member
St Jude Donor '07-'08-'09
Support Corvetteforum!
4GTABODT's Avatar
Location: Oakville, Ontario Corvettes were built to be driven...not trailered
Send a message via ICQ to 4GTABODT Send a message via AIM to 4GTABODT
Steve, can you be a little more specific
What can I say except WOW and THANK YOU!!
4GTABODT is offline   Reply With Quote
Old 07-12-2005, 09:38 PM   #3
Chrispy
CF Senior Member
How long did this take you to do and how big was the drop?
Chrispy is offline   Reply With Quote
Old 07-13-2005, 10:46 AM   #4
molson
CF Senior Member
molson's Avatar
I have tried to do lower mine several times....
I can't get the front bolts to turn!
molson is offline   Reply With Quote
Old 07-13-2005, 11:14 AM   #5
z06cab
CF Senior Member
z06cab's Avatar
I did the same thing! It just means you still have a load on the spring...look around, make sure there's nothing...use a bottle jack to reduce the pressure on the spring if needed...Also, some have taken the bolts off the bottom part of the shock mount to reduce pressure as well..Haven't tried that though..Just make sure you torque those bolts back properly on the shocks if you do remove them.
Dropping the front takes about 20-30...the rear 10min..
z06cab is offline   Reply With Quote
Old 07-13-2005, 12:06 PM   #6
GettReal
CF Senior Member
GettReal's Avatar
you can see the drop I have in this pic... if you want actual measurements from the ground to the wheel well I can do that for ya..
and the front from an angle
Old 07-13-2005, 02:31 PM   #7
molson
CF Senior Member
molson's Avatar
Quote:
I tried that........It lifted the car and the bolts still wouldn't turn.
Maybe I will try undoing the shock when I do an oil change this weekend.
Old 08-07-2005, 04:02 PM   #8
TSDuke
CF Senior Member
TSDuke's Avatar
Send a message via AIM to TSDuke
Thanks for the pictures, I found them as well as others during a search on how to lower my vette. I still haven't found a detailed how-to yet. My guess would be front - lift, place on jack stands, remove wheels, use jack to relieve pressure on leaf spring, turn counter clockwise to lower (both sides); rear - I'm not sure on this one, but I haven't read where you need to relieve pressure on the spring. Can you just raise the rear, and turn the bolt until there are a few threads remaining in sight?
Thanks guys.
Here is a picture showing my desperate need of a slight drop.
__________________
'00 Pewter FRC *FOR SALE*
HPTuners, PMFL Stg 3 Heads, PRC Gold, LGM G5X3, LS6 Intake, Trick Flow 7.4 PRs, SVO 30#, LS2 Chain, 160* Stat, BPP Vortex Rammer, Dynatech Supermaxx L/Ts, B&B Bullets, Magnecor, NGK, B&M 45044, R-D Racing Cross Bar, Z06 Clutch Assembly, DRM Brake Ducts, Goodridge SS Lines, Speedbleeders. . . .447rwhp 402rwtq
TSDuke is offline   Reply With Quote
Old 08-07-2005, 04:07 PM   #9
TSDuke
CF Senior Member
TSDuke's Avatar
Nevermind guys, I found it.
http://www.corvetteforum.com/techtip...D=27&TopicID=1
Reload this Page Lowering a C5
Tags
c5, corvette, lowering
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
