Installed front Radiator Grill guards & Black Titanium Lugs
Removing the front fascia is actually quite easy. It just takes some time. I removed the front plate bracket and think it looks much better.
The lugnutz make a HUGE difference. Nothing worse than dark wheels with chrome nutz.
Don't use air tool to install, same torque 140 'LB.
Grills
Does the ABS plastic grill solution seem to be thick/tough enough to stop rocks or maybe aluminum a good option to pick, of course it depends on rock size ? Looks like both choices available.
