Z06 Gearing Makes Little Sense
#61
Some presumably retarded bean counter wanted to save 1 dollar 39 cents per car... I hope so at least because if its not the case then.... then it is not good!
Zed Sled (12-16-2023)
#62
Received 2,069 Likes
http://fbaum.unc.edu/lobby/_107th/126_CAFE_Standards_2/Organizational_Statements/GM/GM_CAFE_Fleet_Requirements.htm
https://www.reuters.com/business/autos-transportation/stellantis-gm-pay-363-million-us-fuel-economy-penalties-2023-06-02/
https://gmauthority.com/blog/2023/10/gm-could-pay-6-5-billion-in-fuel-economy-standards-penalties-by-2033/amp/
The following 2 users liked this post by PRE-Z06:
RiptideHTC (12-16-2023),
#63
Yesterday I ran the Gila Bend 1/2 mile with the C8Z. We did have a ~15 MPH head wind. I was expecting 155-160 before the wind forecast. I did get one run in at 155.17 MPH. but even the top of 4th was slow to come and 5th for the last ~10 MPH was very modest, even more so than my C6Z after the 4th to 5th shift, but that was almost 20 MPH higher at 160+ when it was stock.
#65
Head winds are tough on ANY car at that speed!
#66
My last run was against an HCI C6Z like my 09. I got him off the line good even though he started first and the starting line paving was really poor. I could see at about 125 that he was starting to catch me. He went by when I was doing 145 and trapped about 10 MPH faster than I did. I went and talked with him after and told him the run went as I expected, getting him good from a did but in a 1/4 mile I would have had a better ET but he would have trapped 4-5 MPH higher.
The following 3 users liked this post by AzDave47:
#67
What is the point of having 8 gears in Z06 if only gears 1-5 are utilized for acceleration to top speed and gears 6 and 7 are being used as overdrive gears? Why did GM choose to not maximize the acceleration potential of this car?
<huge snip>
If you’re listening, GM, maybe give us a facelift car in 2026 with revised gearing — and why don’t you also clean up your act with the transmission in general.
<huge snip>
The CAFE fuel standards are something that NO manufacturer wants to get a violation of. Would you be happy with your LT5 turning 4800RPM to make 75MPH in top gear? Think about the accelerated wear, the excessive heat build-up. Now, the car gets 20-21MPG on the freeway. Would you like to get 6MPG? You'd now have a cruising range of 100 miles. Is that good for you? All to spin the engine, needlessly. Would it be worth an additional $10,000 for this "benefit?" That's about what the fine from EPA would be, if amortized across all the C8Z06's. (Missing the CAFE standard by 2/10ths of 1MPG costs $50,000,000. And this was 15 years ago. Who knows what the fine would be, now that the current occupant at 1600 Pennsylvania Ave has devalued the dollar to record lows...)
Besides, how often do you "bury" your speedo? Exactly.
The following 2 users liked this post by NORTY:
bufalobob (12-17-2023),
RiptideHTC (12-18-2023)
#68
I only went over 150 MPH 7 times yesterday in my C8Z, and each time I wished for better gearing.
7 passes in the 1/2 mile NFZ event at Gila Bend AZ.
The following 6 users liked this post by AzDave47:
123sugey (12-17-2023),
Jwalker3rd (12-18-2023),
mfain (12-17-2023),
robob (02-11-2024),
Too-Fast (12-18-2023),
and 1 others liked this post.
#69
The only way I see they could have offered better gearing was to make it a performance option, so that it took less of a hit on CAFE as the majority of Z06 owners probably don’t care and those that do could absorb the costs. Would they also option for performance gearing if it meant less of a warranty because of the increased rpms of the engine?
For scenarios with vmax in 7th or 8th, it would be an interesting issue because 8th gear would be significantly shorter.
123sugey (02-11-2024)
#70
I'm surprised nobody mentioned this already, but CAFE aside, GM could be saving the proper gearing for the ZR1/Zora to give it an extra edge in performance stats and lap times.
The following 4 users liked this post by jc123:
#71
Presuming the ZR1 is TT, they will get torque that way. Zora with TT and electric motor, plenty of torque and front wheel traction, too, so neither will need gears for acceleration. They may do different gears to handle the added torque, though.
#72
#73
No, Just about all the Corvette runs I've done is with the OEM sized tires front and rear. I did run a wider set of front Nitto NT05s as my first aftermarket set of tires for my C6Z. They were OK, but the OEM sized PSS had more grip by a lot. I drive 100-500 miles to events on the tires I am going to run so being safe on the highway is important to me as well and also limits what tires I am willing to run.
This event was 150 miles away and I ran the OEM PS4S ZPs. It was 29* when I left my house. In warmer weather I might run the Cup2R ZPs that I have mounted on the OEM rims. Alternatively, I could drive down to the Valley the afternoon before and stay overnight. I will likely have to do that for the road course event in February. It is typically 15* cooler hup here in the high country than down in the Valley.
#74
GM doesn't profit off dealer repairs. In fact, warranty repairs cost them money.
Back to gear ratios:
Tadge has publicly stated the engineering team want different ratios but management and the bean counters told them no, for cost saving reasons.
#75
And the fact that they couldn't find a manufacturer who was willing to build a bespoke manual tranny for such a small market had nothing to do with it, I guess....
#76
C8Z gearing is something I’d love to hear from Tadge. We know they know how to gear a car. The C6ZR1 box has shorter 5th and 6th so it can run hard up top and goes well over 200. You can watch roll racing videos of them walking Carerra GTs. Then we get a C7 ZR1 that will do freaking 212. Now we have a car that sounds neat, but is really flat up top.
#78
#79
People talk about him by first name — is he a guy who is accessible or whom we could contact? Does he post around here? I had to look up the name Tadge and I am just finding out he is the chief engineer for the C8 project. Certainly it would be nice to ask him about this (and other matters).
#80
