ZR1 LT6 Hybrid Rumor
Received 5,324 Likes
With this rumor getting some momentum from a recent video of a camouflaged mule seemingly driving in silent mode with no discernible engine noise, would this configuration, if true, deter anyone who was originally planning for a TT and ICE only ZR1? This rumor suggests that the ZR1 would get the LT6 paired with the hybrid drivetrain to produce over 800hp via AWD… with the Zora getting the same setup but with the TT LT7 instead. I’m sure the numbers will be impressive if so and the hybrid power combined with the NA LT6 seem like a great match, but this move would also significantly change the driving dynamics of the car. It would no question get the power down though.
Interesting move if so, the pairing always made sense but that would make three performance variants hybridized and only one ICE only, NA powered performance variant (unless they eventually release a GS). I also wonder if a move like that would have any impact on future Z06 demand for the hardcore ICE only crowd?
Personally, I’m not sure what I think. Even though I jumped on MacMulkin’s ZR1 contact list awhile back ago, a ZR1 has always been a long shot for me personally. This rumor becoming a reality would likely keep me more interested in staying with a Z06. A more performance oriented Z06 Carbon would likely be my dream car for this generation.
The following 2 users liked this post by JockItch:
international blue (09-25-2023),
ZRacerLE (09-24-2023)
Popular Reply
09-24-2023, 12:47 PM
Anything Electric. No Thanks!
Never planned on going ZR1, but if I did, they would have to get crazy with weight reduction if it were hybrid... get it back down to 3700lbs.
The following 2 users liked this post by ZRacerLE:
AustinVetter (09-26-2023),
LE MANSZ (09-24-2023)
The following 11 users liked this post by RFS-Z06:
everjeff (09-27-2023),
Fishfryer527 (09-25-2023),
GMJim (09-25-2023),
and 6 others liked this post.
Hard pass due to the complexity, weight, and maintenance considerations with that combo.
TT CPC would be the only thing that would pique my interest, and even that is a hard sell from my viewpoint due to the weight increase.
The following 3 users liked this post by NA FURY:
If it is battery anything, I will cancel my reservation. It needs to have turbos, period.
The following 4 users liked this post by Michael A:
kratedisease (10-01-2023)
No one here knows, but...
The person who took that video posted on MECF that the two mules passed him going about 65 mph. The E-Ray's electric drive is only good up to 45 mph, and a max of 5 miles (at lower speeds - much less at 45 mph). So if those cars were running only on battery, they have a very different hybrid system than the E-Ray. One that almost certainly weighs a lot more than the E-Ray's system. Is that really what GM wants in the ZR-1 / Zora?
Turbos really reduce exhaust sound levels. If that was a twin-turbo engine running in stealth exhaust mode, or maybe even tour, the exhaust is likely to be very quiet.
The following 6 users liked this post by Red Mist Rulz:
CPhelps (09-25-2023),
JockItch (09-24-2023),
Kansasvett (09-25-2023),
Rob97rr (09-25-2023),
and 1 others liked this post.
TT in stealth will be near silent.
Red Mist Rulz (09-25-2023)
Based on just the weight factor alone, if it's an LT6 with E-ray front axle/battery, it's going to be REAL difficult to stomach close to 3900 lbs (unless there is SIGNIFICANT weight reduction, e.g. Magnesium Bedford Castings) for a ZR1....I understand the traction issues of just RWD, but it seems a CPC TT LT7 rather than a FPC LT6 + E-ray front axles/battery is the level of novelty and power a ZR1 should have to be known at the best of the best in the event ZORA is a pipe dream!
I believe GM will go the way of the LT6 with ERay's hybrid electric AWD system to give the ZR1 830hp it's easy and cheapest way to go vs trying to add twin turbo's to the LT6 or come out with yet another new engine. As far as added weight if they went with the added twin turbo's that would add some weight as well (but not as much as the hybrid of course) GM could try and cut the weight with additional carbon fiber to the car but again adds costs. Keeping the rear (engine) the same as the Z06 keeps the maintenance the same.
The one issue I see with the hybrid system is the battery drains pretty quickly for example in a 1/4 mile run it has like 1/2 the HP left at the end of the run.
I'm still counting on the ZR1 having a TT DOHC V8 (sounding like it's FPC) LT7, RWD only. A potential Zora allows them to thrown in the ERay batteries and front electric motor for 1,xxx hp AWD.
The following 5 users liked this post by Latterlon:
BearZ06 (09-25-2023),
jpmotorsport (10-11-2023),
RapidC84B (09-25-2023),
Too-Fast (10-04-2023)
The ZR1 will be TT, the Zora will be TT + eRay drive. Will be interesting to see if they can somehow revise the eRay drive to not cut out at 150.
Yeah I know... but the recent videos clearly show a FPC V8 with a more muted idle and three is no evidence of them driving under electric power. The highway video is well above the eRays electric-only speed. The C8 platform is designed around the eRay's battery and drive unit. There is no room for a larger battery set or a different drive unit. GM works on economies of scale and they're not going to make an eRay and then immediatly come out with a different FWD unit for the ZR1.
Received 1,069 Likes
Considering some dealers still don’t know how to keep a corvette from falling off a lift, I think they SHOULD keep it simpler. LT6/hybrid front. Why throw an extra engine variant into the mix when these dealerships haven’t even figured out how to keep these cars in the air?
The Consigliere
Received 5,457 Likes
The idle tone on what seems to be the LT7 sounds better than the LT6. That's a pleasant surprise.
The following 3 users liked this post by OnPoint:
