track tire sizes for z06
The following 2 users liked this post by Will Kwok:
Discount Tire (09-13-2023),
PRE-Z06 (09-13-2023)
Received 2,061 Likes
Since you’re going down an inch in the rear I’d recommend doing the same in the front and run their 275/35R19 as I saw a C8 run that front tire with the 325/30R20 rear, hope that helps.
minuteman71 (04-03-2024)
I will be using my z06 mainly as a track car and car should be here in 2 weeks. the oem 2R seems to last only 1 day on track on what I read.
I am thinking getting 19 front and rear and run 275/35/19 and 325/30/19 cup 2 or 285/35/19 and 325/30/19 goodyear 3R. any suggestions
Thanks,
Thanks,
You can run them until they chord (not just when the outside line disappears half way through the life) and most likely you’ll only chord the fronts after 4-5 days unless really really pushing it. I doubt you will chord the rears ever on track but rather heat cycle out after 32-35 or so sessions and the rear gets unwieldy.
Regardless, run a set until they Actually chord to know how much you can actually get out of them unless running costs are no concern.
there is a lot of meat left, 50% or so, even after the outside line disappears. Pic is a regular cup 2 from my 350R, but the principle is the same on when they are truly done. I’ve used up 15 sets probably
The following 2 users liked this post by MikeR397:
evanescent03 (03-13-2024),
ZRacerLE (03-24-2024)
Also, I have 2 sets of Cup 2R tires that have 1 full track day on them (z06). I bought them used from those that “money is no object for best times.” Look fine to me, I’m planning to get 3-4 more track days out of each set.
FYI 285/35/19 and 325/30/19 don't work unless you turn off traction control and stability control. if you don't turn off stability control, the rear brakes will constantly be working and you will fade the rear (stock ccb). I did that within 1 lap after 2 warm up lap. People recommendation of 285 or 295/30/19 is better choice
I am going to try 295/30/19 front and 325/30/19 rear when my car arrives. More choices than with the 345/30/19 rear:
295/30/19 & 325/30/19
Continental extreme contactforce
Hoosier R7
Goodyear supercar 3 (if they ever make them again)
Nankang CR-S v2
Toyo R888R
If the 305 works on the front, that would open up a couple other options including the Goodyear 3R as well.
Hoosier R7
Nankang CR-S v2
Toyo R888R
I have done three track days on 295/30/19 F and 325/30/19 R Nankang CR-S v2. Tires stick very well and are wearing great with -3.0 F / -2.5 R camber. Still probably 2 track days left on them. Excellent setup if you want to drive to the track, run some laps, and drive home.
#33
#34
I have chatted with 3 rim providers, one says get 9.5" fronts, another 10.5 and last one said 11", its extremely odd to get such a massive variance in rim sizes and for backs, some say 12, other 13. Overall, we talking about 4.5" variance, which is insanely huge for a car of this size and power, i mean who wants to give up that much rubber?
#36
Most of the 19" setups out there are geared toward a 295/345 combination which suggests the rear size of 13", but it's also worth noting that some tires are larger than others even given the same size ratings. The 325/30/19 CR-S v2 for example is essentially as wide and as tall as a 345/30/19 Hoosier R7 based on my real world measurements when mounted and works well on a 12" rim.
#37
