C8 Z06 Splash Guards
#41
Guessing you didn't have the tab aligned to insert the clip into the fender hole when pressing in. Just installed my front guards with the factory clips and had no issues. Once I got the process of removing the clips down it was all pretty quick. Paragon included clips but using the OEMs made sense. Finish quality matches the OEM carbon flash side skirts. I'd like so see someone with the rear guards installed. Don't want the car looking like a Subaru STi.
I guess that is possible, I don’t think that it was misaligned, other side was no issue, but anything is possible.
#42
I just received the full set, front & rears splash guards for my Z06 from EOS today. Have not installed them yet, but the construction quality & carbon flash finish is much, much better than the set of fronts only that I had ordered from Paragon a few weeks ago.
The plastic tabs that the metal clips attach to on the Paragon units seem a little flimsy. I had one break off when installing them with what seemed to be just moderate pressure.
I’ll post a few pics after I get the EOS ones installed in a couple of days.
Car Junkie 24 (04-05-2024)
#43
Received 1,737 Likes
Their soul purpose is to intercept stones thrown from the tires so it won't take long for the Carbon Flash paint to start looking bad. I had a can of this stuff and I'll be spraying mine tomorrow. I've used the black version and this coating is bulletproof. The clear version should work great.
Lefty32 (04-07-2024)
#45
I just received my full set from EOS/RGS via FedEx. And they are in perfect condition, paint quality and finish is great and the price can't be beat (although I believe, as indicated above, they may have been mis priced). Definitely a keeper, even at full price of $370? They DO NOT have the mesh grill that the ACS rears appear to have. But, that doesn't matter to me, in the least.
Now all I need is my Z06! Expect delivery in the June timeframe.
Last edited by hamta; 04-05-2024 at 02:03 PM. Reason: Further clarification of delivery date of Z06.
#47
Splash guards install ?
Did you have to remove rear wheels to remove/install the rear guards?
#48
Sorry. I should have mentioned that I'm expecting my Z06 W/Z07 in the June timeframe. That being said, I don't believe that you need to remove any of the wheels (front or back) to install the splash guards.
#49
I had to break out the Dremel and trim some of the tabs so they could fit properly. This is my second set because the first had paint blemishes. EOS took care of me and sent another set.
#51
#52
Received 1,530 Likes
Unmodified C8 of the Year 2021 Finalist
/Bear/ (04-08-2024)
#59
The clips they sent weren't the same, so I used the OEM clips (which they recommended). The trick is getting the clips off without bending them to swap over, but the installation is all done.
KIKNBAK (04-08-2024)
